Belt tensioner replacement DIY
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gsingh, Jul 26, 2020.
  1. Jul 26, 2020 at 3:36 PM
    gsingh
    gsingh [OP] Well-Known Member
    G
    2016 Toyota Tacoma TRD Sport
    2016 Tacoma Sport 4x4 3.5.
    Here are the tools I used.
    I had a rattle for a while. Every time I turned lock to lock or had the ac on. Finally traced it down to the belt tensioner. Didn't see a DIY, so I figured id make one.
    Disconnected the battery and moved it out of the way. Turned tensioner in counter close wise and put a pin in it to lock it.
    Need to remove two 14 mm bolts from front of tensioner and one from the side. Side one goes through the ac compressor and is a nut on a stud. HIGHLY RECOMMEND HAVING A E TORX AT THIS POINT. Makes taking the stud out much easier.
    I didn't have any at the house so i ended up removing the alternator. Took me about 3-4 hours to do this with out a lift and middle of the day. Hopefully this helps out.
    Removed the alt and double nutted the stud, so I could take it off.
    There are 2 bolts in front of the alternator 1 long and 1 short. There is also a thing bolt from behind. very difficult to see, I took it off by feeling and it was a PITA.
    Aftermarket belt if any one needs it.
    Torque specs and Belt diagram
    Here is the final product. I also replaced the upper pulley as it had a lot of play in it and the bearing was noisy.
    Any suggestions and/or tips and tricks, please share on here.
    stealthmode, helix66, SR-71A and 14 others like this.
  2. Jul 26, 2020 at 3:43 PM
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    how many miles were on your truck when you did this,
    BlackTRD4Me likes this.
  3. Jul 27, 2020 at 3:46 AM
    gsingh
    G
    Around 115-122k.
    3r3Taco and b3itz like this.
  4. Jul 27, 2020 at 4:53 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Good write up
    mquibble likes this.
  5. Jul 27, 2020 at 5:08 AM
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Great job OP and thanks for sharing the diy!!!:thumbsup:
  6. Jul 27, 2020 at 5:29 AM
    Danno 1948
    Dan
    Ocala,Fl.
    thanks
  7. Nov 5, 2020 at 8:20 AM
    basshole
    basshole Well-Known Member
    chicagoland
    2018 OR MT
    I would like to add some info to this thread since not many belt threads pop up.
    The belt number the OP referenced is to long. I'm not saying his diagnosis on the belt tensioner was wrong, but it's possible the tensioner was maxing out/rattling. Proper part numbers listed below
    Bando 7PK2120
    Gates cross reference: 070834
    I would take a Bando belt over Gates any day. I think they are better quality and nearly half the price or lower given the application.
    3JOH22A, Vanski4X4 and tonered like this.
  8. Nov 6, 2020 at 6:13 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    I trust this post because you have a significant amount of snap-on tools.
    Tacosha, tacoman45, mquibble and 5 others like this.
  9. Nov 12, 2020 at 4:42 AM
    gsingh
    G
    All for work man.
    mquibble and twitchhero[QUOTED] like this.
  10. Jan 16, 2023 at 7:24 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Thanks I'm at 188k miles and mines telling me it needs replaced. How much did you spend on parts?
  11. Sep 8, 2023 at 4:28 AM
    Vanski4X4
    Vanski4X4 Member
    Vanski
    Tacoma SR5
    Umbrella Corporation, flood backup lights
    Did you have to take the clutch fan and shroud off in order to gain access? And what about the upper radiator hose?
    Many thanx
  12. Sep 8, 2023 at 4:34 AM
    Vanski4X4
    Vanski4X4 Member
    Vanski
    Tacoma SR5
    Another question,
    They're 3 columns in the torque spec diagram. Which column is the torque spec?
    Thanx
  13. Sep 8, 2023 at 4:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Nope. It slips around without removing anything. I would recommend working from below. Topside was a lot of work.
    That is for replacing the tensioner. You do not need to do that.
    Vanski4X4[QUOTED] likes this.
  14. Sep 8, 2023 at 6:49 AM
    Vanski4X4
    Vanski4X4 Member
    Vanski
    Tacoma SR5
    @tonered
    Thanx so much for that info. I will be replacing the tensioner and so I need to get the torque spec.
  15. Sep 8, 2023 at 6:54 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
    Ah!
    The different values are for different units. Scroll up to the top of that page. If I am correct, ft-lbs are typically the last / third value given.
  16. Dec 2, 2023 at 4:10 PM
    whitetiger
    whitetiger New Member
    Dale
    Appreciate the pictures. I have a 2019 tacoma with 90,000 mi and will be needing to change the 2 idler pulleys and planning on changing the belt tensioner also. I can't find any of the torque specs. I think I have a torx socket for the stud going thru the compressor. Does anyone know what size torx socket I need? Thanks. I just joined the forum.
  17. Mar 26, 2024 at 6:23 AM
    mchabot1987
    mchabot1987 Well-Known Member
    Elizabeth City, NC
    2017 Super White TRD Sport DCLB
    Yes
    Great write up OP. Followed it to a T and went smoothly. E8 Torx Socket FYI.
  18. Apr 2, 2024 at 2:55 PM
    Bananaclipboii
    Bananaclipboii New Member
    Josiah
    18 OR
    She’s on 35s
    Do you still need to take off the alternator if you have the E Torx? I’m doing this tomorrow, my housing snapped while taking tension off during a belt replacement.
  19. Apr 2, 2024 at 3:14 PM
    mchabot1987
    Elizabeth City, NC
    Yes
    No you do not.
  20. Apr 3, 2024 at 9:34 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Great write-up. Is the tensioner failure common? Is the spring the issue or something else? I’ve replaced many tensioner pulleys alone over the years, even one on similar engine (wife’s RX) and was curious as to where the wear is.
