Benefits of coilovers?
Discussion in 'Suspension' started by 09WhiteTaco4x4, Jul 27, 2009.
  1. Jul 27, 2009 at 5:24 PM
    09WhiteTaco4x4
    09WhiteTaco4x4 [OP] Well-Known Member
    Washington
    2009 4x4 TRD Off-Road DC
    Removed mud flaps, Borla cat-back exhaust, AFE Pro-Dry S air filter
    What are the benefits of a coilover setup as opposed to just getting new shocks (e.g. 5100's)? I'm trying to decide if they're worth the extra money. I definitely want to level the truck and I can achieve that with just the shocks, so what extra benefits do the coilovers give besides just looking better?
    Since I would plan on setting the shocks to the 1.5" (or 1.75" setting, whatever the second-highest setting is), would I need new uca's? Has anyone had any issues with their cv's at this setting? I'm just trying to gather as much information as I can before my purchase. Thanks!
    P.S. I know these subjects are discussed a lot, but I've read a lot of different things in different posts from different dates. I just wanted to get a focused, recent consensus. Sorry if I offend the "search-nazis"!
  2. Jul 27, 2009 at 5:43 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    At 1.75 lift..No,you wouldn't need uca's. After the install,get an alignment and call it a day.Your cv's will be fine at that setting.:)
  3. Jul 27, 2009 at 5:45 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Most coilovers allow height adjustment without removing the coilover. With 5100s you have to remove the shock & spring to adjust the height.
    I have 5100s at 1.75 and no problems with stock UCA and no diff drop (CV angles are good).
    Some people have their 5100s at 2.5 and still get good alignment with stock UCA. At 2.5 I would recommend a diff drop.
  4. Jul 27, 2009 at 5:57 PM
    09WhiteTaco4x4
    Washington
    Thanks for replies!!
    Any other benefits of the coilover besides adjustments? Do they give a better ride? Are they a more capable setup for off-roading? Once again, thanks!
  5. Jul 27, 2009 at 6:05 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    They are rebuildable and adjustable. Some nice ones like fox have the knob setting to adjust the firmness by hand. But those are pricey. If you dont do a lot of offroading the biilys are sufficient. But if you have the money and want to get a pair then do it.
  6. Jul 27, 2009 at 7:22 PM
    Jpf8653
    Jpf8653 Well-Known Member
    Justin
    Baton Rouge,LA
    Revtek 3" lift, Tinted Windows Wheels n' Tires Door Sill Protectors Rockford fosgate P3 shallow w/ alpine mono 500 amp in a MR MARV PORTED box Weathertech floor liner Rear TSB Pioneer 3200BT Double Din touch screen
    So i thought i understood everything about lifting but i think im not there yet. Correct me if im wrong but im reading that u can buy the 5100 shocks and they adjust. Knew that! Didnt know it would lift a truck though, how?
    If this is correct could i use say 5100 shocks with a spacer kit to lift more?
  7. Jul 27, 2009 at 7:24 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    5100s have a moveable lower collar...To obtain lift you move the collar higher on the shock body, which in turn puts pressure on the spring more and that creates the lift you need.
    Mixing spacer lifts and 5100s is NOT recommended....
  8. Jul 27, 2009 at 7:29 PM
    Jpf8653
    Justin
    Baton Rouge,LA
    Thank you for the info!
  9. Jul 27, 2009 at 7:35 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Quite welcome!!
  10. Jul 27, 2009 at 10:33 PM
    09WhiteTaco4x4
    Washington
    Are the 5100's the same shocks that come with the Toytec Coilover kit? I read on the Lift Sticky thread that the 5100's are not a good match for aftermarket coils. Are they referring to something like OME coils?
    It sounds like the 5100's all around with the front set to a 1.75" lift should be adequate unless someone can provide a convincing argument as to why the coilover's are worth the extra money. I don't do a lot of hard-core off-roading. I would love to do more but I since I moved up here to WA, I haven't found a wheeling group. :(
    Thanks for the info. guys. :)
  11. Jul 27, 2009 at 10:35 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Another option would be the OME lift. Comes with coils and new shocks. So u get your lift from the coils rather than preloading the lift. Only thing is its not adjustable. Its what I have and many others. We love it. :)
  12. Jul 27, 2009 at 10:45 PM
    rpparkster
    rpparkster Well-Known Member
    Roger
    Long Beach, CA
    2009 Tacoma TRD 4X4
    TRD FJ Wheels, 285 GY DuraTrac's, Fox 2.5 C/O w/ Res, TC UCA's, Demello Sliders,AllPro 3" Leaf Pack, Walker Evans 2.0 Adj. RR, AllPro Front Bumper & IFS Skid, Timbren Bump Stops, Leather
    Agreed! You'll be happy with the ride on-road, but it all goes back to the question of what do you want out of your truck? IF you're looking to just lift it without taking it offroad OR Wheeling it, then there are different answers.
  13. Jul 28, 2009 at 4:03 AM
    Ridingontrd
    Richard
    Laughlin,N.V
    Starting from the top:Yes,The ToyTec coilovers use the 5100's.(this is what i'm running now)Yes,You could use the OME coils.
    But...the OME shocks were designed just for those coils.(meaning they would ride better)And as said above,they're not adjustable.
    If all you're looking for is a mild lift..Then Yes,1.75 (this is where i started at) would do the trick.At that setting the ride was like night & day.Way better then stock.You could get the stage 1 kit from ToyTec & upgrade/lift it more.This would depend on how you'll use your truck.:cool:
  14. Jul 28, 2009 at 5:05 PM
    09WhiteTaco4x4
    Washington
    How many inches is this lift?
  15. Jul 28, 2009 at 5:15 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    3".
  16. Jul 28, 2009 at 5:16 PM
    09WhiteTaco4x4
    Washington
    I'm looking to take it off-road occasionally, but I'm not looking to go rock crawling. It's my daily driver that I plan to take to the mountains and hopefully every now and then find some dirt/mud trails. I live in a hilly area that gets its fair share of snow in the winter, so the 4WD definitely comes in handy during the snow season. I would think a 1.75" lift in front should be more than sufficient for my 4WD needs.
    I'd like to be able to clear 275/70/16 BFG A/T's with the setup. Does anyone know if these tires would rub? Thanks!
