Belt squealing after belt cleaner
Discussion in 'Technical Chat' started by Fisher, Nov 17, 2012.
  1. Nov 17, 2012 at 4:36 PM
    Fisher
    Fisher [OP] Well-Known Member
    Salem, OR
    2007 2.7 SR5
    K&n Drop In, Secondary filter removed, 5k Headlights, 3K fog lights. Vvt-I sticker (plus 15 HP), Magnapack muffler
    So i had a slight squeek when starting up in the mornings from the belt so i used some spray belt cleaner called "belt dressing"
    after sprayed on i started my truck and the belt squealed very loud and didnt stop at all. i fugured there were to much spray so i let it run for 15 min with no let up on the noise. then drove it a good 25 miles and still very loud.
    What could it be?
    btw 07 2.7 I4
  2. Nov 17, 2012 at 5:10 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Worn tensioner? Misaligned power steering pump? Have you checked the belt tension?
  3. Nov 17, 2012 at 5:13 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    belt dressing is a band aid... just replace the serpentine belt
  4. Nov 17, 2012 at 5:14 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I ended up smoking a belt with the spray-on belt dressing on my '69 Camaro.
  5. Nov 17, 2012 at 5:53 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    1969, now that was a year for muscle cars. I had a 1969 SS Chevelle, 396/375hp. Factory chambered exhaust, great car.
  6. Nov 17, 2012 at 5:57 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Belt dressing is for masking the problem. I recommend fixing the problem. Why is the belt squeeling? Stretched so the tensioner is maxed out and isn't tightening it enough? Is it an idler pulley causing the noise?
    Definitely find the issue, and throw that belt dressing in the trash!
  7. Nov 17, 2012 at 5:58 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup... Last year of the 1st Gen Camaro... awesome car, despite the problem with compression oversteer. IMHO, that was the only thing that improved with the '70 redesign.
  8. Nov 17, 2012 at 5:59 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Ditto.
    Bad tensioner, aged belt, or one of the driven devices is running "tight".
  9. Nov 17, 2012 at 8:11 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never spray anything on belts.
    If they squeel, you need to check/tighten the belt. If that doesn't work, take the belts off and check for bad bearings.
    Was it cleaner or belt dressing? Two totally different things.
    Where I work, cans that are labeled as belt dressing are a nasty sticky material that will gum up everything. Cleaners should evaporate ( like Brakleen).
  10. Nov 17, 2012 at 10:07 PM
    KenLyns
    Belly of the Beast
    What the hell is belt dressing meant to do anyway, to make the belts shiny?
  11. Nov 17, 2012 at 10:10 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If belts are squealing, it is indicating there is a problem weather it be a stretched belt or a worn tensioner, in either case you need to properly identify and correct the issue.
  12. Nov 18, 2012 at 1:00 AM
    Fisher
    Salem, OR
    2007 2.7 SR5
    Tension was good. i only have 28k miles on the truck i don't feel like i should need a belt yet.
    There was only a small squeek that i could hear at idle sometimes so my uncle tossed me a can of "belt dressing". (which made it squeal constantly.)
    I'm thinking maybe i just put to much on or something because later i put a little water on the belt and it stopped instantly. Came back after another few miles of driving but not as bad. put a few more drops of water and haven't herd the sound since. 100+ miles.
  13. Nov 18, 2012 at 1:06 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Only 28k, but it's a 2007.
    Age has more of an impact on belt life than mileage.
  14. Nov 18, 2012 at 1:12 AM
    Fisher
    Salem, OR
    2007 2.7 SR5
    Bought it from my grandfather who babied it for 5 years at 22k :headbang:
    Do you think the belt it worth replacing than? Not really any signs of wear that i can see.
  15. Nov 18, 2012 at 8:50 AM
    Failure2Comply
    Virginia, USA
    It is a tackifier.
  16. Nov 18, 2012 at 8:52 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    If you replace your belt, get a Good Year Gatorback. They are by far the best belts I have seen, and not heard.
    Frank
  17. Nov 18, 2012 at 8:52 AM
    Failure2Comply
    Virginia, USA
    For a $40.00 investment why take a chance with a five year old belt.
  18. Nov 18, 2012 at 8:56 AM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    Is it possible that it could be an idler pulley? Mine was making a chirping sound before I had to replace it, which at first I thought was the belt. Only really heard it while the truck idled though.
  19. Nov 18, 2012 at 9:00 AM
    Failure2Comply
    Virginia, USA
    That is the belt I prefer. Goodyear and Gates make some of the better belts IMHO.
  20. Nov 18, 2012 at 9:30 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If you put water on the belt and the squeak stopped you need a new belt.
