Belt squeak or pulley?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaMike37, Jun 11, 2019.
  1. Jun 11, 2019 at 9:41 AM
    TacomaMike37
    TacomaMike37 [OP] Well-Known Member
    13' DCLB MGM
    Hi guys,
    So over the past few weeks my serpentine belt ( or at least I believe it is) has begun to squeak intermittently. My truck only has 28K and its almost 6 years old.
    Yesterday I sprayed the belt with water and the squeak disappeared for about 10 seconds, then it came right back. I spray, it disappears, then comes back.
    I know these belts should go longer then 28k, but maybe the age of the belt is causing it to squeak?
    Should I just replace the belt and see if that alleviates the issue? Or could it possibly be a pulley.
    Thanks for the help,
  2. Jun 11, 2019 at 9:44 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    Probably a pulley, but it won't hurt to change the belt just to see. When you have a bad pulley bearing, spraying water on the belt just causes it to slip and put less load on the pulley. Think about just doing them all with the Gates kit from Rock Auto.
    TacomaMike37[OP] likes this.
  3. Jun 11, 2019 at 9:51 AM
    TacomaMike37
    13' DCLB MGM
    Thanks. Ill check into that.
    Is this something a DIY guy can do over the weekend?
  4. Jun 11, 2019 at 10:17 AM
    ImpulsedComa
    ImpulsedComa Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
  5. Jun 11, 2019 at 10:24 AM
    TacomaMike37
    13' DCLB MGM
  6. Jun 11, 2019 at 10:27 AM
    Harry T
    Harry T My new to me Taco
    Harry
    Lakeland Florida
    2007 Toyota Tacoma DCSB Prerunner
    I just replaced my Alternator Tentioner Pulley and Serpentine Belt. It was not squeaking though. It was whining. I cannot spell as you can see. Sorry
  7. Jun 11, 2019 at 10:31 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Take some brake lube or other similar paste type lube, apply it to a couple spots on the belt with the engine off, start engine and see if noise is gone or if it changes. If it does go away, the belt is the likely culprit. If the noise remains, suspect pulley.
  8. Jun 11, 2019 at 10:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    Even a bar of bath soap will work for this diagnosis.
    My truck is the same age and a bit less miles. I'd be shocked if there was a pulley problem at this point.
    Styx586 and TacomaMike37[OP] like this.
  9. Jun 11, 2019 at 10:35 AM
    TacomaMike37
    13' DCLB MGM
    GOod stuff. Will report back
  10. Jun 11, 2019 at 10:38 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  11. Jun 11, 2019 at 10:47 AM
    TacomaMike37
    13' DCLB MGM
  12. Jun 11, 2019 at 1:11 PM
    ImpulsedComa
    NJ
    Holding off cause it only squeeked those couple days it was raining and humid. FYI, don't put anything on ur serpentine belt (grease or lube) to test it other than spraying it with a little water If the noise goes away immediately it's the belt that is the problem.
