Behavior of the Truck after a thermostat replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by guyofnowords, Jun 11, 2022.
  1. Jun 11, 2022 at 1:10 AM
    guyofnowords
    guyofnowords [OP] Well-Known Member
    So, I just replaced my thermostat, both radiator hoses, radiator cap, and just drained and filled the coolant. I changed the parts and fluid with all OEM.
    When I bleed the air from the system, I did this:
    • Raised the front of the car slightly
    • Used a see-through spilled proof funnel
    • Poured in coolant and squeezed both radiator hoses
    • Once no more coolant could go in, I started the car
    • I bleed the air for 1 hour and 15 minutes
    • During the process, I revved the car between 2000-2500 RPM
    • Air was coming out between the 30 to 50 mins mark
    • I also had the air on low speed, at Hot, and the air recycling was on.
    • After I saw no more air coming out, I decided to stop the car after 1 hour and 15 mins
    So, why I’m I writing this? Well, I’m curious on how the truck behaved before the maintenance vs after the maintenance.
    BEFORE:
    First thing in the morning when I warm up the truck, the truck would only take around 3-5 mins to warm up. By warm up, I mean fully warmed up. The temp needle on the dash would be in the middle of the gauge already. Also, what I noticed was that there would be a lot of water dripping out of the exhaust. It smelt like water. There was no hint of sweetness. I monitored the coolant in the overflow tank and that was still good.
    AFTER:
    Now, after the maintenance was performed, when I warmed up the car it takes about 10 to 20 minutes to fully warm up (where the gauge needle is in the middle). Also, the water dripping out of the exhaust is pretty much gone. There still is some water in the exhaust, but it is not like before where it was dripping onto the floor. There is SIGNIFICANTLY less water.
    My question is: Does this seem normal? The Truck is a 2006 Toyota Tacoma that has 175xxx miles.
  2. Jun 11, 2022 at 2:11 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The thermostats may open at slightly different temps, and I suspect that will change for the new thermostat as it ages. If you have have a code reader with live data, you can confirm the temp readings. Normal cruising temp for mine is 200 degrees.
  3. Jun 11, 2022 at 9:03 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Yup thermostats slightly different
    Maybe 195 instead of 185?
  4. Jun 11, 2022 at 1:49 PM
    guyofnowords
    Okay, that makes sense! The old thermostat was, I assume, the original one from the factory and had never been changed before. Do you have a recommended code reader under $100?
  5. Jun 11, 2022 at 1:50 PM
    guyofnowords
    Good to know! Hopefully I can get my hands on a code reader to confirm my temps
  6. Jun 11, 2022 at 2:04 PM
    Chuy
    Lakeside, CA
    Silver Taco
    But he got oem, wouldn’t they all be same temp rating?
    To OP, any code reader that reads live data should work. I have a fancy pansy Foxwell NT520PRO but it is slow to load up. I usually reach for my cheaper but much faster Autel ML329.
  7. Jun 11, 2022 at 3:59 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
  8. Jun 11, 2022 at 4:16 PM
    guyofnowords
    Can you leave this device plugged in? Or do you have to removed it so that it doesn't drain the battery?
  9. Jun 11, 2022 at 4:22 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    there are countless quality readers all over Amazon for way less than $100. Just search Amazon for OBD2 code reader.
  10. Jun 11, 2022 at 4:55 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    I leave it in all
    The time. Some say it will weaken the OBD connection. But not that I have seen
  11. Jun 11, 2022 at 5:11 PM
    Chuy
    Lakeside, CA
    Silver Taco
    SR-71A likes this.
  12. Jun 11, 2022 at 6:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Did it take that long the 1st you started the truck?
    And if not, was the thermostat replaced with an OEM?
    The reason I ask, is that my dad replaced his thermostat once with and after market fails safe type.
    “Fail safe” in that it sticks open if the coolant gets too hot.
    As luck would have it, the one he bought was defective and it tripped open early.
    Thus, it was open all the time from then on.
  13. Jun 11, 2022 at 6:31 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    What were the ambient temps in your before and after scenarios? That can certainly play into how long it takes to warm up. Though 20 minutes does seems a bit extreme, unless it's very cold out.
  14. Jun 11, 2022 at 7:55 PM
    Waasheem
    Waasheem
    2007 xrunner
    What you did to burp is way far beyond anything I’ve ever done. I’ll do the squeeze the hoses & run the heater for a bit, then make sure the radiator is full, and the reservoir is half full. Drive it, then the next day fill the reservoir to the top line after driving it again. Then maybe check it once more in a week or so.
    If you still have the old thermostat and the box the new once came in, maybe you can see what temperature they are.
    I could be wrong but I think a engine that’s running hotter will have a hotter cat and create more water.
  15. Jun 11, 2022 at 9:08 PM
    guyofnowords
    Yes, it took that long the first time I started it up the day after. It's still taking long, but not too long. Once I drive the truck, it warms up faster.
    Also, just an FYI, because I didn't mention it before, but the car takes long to warm up when I am in park and idling (first start up of the day).
    Yes, the thermostat was replaced with an OEM part. I bought it and picked it up at the Toyota dealership.
    TnShooter[QUOTED] likes this.
  16. Jun 11, 2022 at 9:10 PM
    guyofnowords
    What do you mean by ambient temps?
    Also, it's takes long when I am in park and idling on the first start-up of the day. I've been driving around for almost a week now and the temp gauge seems normal.
  17. Jun 11, 2022 at 9:12 PM
    TnShooter
    Deogee
    STOCK
    Ambient means outside temperature
    As for how long it takes at idle, I don’t know.
    With the price of gas currently , I crank it up, buckle up, and and take off.
    I just don’t do any hard pulls until the engine is up to temp.
  18. Jun 11, 2022 at 9:18 PM
    guyofnowords
    Yeah, I wanted to make sure the air was out of the system as much as possible. I would rev the engine and more air just kept coming out. So, it just made sense to keep on running the car until I didn't see any more air for a while. Plus, I had the fan running on low speed on hot. So, I wanted to make sure the car was warmed up fully.
    I still have the old thermostat, and it does look worn when doing a side by side comparison. Also, the new thermostat didn't come in a box. It came in a small sealed bag with the part number on it.
    SR-71A likes this.
  19. Jun 11, 2022 at 9:25 PM
    guyofnowords
    The temperature was pretty much the same for the before and after scenario. The temp was around 85 degrees (F).
    I hear that!! For testing purposes, I've been idling just to see how the car behaves. So far, I've been driving for a week, and it seems to run fine even when the weather is 100 degrees right now in California.
    SR-71A likes this.
  20. Jun 11, 2022 at 9:44 PM
    TnShooter
    Deogee
    STOCK
    I honestly wouldn’t worry about it. If it’s getting up to temp and the coolant is staying full.
    I say - Drive it.
    Worrying about it taking 10-15 mins to warm up at idle isn’t worth it man.
    I think everything is just fine.
    FWIW, I’d say it takes mine about 3-5 mins to warm up.
    But I literally start the truck, and pull out on to a road that has a 50mph speed limit.
    So, I don’t idle long.
    Jimmyh likes this.
