Bed weight limit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lwszabo, May 17, 2014.
  1. May 17, 2014 at 12:05 PM
    lwszabo
    lwszabo [OP] Well-Known Member
    Concord NC
    2018 SR double cab
    toyota dark satin alloy wheel Tint OEM bed mat
    Don't have an owners manual. Googled and searched but have found everything from 500-2000 pounds! What's the limit we can put in our beds! Truck is a 2000 tacoma sr5 with a 2.4 automatic. Thanks!
  2. May 17, 2014 at 5:20 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Half ton truck, right?
    Sure as heck isn't 2000#.
    Now on the other hand, if it were made in China, it could be 2000#, as it might be a Won Ton....
  3. May 17, 2014 at 5:57 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not exactly.
    Capacity varies by model... 4x4 is 100lbs lower, but these are from a mid-level model and are close enough to apply to any Tacoma:
    Curb weight: 4140
    GVWR: 5500
    GCWR: 8100/11,100
    Payload: 1360
    The payload is 1,360 pounds.
    This includes passengers.
    If you have a doublecab with 4 passengers, you only have only 500-800 left for cargo.
    If you have a doublecab with 4 Americans, you're probably already over gross :D
    That's for a 2nd Gen.
    I'm having trouble finding the specs for the 1st Gen, but your owner's manual will have the numbers.
    Subtract curb weight from Gross weight and that is your payload capacity, including passengers.
  4. May 17, 2014 at 6:32 PM
    lipster
    Northern MN
    License plate frame
    Still, closer to a half ton than to 3/4 ton or Won Ton.
    Who the hell carries a scale around?
  5. May 17, 2014 at 8:41 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You know how much you weigh within 20 pounds.
    You know how much your passengers weigh within 40 pounds.
    Add another hundred or so for tools and the shit that piles up in the various storage areas of our trucks... more if you have armor.
    So now you know about how much you should put in the bed.
    You know how much that concrete or kitty litter weighs.
    No scale needed... just do the math.
  6. May 17, 2014 at 8:43 PM
    xaqori
    xaqori Grammer knotsy
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    ARB lockers and 4.88s front and rear, OME 886s, Dakars, etc., Safari Snorkel, 17"Fuel Revolvers w/ 35x12.50r17 KM2s, fenders cut 3" all around, Pioneer AVH-P4400BH w/ Backup cam, CB/PA (PA Installed), Weathertech Digis, Foglight anytime, AP: front bumper, skids, and pack rack, custom sliders, Warn 9.5XP, dual VIAIR 480Cs with a 2.5gal tank, OTRATTW switches galore, URD y-pipe, RCI skids, LF 240s, etc.
    It can handle more than stated (as per safety factors). But it is a TERRIBLE idea to exceed the stated max - especially long distance.
  7. May 17, 2014 at 8:57 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    True... I probably had 1500+ of concrete in my '03 Tundra.
    But I felt it. The bed was on the bump stops and the front end was "loose"
    Glad I was only going 3 miles.
  8. May 17, 2014 at 9:20 PM
    xaqori
    Zac
    Marietta, Georgia
    '06 4x4 Limo
    Same. I had a ridiculous amount of gravel (either 1300 or 1700lbs, I can't remember) and only drove about a mile and a half. My truck was riding on bumpstops the whole way. And, to add insult to injury, my driveway is so stupidly steep that I had to use 4lo and reverse it up for max gearing...
