Belt squeal upon engine start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Logans2001, Jun 18, 2020.
  1. Jun 18, 2020 at 1:18 PM
    Logans2001
    Logans2001 [OP] What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    Just replaced all 3 belts and idler pully and now it’s squeals for a second upon cold starting. It Didn’t do this before. Is that normal or did I tension the belts too tight?
  2. Jun 18, 2020 at 1:23 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Belt is lose. I usually install belts, run the engine for a little while, and then recheck them. My reasoning is because they are stored in the little sleeve they are slightly misshapen so once you install them and run the engine for a bit they loosen up a little.
    wilcam47, StevenP, Madjik_Man and 2 others like this.
  3. Jun 18, 2020 at 1:41 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    yep, belt is loose.
    wilcam47 likes this.
  4. Jun 18, 2020 at 1:47 PM
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    You could go the cheap and not actually fixed route in the meantime while wait on new belts..
    A bit of a bar of soap.. CAREFULLY.. again.. CAREFULLY.. applied to the belts will stop the squealing for some time. Not a fix, but an audible bandaid until you can get it fixed.
    Ps, little soap bar bits go everywhere
    cruiserguy likes this.
  5. Jun 18, 2020 at 1:54 PM
    jbrandt
    Justin
    or just turn your radio up louder
    cruiserguy, wilcam47, Auzea and 2 others like this.
  6. Jun 18, 2020 at 1:54 PM
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    Spoken like a true mechanic
  7. Jun 18, 2020 at 2:07 PM
    Harryhood87
    Harryhood87 Well-Known Member
    Harry
    New England
    2004 Xtra Cab 4x4 Lunar Mist 260k+
    265/75/16, Yak Q towers
    I've got the same squeal. I checked the tension on all belts and the alternator has about 1 inch of give while rest are 1/2inch or less. I gotta get In there and tighten it. I just had the belts replaced as well.
    Currygoat, cruiserguy and wilcam47 like this.
  8. Jun 18, 2020 at 2:20 PM
    StevenP
    Steven
    Alta, Ca
    this is much safer :rofl:
  9. Jun 18, 2020 at 2:25 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
  10. Jun 18, 2020 at 3:08 PM
    jbrandt
    Justin
  11. Jun 18, 2020 at 8:55 PM
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    Interesting that you guys say it’s too loose cus if anything I thought they may be too tight. They all seem pretty tight to me is there a way I can judge?
  12. Jun 18, 2020 at 9:04 PM
    osterhagen
    osterhagen Well-Known Member
    Rafe
    Glendale, AZ
    2003 DC v6, MTM, 4x4
    "Totally Stock"
    This can also happen due to a failing fan clutch. I used to have the same squeal at startup, replacing my fan clutch I noticed it was nearly "locked-up" all the time. Meaning I could just barely move it twisting it with my wrist off the vehicle.
    Might be worth going through the checks here in Tim's video or seeing if it takes excessive force to move yours.
    https://www.youtube.com/watch?v=WzhlACxqeqQ
    jbrandt and cruiserguy like this.
  13. Jun 18, 2020 at 10:00 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    If it was tight enough to be so tight that it would squeal, that belt would sing like a guitar string if you plucked it.
    If you really need a way to check, in machine maintenance (not neccesarily automotive) the standard is 1/4" of deflection over 1' of belt span length between pulley centers. .... it would be WAY easier for you to just go out and tighten all the belts tensioners.
  14. Jun 19, 2020 at 3:39 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Oh that's interesting man. I hadn't ever though of the fan clutch being locked up (failed) as a source for a quick squeal but thinking that through in my head, yeah it totally could. It's supposed to 'slip' at first until it heats up and locks up. Very cool
    Thanks man, Learned something new:cool:
  15. Jun 19, 2020 at 3:45 AM
    cruiserguy
    Elijah
    SEKS
    That sounds to be about the same rule of thumb for cars too. I'd say, after belt has been on and run for a few miles, about a 1/2" deflection at center between two pulleys ~ 1' run length.
    It truly does become a feel thing, and logic would tell you its better to be a tad loose than a tad overtight.
    Abeyancer[QUOTED] likes this.
  16. Jun 19, 2020 at 5:57 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    The belt should twist no more than 90° between your fingers midway between pulleys. And it will feel too tight compared to most domestic V belts.
    Grooved flat belts require more tension than V belts.
    cruiserguy and Abeyancer like this.
