Bed Track System
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dalesrn, Jan 12, 2012.
  1. Jan 12, 2012 at 3:56 PM
    dalesrn
    dalesrn [OP] Tacoma TSS
    Dale
    Southeast Louisiana
    2008 Tacoma PreRunner DC with TSS Package
    Borla exhaust system, Sirius Satellite Radio, Chrome package, Trailer Hitch, Clazzio Leather seat covers, TSS badging, Anytime on fog lights mod, Daytime driving lights mod, Dual backseat DVD players w/monitors, 3rd Brake Light "TSS" mod, Bed pocket lights mod, Seat belt chime mod, Bed storage compartment auxillary outlet mod, Shorty antenna, Armor Lid Tonneau Cover, Line of Fire tailgate light
    Has anyone removed the bed track system in the 2005-2008 Tacomas? I see I need a T30 to remove the 5 bolts in the track nearest the cab. Do I need to get between the bed and cab to remove these bolts?
    Also, what has everyone been using to mount things in the track system? I have seen members using bolts, washers, and nuts. Any particular size that anyone has found to work better than others?
  2. Jan 12, 2012 at 4:11 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    I have removed my rail system. There are threads/threaded plate behind the bed, so no concern about removing the screws. I would suggest putting the screws back in after you remove the rail, so you know where they are if you ever want to re-install the rail.
  3. Jan 12, 2012 at 4:13 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I use these nuts to mount stuff to my bed rails. They fit right into the rails
    Link
  4. Jan 12, 2012 at 4:30 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  5. Jan 12, 2012 at 4:34 PM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Eagle River, Alaska
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    x2
  6. Jan 12, 2012 at 4:37 PM
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Should be fairly simple to remove.
  7. Jan 12, 2012 at 4:45 PM
    dalesrn
    Dale
    Southeast Louisiana
    Are these threaded plates welded or mounted to the bed? They are not going to fall off when I start unscrewing, are they?
  8. Jan 12, 2012 at 4:49 PM
    ROGU3 PR3DATOR
    Jake
    Eagle River, Alaska
    No, they are actually set into the bed. At least on the front anyway.
  9. Jan 12, 2012 at 4:50 PM
    dalesrn
    Dale
    Southeast Louisiana
    That looks perfect. Is the link directly to the size you used?
  10. Jan 12, 2012 at 4:52 PM
    dalesrn
    Dale
    Southeast Louisiana
    Thanks. The front is all I worried about. I just didn't want to start unscrewing the bolts and the nuts fall out and me not be able to get my hand between the bed and cab to put them back.
  11. Jan 12, 2012 at 5:00 PM
    StaticFilter
    StaticFilter Well-Known Member
    Cedar Hills, UT
    2008 Blue FJ Cruiser
    Lifted, N-Fab steps, Roof rack light bar, Grill guard, Volant Snorkel (not installed ye)
  12. Jan 12, 2012 at 5:24 PM
    MrGrimm
    Dean
    Wisconsin
    See build page
    I don't remember the size but if you measure the track system, you can order the size you need.
  13. Jan 14, 2012 at 5:57 PM
    DIVERMAN
    DIVERMAN Well-Known Member
    Cullen
    Louisiana
    2012 Pyrite Mica 4x4 TRD O/R SWB
    Tailgate theft prevention, Locking rear window, Blind spot mirrors, Fogs on anytime, Rear diff breather relocated, Bed storage locks, LEDs in/out, Relocated trailer plug(custom!), OEM bed mat, OEM running boards, OEM bed divider, Bed lights, Rev lights, Raptor lights, WeatherTech floor mats and window vents, Extra D-rings, ImMrYo Bracket, UWS low pro black toolbox, Carhartt seat covers,
  14. Jan 14, 2012 at 6:36 PM
    dalesrn
    Dale
    Southeast Louisiana
  15. Jan 14, 2012 at 9:23 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    those are cool, ..just wish they had a zinc-coated ones..
  16. Jan 14, 2012 at 9:38 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
  17. Jan 15, 2012 at 6:37 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  18. Jan 15, 2012 at 6:44 AM
    rubberduckytaco
    rubberduckytaco Well-Known Member
    nicholas
    sumter sc
    09 prerunner dc sb
    running boards, backup camera, yellow fogs, camo interior
    would lowes or tractor supply have these by and chance? if not ill prolly just make them at work lol
  19. Jan 15, 2012 at 8:57 AM
    DIVERMAN
    Cullen
    Louisiana
    ya, i ordered 10, so i don't know if that had anything to do with it. they did offer to over night them for me, on my dime... still don't see what the problem was. in this day and age.
  20. Jan 15, 2012 at 9:02 AM
    huntark03
    huntark03 I'd rather be hunting!
    Maumelle, AR
    2005 Limited Tundra DC 4X4
    Spidertrax Wheel Spacers aFe Pro Dry Drop in Air Filter Weathertech Liners Bilstein 5100s w/ OME 885 coils and ToyTec 1.5" AALs Light Racing UCAs
