Belts recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hektor, Dec 11, 2019.
  1. Dec 11, 2019 at 3:13 PM
    Hektor
    Hektor [OP] Well-Known Member
    Texas
    04 Tacoma 4x4 TRD DC v6
    Hi guys, I'm gonna have my friend change the belts for the 2004 Tacoma v6. Which belts do you recommend? Just the 3 belts , not the timing belt. I can get band 3 kit from Amazon at around 28 bucks. Should I get the oem from the dealer??
  2. Dec 11, 2019 at 4:00 PM
    ryans4x4
    ryans4x4 Well-Known Member
    1998 Tacoma ECSB 5VZ 5MT
    OEM only
  3. Dec 11, 2019 at 4:06 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    My truck has had Mitsuboshi Belts for as long as I can remember without issue. I don't think accessory belts are something you should absolutely get OEM for, brands like Continental or Denso are fine. Timing belt is another story, I'd only use OEM for that.
  4. Dec 11, 2019 at 4:08 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    I agree. For belts, you'll be fine with what your local autopart store has. Only when it comes to timing belt an waterpump is when you should absolutely consider OEM.
  5. Dec 11, 2019 at 4:12 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I always use Dayco or Gates for all my belt needs. More so Dayco if they have it in stock since its usa made and high quality
    badone likes this.
  6. Dec 11, 2019 at 4:13 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Gates
  7. Dec 11, 2019 at 4:17 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    When did you do the timing belt last? If youre gonna do the tbelt, then do the water pump, cam seals, crank seal, tstat, idler pulleys, tensioner pulley and tensioner. everything that’s there..
  8. Dec 11, 2019 at 4:31 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Cheap autoparts store Gates.
  9. Dec 11, 2019 at 4:35 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Bando, Dayco, and Gates are all makers of OE belts for different car makers. You should be able to trust that they are quality
  10. Dec 11, 2019 at 4:54 PM
    Hektor
    Texas
    2016, I also did the belts back then, but I’m getting a chirping sound at start up in the mornings. So I’m gonna replace them since my friends is gonna do them while changing the power steering fluid. He’s only charging me a case or beer anyways
    cruiserguy likes this.
  11. Dec 11, 2019 at 4:56 PM
    cruiserguy
    Elijah
    SEKS
    Prolly one of the belts just a lil bit loose. A lil snuggy snugging of the belt would likely take care of it, if the belts are that new.
  12. Dec 11, 2019 at 5:28 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I carried Gates and Dayco in my auto parts stores over the years, you can't go wrong with either one. Most important don't over tighten them as it's a leading cause of premature water pump, alternator and P/S pump bearing/seal failure.
    CS_AR and JC15Taco like this.
  13. Dec 11, 2019 at 5:40 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Area51Runner and Markcal like this.
  14. Dec 11, 2019 at 9:26 PM
    Hektor
    Texas
    Lol, he’s a Toyota mechanic
  15. Dec 11, 2019 at 10:25 PM
    Timmah!
    TIM
    That's a great friend to have, but how does that help you learn? I realize wrenching isn't for everyone, but if you're at all interested, you should take on the challenge. Maybe use your friend to help you but you turn the wrenches and gain experience. The sense of accomplishment of doing your own work is pretty cool and I know most people who do their own wrenching probably agree with me. Some people are reluctant DIY auto mechanics and are doing it just out of shear necessity because they don't have the money to pay a shop to keep their rig on the road. I'm obviously in the camp that looks forward to turning wrenches because I like to learn, I enjoy the challenge and I love the sense of accomplishment when the job is done.
    TWJLee likes this.
  16. Dec 11, 2019 at 10:28 PM
    Hektor
    Texas
    It’s just that I’m paranoid and I don’t want to over tighten the belts. I heard that it would lead to more issues.
  17. Dec 12, 2019 at 1:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Texas should not be to bad here in the great liquid brine belt.
    I ended up needing to replace all the adjuster hardware as even after liberal application of Kroil they all started to twist .
    A short easy job turned into a 3 day project I will learn at some point don`t do these things in front of the garage door outside.
