Bent Hitch...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gavinjd68, Jul 24, 2020.
  1. Jul 24, 2020 at 10:02 AM
    gavinjd68
    gavinjd68 [OP] New Member
    This is going to sound stupid but I just noticed one side of my hitch is badly bent.
    New truck (first truck) and I think i kinda noticed it before but thought it was designed that way, but now the paint has started to chip off. Was at the dealership today and they took pictures to send to Toyota.
    1. Is the hitch even replaceable?
    2. Can they just bend it back and repaint it?
    wilcam47 likes this.
  2. Jul 24, 2020 at 10:03 AM
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    couple bolts and it comes right off. bending it back and painting yourself is the easiest and simplest option. Those are for safety chains anyway so not load bearing by default
  3. Jul 24, 2020 at 10:05 AM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    Sledge hammer + spray paint = fixed.
    Tacosha, OldSchlPunk, EMR and 19 others like this.
  4. Jul 24, 2020 at 10:11 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    It's fine. I bent mine a few weeks ago same spot same side. It is for safety chains. I personally wouldn't bend it back. Just re paint it.
    Not 100% sure if itll mess with the strength but I would avoid bending or re bending a piece of metal.
  5. Jul 24, 2020 at 10:13 AM
    nartmot
    nartmot Well-Known Member
    Agree with the others in that its probably not a big deal. These things get trashed off-roading. However, it definitely shouldn't have come off the lot that way and you did pay for a new truck. If they are willing to replace it and you don't mind the wait and hassle of going to the dealership, get it replaced.
    gavinjd68[OP] likes this.
  6. Jul 24, 2020 at 10:17 AM
    Franky86
    Franky86 Well-Known Member
    Sac
    2019 OR
    I bent mine too a month ago. It doesn’t provide any structural report like the responses said above, just holds the chains. Cosmetically, if it bothers you, maybe try and hammer it back into place. Use a 2x4 as a contact point so you aren’t bashing the hell out of the metal and go for it.
    4x4_Taco likes this.
  7. Jul 24, 2020 at 10:19 AM
    Lunatic209
    Lunatic209 Well-Known Member
    17 Inferno TRD
    Bent mines on both sides, just took a sledge hammer to fix it up no big deal
  8. Jul 24, 2020 at 10:22 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I normally like to fix this things when they get damaged, as not to have a new POS,,,, BUT, I wouldn't fix this, especially if you're off-roading, it gets hit on even mild terrain.
    whatstcp likes this.
  9. Jul 24, 2020 at 10:25 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    +1 on this, simple fix and move on.
  10. Jul 24, 2020 at 1:27 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    The oem hitch is part of the rear bumper I think, if I’m wrong then I’m wrong.
  11. Jul 24, 2020 at 1:57 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    Rather than a sledge hammer, I'd put a large pipe wrench on it and take advantage of leverage and a strong grunt and slow bend it back to near straight. Then sand and spray. But, to be honest, leaving it alone will not affect the utility of that part of the hitch.
  12. Jul 24, 2020 at 2:15 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    someone used the chain holders for a towing/recovery point, and was too aggressive with the throttle, pulling, snap, to get out. been there, done that, got the Tshirt, and hat. hammer, dolly, semi gloss black paint. wont make that mistake again. :D Ski
    Thomasf94 and Dirk Diggler like this.
  13. Jul 24, 2020 at 4:22 PM
    t0nyvalenzuela
    t0nyvalenzuela Well-Known Member
    2019 Tacoma TRD OR DCLB
    Puck level
    Don’t sweat it OP. It’s the first thing that bends when you first take it off road. If you plan on it.
  14. Jul 24, 2020 at 4:33 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    If you bend it back it will absolutely weaken the metal.
    Will it be an issue going forward? Very, very slim chance as you would have to be towing, have the trailer detach from the hitch, and the safety chains would have to load that section of the hitch. This sounds like an unlikely scenario to me. If it were my hitch, I would bend it back, paint it, and get on with my life.
  15. Jul 24, 2020 at 4:47 PM
    Tacomike18
    J
    Here and now...a Kenny Chesney fan huh?
    soundman98 and t0nyvalenzuela like this.
  16. Jul 24, 2020 at 5:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    BFH.
  17. Mar 7, 2022 at 1:14 PM
    jmd384
    jmd384 Well-Known Member
    2017 Inferno TRD Off Road
    Bent mine a little back in January. Did it again on the same side yesterday. I know it's there so it's annoying, but nothing more. How's it go, "have fun, break some"? With that being said, you shouldn't be getting a new truck off the lot like that. I'd complain to the dealer if it came that way. Mine, well that's what I get for not leaving it as a pavement princess. And I try to keep things nice...
  18. Mar 7, 2022 at 1:25 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Hammer and paint
    Or
    Just hammer
    Or
    Just paint
    Or
    Fuck it and make a sandwich.
    :sandwich:
  19. Mar 7, 2022 at 1:27 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    two year old post...
  20. Mar 7, 2022 at 2:55 PM
    jmd384
    I was just gonna leave it and hit it with a coat of PSC black wax. Close enough to paint and it will prevent corrosion. I figure it's just gonna get bent again..
