Benefit of leveling kit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bubbleheaddiver, Nov 17, 2018.
  1. Nov 17, 2018 at 9:10 AM
    Bubbleheaddiver
    Bubbleheaddiver [OP] Active Member
    BEN
    2017 SR5 4x4 double cab
    Sorry, but need some clarification.
    What benefit would a leveling kit have? I drive a 17, Taco and have heard mixed opinions on these. I would like some TW advice on this.
    Also, what leveling kits are recommended?
    Thanks
    Bubble
  2. Nov 17, 2018 at 9:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    Mostly looks.
    Before the leveling lift defenders crawl out of the woodwork, we'll add a bit of body clearance for approach angles off road and a touch of tire clearance.
    That's a bit nebulous though, and is more dependent on wheel fitment and tire selection, along with trimming and cab mount chops.
    The only way to get axle line ground clearance is with taller tires.
    beergeek likes this.
  3. Nov 17, 2018 at 9:52 AM
    Bubbleheaddiver
    BEN
    I read it wrong and recant my sarcasm point.
    One of the links he listed, had zero responses and same basic question I had. Thanks guys.
  4. Nov 17, 2018 at 10:00 AM
    Bishop84
    Bishop84 Well-Known Member
    Pro's
    -Looks better, beefier
    -bigger tires fit easier
    -approach angle is better
    -feels bigger and manlier
    -Cheap if using a spacer lift
    Con's
    -Spacers have poor geometry and travel, causing bump stop in the shock
    -offroaders will call you a poser online
    -poor ride with using preload bilstiens and oem springs (there is no disputing this, preload means firm)
    -alignments are hard to set above 2" lift without upper control arms
    I always suggest starting with a level kit if interested and move up to proper full shock lift if desired later on.
  5. Nov 17, 2018 at 10:00 AM
    Massappeals
    Massappeals Guest
    I think the problem with these repeat questions is because it causes more of the same information to be spread out. What I mean is that people on forums like information to be condensed and they mostly do not like repeating themselves twenty times.
  6. Nov 17, 2018 at 11:46 AM
    louie4
    louie4 Injanir
    Lou
    Phoenix, AZ
    2017 Black Tacoma SR5 DCLB
    Bilstein 5100’s all around, OVTune 1.05
    I think I'm going to get one for looks and looks only. I don't see much other benefit IMO.
  7. Nov 17, 2018 at 11:53 AM
    notanexpert
    notanexpert Well-Known Member
    Golden, CO
    18 MT TRD pro
    Aside from looks, which are subjective, one of the key benefits of a leveling kit occurs if you have imbalanced the stock suspension, and need a relatively cheap way to re-balance it. One example would be putting on a relatively heavy front bumper with a large winch and several light bars and so forth. The added weight may cause the front suspension to sag. This sag could be eliminated using a leveling kit.
    Keep in mind i'm talking about a really heavy front bumper, and if you're planning on something like that it would probably be better do do a complete suspension overhaul.
  8. Nov 17, 2018 at 11:56 AM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    You can always level your truck with good suspension and then have all the pros of a better performing truck without the negatives of hockey puck spacers.
    Spacers are the padded bra of truck suspension. I understand that for a lot of people they work just fine though.
    tcjacado likes this.
  9. Nov 17, 2018 at 5:19 PM
    Gritz N' Gravy
    Gritz N' Gravy Well-Known Member
    Gilbert, Arizona
    2017 Quicksand MT TRD Off Road
    Can you elaborate on the poor geometry? How would it affect handling?
    I lifted my 3rd gen with 5100's set to the highest notch and like the ride after, so preload wasn't an issue for me.
    I want to level out my 1st gen (about 1" or so in front) and since it's a 100% road driven work truck, I was hoping to save money and just go with spacers.
  10. Nov 17, 2018 at 7:06 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    ]I'm set on the 4th setting on my Bilstein 5100s with factory coils and it rides, handles and absorbes bumps better than my factory Sport suspension. Don't believe this bullshit that it will rides stiff and like complete ass. I here to tell you mine rides night and day better than stock. Put some Bilstein shocks and a one inch block in the rear, it will sit nice, ride great, good to go off roading and won't break the bank. Also a spacer lift isn't all the bad, check out low range 3/1 leveling kit.
    elkiny and tacofish like this.
  11. Nov 17, 2018 at 7:23 PM
    Realoldfatguy
    Realoldfatguy Well-Known Member
    Bob
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    RokBlokz Rally Flaps Toyota running boards
    I’m never on level ground so I doubt a leveling kit would do me any good.
    helix66 likes this.
  12. Nov 17, 2018 at 10:01 PM
    Motor Magoo
    Motor Magoo Member
    2017 Tacoma
    Bilstein level kit, 285/75/16 KM3, Pelfreybuilt sliders, are shell
    I did the same leveling kit 5100 Bilstiens at 2.5 inches, 1 inch block rear. On TRD Off road manuel. Did excellent going up to Calcite Mine Anza Borrego. Problem is if your caring a load. Stock rear leaf springs are garbage. Packed camping gear for 4 and bottomed out rather easily. Just got old man emu heavy today. Need to break in but very nice. I will eventually beef up front coils too 500# for peace of mind when I do add winch and light bars. Thinking on getting Southern Style Slim Line with bull bar. Future winch will be waterproof 9000#. Running KM3 285/75/16 occasional rubbing on UCA , not much at all. Not satisfied what I've seen to replace stock UCA so still doing my homework. I agree with Bishop84, start with a leveling kit, get out there and find out what fits your needs. Good luck!
  13. Nov 18, 2018 at 12:35 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    It's a pickup truck made to carry a load , put shit in the bed and it'll be level.
    tallpilot and Zion like this.
  14. Dec 27, 2018 at 4:36 PM
    VaToy
    Parts Unknown
    I put about 700 lbs without an issue.
  15. Dec 27, 2018 at 7:30 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    The teraflex leveling kit seems a lot better than many other shock upgrades.
