Behind Grill Light Recommendation
Discussion in 'Lighting' started by grubburg, Sep 28, 2018.
  1. Sep 28, 2018 at 1:30 PM
    grubburg
    grubburg [OP] Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I'm getting a grillcraft grill and the mounting bar from BAMF.
    What kinda lights you guys recommend for behind the grill? I want a look like this:
    I don't want to go with a light bar and I don't want to break the bank. If I can, i'd LOVE to stay around $100, but not if it means the lights are crappy. I do some wheeling up in the sierras and a lot of camping/mountain climbing.
    thanks for the recommendation.
    lighting newb...
  2. Sep 28, 2018 at 1:42 PM
    grubburg
    2019 TRD OR MT
    oh I also want to keep the light white color, cause I have the silver HID xenons in my headlamps.
  3. Sep 28, 2018 at 2:06 PM
    Taylor@KC HiLiTES
    Taylor@KC HiLiTES Well-Known Member Vendor
    Taylor
    Arizona
    2010 DCSB TRD OR 4x4
    See build thread
    Here's some options for you! I'm trying to keep it as close to your budget as possible, but also with a larger and whiter light. The first thing you should check though is how deep of a light you can fit in there without issue.
    I think our 8" HID lights would be best for you there, but they're about $100 more than you're wanting to spend. They will however be an insanely bright light for you with a great light output. I would recommend the spread version for best overall coverage. Plus, they're a couple inches larger in diameter so it'll be a bit more like the photo. I know the price is a bit higher than you want, but PM me and I'll hook you up!
    http://www.kchilites.com/light-type/hid/pro-sport-hid/8-pro-sport-hid-pair-pack-system.html
    And if that doesn't suit your needs, we always have halogen lights that are within your budget! The halogens I would recommend are all 6" diameter lights, so just a bit smaller than the HIDs above. They also produce a lot of light! Again, I would recommend spread beam on these, but you can get them in spot if you'd prefer... just depends on what your lighting needs are.
    http://www.kchilites.com/light-type/halogen/halogen-specials/pro-sport-6-driving-lights-kc-606.html
    A light that will perform quite similarly to the halogens I linked just above is the 6" Apollo Pros. The biggest difference is that these will be about 1.5" shallower and potentially easier to bit behind the grille if you don't have enough room for the two options above. I can also help you out on pricing on these!
    http://www.kchilites.com/light-type/halogen/apollo-pro/6-apollo-pro-pair-pack-system.html
    crashnburn80 and DirtJumper14 like this.
  4. Sep 28, 2018 at 2:19 PM
    grubburg
    2019 TRD OR MT
    hmmm those HIDs are sweet!
  5. Sep 28, 2018 at 3:30 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Agreed! And you can mount them upside down or right side up, whichever is easier with that BAMF bar.
  6. Sep 28, 2018 at 4:04 PM
    grubburg
    2019 TRD OR MT
  7. Sep 28, 2018 at 4:41 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Well, I'm going to be giving you a biased answer. But I do think so based on the specifications we provide for light output and how much testing we do with each of our lights. We're a company whose primary objective is providing the best lighting possible. Ours is a slightly larger light with a larger reflector, so the pattern will be more controlled than a smaller reflector. In addition, ours comes as a kit of two and theirs is only one light. So, the price will be essentially the same, and you'll have to do your own wiring combination or deal with having two separate switched for those two lights. Another difference between those Pro Comps and ours is that the ones you linked at least, are flood lights.
    crashnburn80 likes this.
  8. Sep 28, 2018 at 4:52 PM
    grubburg
    2019 TRD OR MT
    sold. you give us a discount here on Tacoma world?!
  9. Sep 28, 2018 at 4:54 PM
    grubburg
    2019 TRD OR MT
    you guys have anyone to trouble shoot me on the install, or am I on my own?
  10. Sep 28, 2018 at 6:35 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    PM me and I'll walk you through it
  11. Sep 28, 2018 at 6:36 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I have no experience with either specific HID product, but I can tell you that KC makes excellent quality products with many decades of experience in off road lighting, far more than other off road lighting companies. You'll notice there is little engineered optics in the Pro Comp lights, if you have a smooth reflector bowl you should have a fluted surface lens to control beam pattern. If you have a smooth lens the reflector itself should be faceted. The Pro Comps have neither, it is just going to put light out there with no real engineered pattern or distance projection, aka short range 'flood'.
    One other thing to consider, HIDs are not an 'instant on' light. You turn them on and they warm up. If you want to be able to flash, or have your lights instant on, halogen will be more effective, but they will not be as bright as HID.
    I believe KC does offer a TW discount. The install should be very straight forward as far as wiring up the lights, I'm sure their support people would help, but you also have the TW community which can be highly effective in helping out our members. :)
    Tsinajinii and Taylor@KC HiLiTES like this.
  12. Sep 29, 2018 at 2:04 PM
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    I currently have a set of PIAA 55w halogens, but I've been trying to free up enough funds for the KC Gravity Pro6. Maybe if I win the lotto I'll be able to swap out the entire front end of aux lights for KC LEDs.
  13. Sep 29, 2018 at 5:50 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Yep! We'd be happy to help will you through the installation but we also include instructions for how to do the wire connections. Overall it'll be very simple. But I'm happy to give you my number for if you need help.
    I also will help out on pricing! Just send me a private message and I'll give you a coupon code to use on our website.
    crashnburn80[QUOTED] likes this.
  14. Sep 29, 2018 at 5:51 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Ohhh la la. Would you do the Pro6 as an overhead bar?
  15. Sep 29, 2018 at 5:54 PM
    Boatbldr
    Boatbldr Well-Known Member
    Florida
    2002 prerunner
    None
    Drain that swamp
  16. Sep 29, 2018 at 5:56 PM
    Boatbldr
    Florida
    2002 prerunner
    None
    Flipping through picks thought u had a FSU thumb nail pic
  17. Sep 29, 2018 at 6:07 PM
    cuda2k
    Jon
    Allen, TX
    My current plans are for the pair, probably spot beam, to replace the PIAAs, but my dream build would include the full bar up top as well mounted to a roof rack, then a couple of the Flex Duals down in my winch bumper. Maybe a cyclone or two in my rear bed rack...
  18. Sep 29, 2018 at 6:12 PM
    Taylor@KC HiLiTES
    Taylor
    Arizona
    See build thread
    Dang that would be quite a sweet setup! I love the cyclones... They'd be great in/under a bed rack.
    cuda2k[QUOTED] likes this.
  19. Sep 29, 2018 at 8:55 PM
    Mack7n
    Mack7n Well-Known Member
    Josey
    Old Town, ME
    2018 Tacoma TRD Sport DCSB 6M BBP/2018 T4R TRD Pro Calvary Blue
    I was going to purchase lights for behind the grill, but once I saw there's going to be a Turbo kit available soon, I need to save that space for the intercooler. :( . Guess I need to find a new location.
    Boatbldr likes this.
