Bedliner vs Plastidip for plastic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma13_NC, Jan 12, 2021.
  1. Jan 12, 2021 at 1:24 PM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    If you had to paint ABS plastic, would you use bedliner spray or Plastidip for durability? I can use Plastidip without a primer coat, but does the bedliner need it on plastic? I'm wanting to do but the lower bumper grill that is grayed out looking.
  2. Jan 12, 2021 at 1:26 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Krylon paint for plastics.
  3. Jan 13, 2021 at 8:21 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    Plastidip is in fact often used in applications that are meant to be non-permanent and easily removed (think coloring stock emblems/trim/grilles/wheels and wanting to be able too go back to stock for resale or recoloring later), and I've found that once damage starts, it tends to wear at the damaged edges quickly.
    Plastidip also seems to be harder to touch up without obvious spray marks or borders, as opposed to bedliner which you can often just spray over without very much feathering.
    Regarding bed liner (rattlecan stuff) on plastic parts, I've found that a layer of Krylon Fusion as a base coat/primer makes the bed liner stick much better. It seems to particularly help with limiting impact damage to the bed liner (chunks coming off) in cases where the plastic part deforms under impact but returns to (more or less) its original shape, and also makes it a hell of a lot more resistant to flaking under abrasion.
    As with any surface coating, substrate preparation is KEY, especially on glossy plastics. Clean, dry, de-greased, and pre-scuffed with a brillo pad are the parameters for success with Fusion and plastics, and ambient temperature and humidity are also important. Basically... Follow the directions on the can!
    Tacoma13_NC[OP] likes this.
  4. Jan 13, 2021 at 8:32 AM
    Tacoma13_NC
    Great thanks! I bought a can of satin black Krylon Fusion last night that I was going to use today. I prepped it by scuffing it all up and then wiping it down with rubbing alcohol. I also have a can of spray on bed liner, but I just don't want to mess something up and have to redo everything.
  5. Jan 13, 2021 at 8:36 AM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    I'm not sure what you're painting, but if you're doing it /on/ the truck, be sure to be particularly careful with your masking job. That bedliner can get fine droplets EVERYWHERE and it is a real pain in the ass to get off!
  6. Jan 13, 2021 at 8:39 AM
    Tacoma13_NC
    I'm painting the lower plastic grill which I've taken off the truck. (was a pain in the ass to do too)
    deanosaurus[QUOTED] likes this.
  7. Jan 13, 2021 at 10:39 AM
    Tacoma13_NC
    I've got a few coats of Fusion on it and I think I'll stick with just that. I'm afraid of trying to spray bed liner on top of it and messing it all up. It's got some texture right now due to scuffing up the plastic and it kind of looks cool the way it is.
  8. Jan 13, 2021 at 12:08 PM
    Tacoma13_NC
    Finished product. :thumbsup:
    deanosaurus likes this.
  9. Jan 13, 2021 at 2:55 PM
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    Bedliner.
    1: Sand everything.
    2: Use adhesion promoter (Follow directions)
    3: Spray with Bedliner
    deanosaurus and Tacoma13_NC[OP] like this.
  10. Jan 14, 2021 at 1:46 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Rust oleum bed liner spray sticks very well to plastics i did my old grill(just the center it was gray) with it and it held up really good 305C4DA0-851A-4F92-BEC0-933049B8CEC1.jpg
  11. Jan 14, 2021 at 4:54 AM
    Tacoma13_NC
    It turned out good, same with the guy's post above you. I was about to coat it bed liner on top of the Krylon Fusion, but I spent a lot of time and elbow grease prepping that piece not to mention just getting it off the truck, that I didn't want to mess it up beyond repair. It probably would've been fine, but I didn't want to chance it. I've read nothing but good things about Fusion paint holding up, and with the texturing from the drill attachment, it actually looks like fiberglass now. Maybe down the road I'll get another wild hair and decide to do something different, but for now this works. If I didn't have the light bar mounted behind it, I probably could've masked it all off and painted it while it was on the truck, but I didn't want to risk messing up the light either.
