Beep, Beep, Beep while Braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FishaRnekEd, Sep 18, 2014.
  1. Sep 18, 2014 at 5:01 AM
    FishaRnekEd
    FishaRnekEd [OP] Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    2005 dbl cab, 6spd, sr5, 4x4, 4.0, 80k mi
    stock front end, general spring 4 leaf in back
    aftermarket stereo (shitty job? previous owner)
    cruise control does not work
    fog lights dont work
    clutch cancel button does not work
    Now Im geting the key warning beep while i use the brakes. Maybe half the time. It stops beeping as soon as i stop braking.
    no warning lights on dash at all
    I DO NOT HAVE TRACTION CONTROL so that's not it.
    my door open/key forgotten/seatbelt warning is all the same beeper module. and same beep as the brake/turn signal problem I am having.
  2. Sep 18, 2014 at 5:15 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Mine dies this too, but only when i slam on the breaks
  3. Sep 18, 2014 at 5:28 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I'm thinking that the OP is not talking about the same "beep" as the traction control beeps that go along with braking.
    My guess OP is that you have some serious wrong wiring issues going on. Wish I could tell you where to start. After market radio shouldn't affect your specific issues.
  4. Sep 18, 2014 at 12:40 PM
    FishaRnekEd
    New Orleans, LA
    It is the same key/door open/ put into reverse beep (I don't have traction control)
    more clues- It does it when I step on the brake while the right turn signal is on. even if im at a stop.
    ok, so crossed/frayed wires?
    any idea where to start taking the dash apart?
    does the dash "snap" together or are there fasteners?
  5. Sep 18, 2014 at 12:43 PM
    FishaRnekEd
    New Orleans, LA
    PITA not being able to download a service manual...
  6. Sep 18, 2014 at 1:05 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Does it do it with just the brake on?
    Does it do it when you just have the blinker on but not the brake?
  7. Sep 18, 2014 at 1:50 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    rapid beepbeepbeepbeep is traction control/vsc warning sounds
    ding ding ding is key chime
    slow beeeep beeeep beeeep beeeep is driving without seatbelt clipped
  8. Sep 18, 2014 at 3:09 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    I think we've covered OP does not hear the traction control beep.
    Most of the dash is held together by clips. I've never gone further than the center console and radio myself.
  9. Sep 19, 2014 at 3:52 PM
    FishaRnekEd
    New Orleans, LA
    Blinker on- no beep.
    blinker on and then brake- beep beep beep...
    brake only- no beep
    blinker on, then brake- beep, beep then release brake, beep stops. brake again (blinker still on) beep, beep...
  10. Sep 19, 2014 at 3:53 PM
    FishaRnekEd
    New Orleans, LA
    so, pry it open gently and it will snap out?
  11. Sep 19, 2014 at 5:08 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Yeah, its all clips one way or another I believe. Like I said I've never gone farther than the around the radio. Never had an issue with that. Google search on here about it. Also there is a YouTube video on how the radio comes out, to get you that far.
  12. Sep 20, 2014 at 2:19 AM
    Canufixit
    New England
  13. Sep 20, 2014 at 2:38 AM
    Canufixit
    New England
    1. Do you have an oem or aftermarket trailer harness installed?
    2.) Is this the door ajar alarm or the key reminder alarm??
    Also When beeping does the door ajar light or seatbelt reminder light up on the instrument panel com on as well ??
  14. Sep 20, 2014 at 2:56 AM
    Canufixit
    New England
    Two more thoughts...
    Try this and let me know .... Buckle the passenger's seat belt and see if it still beeps.
    you said "aftermarket stereo (shitty job? previous owner)"
    Perhaps the problem is either with the wiring or possibly the radio is causing a backfeed ??? I'll see if I can find the harness wiring for the radio ... the radio may have a feed wire for the door ajar signal.
    Try seeing if this issue occurs with the Radio both Off and On??
    Hook up harness if you need to rewire ... $6 Amazon
    http://www.amazon.com/gp/product/B000KL37AO?ie=UTF8
  15. Sep 20, 2014 at 3:28 AM
    Canufixit
    New England
    Just FYI
    Approx $6
    AFTERMARKET RADIO / STEREO INSTALLATION WIRE HARNESS -- CONNECTS DIRECTLY INTO VEHICLE HARNESS -- AVOIDS CUTTING INTO CAR HARNESS FOR PROFESSIONAL RESULTS -- (THIS HARNESS IS DESIGNED ONLY FOR STANDARD / NO PREMIUM / NON FACTORY AMPLIFIED SYSTEMS) -- (NOT COMPATIBLE WITH ONSTAR, SYNC, RAP FEATURES OR CAN BUS SYSTEMS - SPECIALTY PREMIUM HARNESSES AVAILABLE) -
    You might be able to use this to re wire the radio ??
    More info here
    http://www.modifiedlife.com/2005-toyota-tacoma-car-radio-installation-guide/
    Still looking for the radio wiring diagram ...
  16. Sep 20, 2014 at 4:49 AM
    Canufixit
    New England
    wiring diagrams
    http://www.autozone.com/autozone/re...al-Wiring-Diagram-2005-1/_/P-0996b43f80378c50
    I'm also looking through the diagrams I have found so far. Please answer the above questions so I can proceed. I also see that the steering wheel radio control wiring and key reminder have a "threshold" voltage settings (i.e. diff voltages mean different things.) So it may be possible is the wiring is screwed up in the radio install, it might also affect the cruise. But lets stay with the beep for now.
  17. Sep 22, 2014 at 4:03 PM
    FishaRnekEd
    New Orleans, LA
    Thanks Everybody! Im about to just open the dash and take a look in a minute...
  18. Sep 22, 2014 at 7:38 PM
    Canufixit
    New England
    OP - Can you answer the questions I posed above ?? I'm currently looking at the combination meter schematics ... This is the board that has the beeper on it. I need the info to track the inputs to the board..
  19. Oct 6, 2014 at 8:28 AM
    FishaRnekEd
    New Orleans, LA
    1. stock trailer wiring (I think)
    2. my door ajar and key reminder are the same noise from the same spot
    Hey, thanks again, I finally took it apart, and here is what is happening.
    http://youtu.be/wLRtQmp6cgk
    im sure the video is better than me describing it.
  20. Oct 6, 2014 at 8:29 AM
    FishaRnekEd
    New Orleans, LA
