Bed Tie Down Anchors - VersaTrax
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by VersaTrax, Feb 22, 2024.
  1. Feb 22, 2024 at 3:16 AM
    VersaTrax
    VersaTrax [OP] Well-Known Member Vendor
    Nicholas
    2019 Toyota Tacoma
    Hey Tacoma World! My name is Nick and I am the owner of VersaTrax - a bed tie down company specifically manufacturing custom bed tie down anchors for the Toyota community.
    We have a exciting new product that we would like to share - OneTrax Bed Anchor.
    VersaTrax - OneTrax Bed Anchors will FIT ANY EXPOSED BED BOLT on Tacoma.
    OneTrax Bed Anchors incorporate a L-series stud fitting anchor directly to the bed floor of your truck.
    OneTrax are CONSTRUCTED OF AIRCRAFT GRADE 7075-T6 ALUMINUM which is substantially stronger than 6061-T6 aluminum found in most aftermarket tie downs today. It is necessary to utilize 7075-T6 in our design as it provides 2x the tensile strength of 6061-T6 allowing for an incrediable Working Load Limit (WLL) of 1000 lb.
    :benchpress:
    Each OneTrax Bed Anchor is HARD COAT ANNODIZED IN BLACK to add a more durable lasting finish that will withstand the elements for the lifetime of your vehicle.
    OneTrax BOLTS DIRECTLY TO THE FRAME OF YOUR TRUCK utilizing the factory bed mounting holes and threads on your frame. This not only provides a quick installation process, but gives you the assurance your cargo is secure.
    INSTALL IS A BREEZE. Simply remove your factory bed bolt and replace it with the VersaTrax - OneTrax Bed Anchor assembly.
    Each OneTrax INCLUDES A SINGLE STUD FITTING PER ASSEMBLY.
    That's it! Oh, and it's GUARANTEED FOR LIFE. If you break it we will send you a replacement for free.
    We are providing a special 10% discount code for Tacoma World. All you need to do is apply the discount at checkout to recieve the discount.
    15% discount code: "TacomaWorld15" :thumbsup:
    Link to our OneTrax product: https://versatrax.com/products/versatrax-onetrax-bed-anchor
    Install Instructions: https://cdn.shopify.com/s/files/1/0...OneTrax_Install_Instructions.pdf?v=1701294703
    Ricardo13x, 4xdog and cementJay like this.
  2. Feb 22, 2024 at 3:51 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Very cool…… a wonderful system. I’ve used these in the aircraft industry for many years.
  3. Feb 22, 2024 at 3:57 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    That’s where I got the inspiration for these tie downs! Can’t beat the L-series track system.
  4. Feb 22, 2024 at 8:25 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Awesome…….ill be ordering a set
    **Order placed
    ***Used them today. I installed in the forward and middle positions. I have TC bed stiffeners at the rear. Strapped in some lumber……darn slick system.
    Once I unloaded, I removed the rings, zip tied all four together and put in the storage compartment under the rear seat.
    VersaTrax[QUOTED][OP] likes this.
  5. Feb 22, 2024 at 9:46 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Hell yeah!
  6. Feb 22, 2024 at 8:43 PM
    TwinTaco31719
    TwinTaco31719 Well-Known Member
    Eric
    Glenbrook, NV
    2023 Lunar Rock LB Sport
    Super cool!
    VersaTrax[OP] likes this.
  7. Feb 26, 2024 at 9:44 AM
    corgimas
    corgimas Well-Known Member
    rob
    North Shore of Massa-who-setts
    0rangeSeventeenShortSportStick
    uhhhh....dog fur?
    Oh, very nice and clean, will those replace these big a$$ bolts?
  8. Feb 26, 2024 at 9:45 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Yes they will!
  9. Feb 29, 2024 at 10:50 AM
    corgimas
    rob
    uhhhh....dog fur?
    ordered! replacing the basic triangle hold downs that are very rusted
    Looking for ward to them
    BTW a note to add to your FAQs: how do they interact if you have a tailgate bed wall bracket system? I know there are a few options of those, but i wonder if they can go over the bed wall support bracket?
    4xdog likes this.
  10. Feb 29, 2024 at 3:00 PM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    We’ll get your order out tomorrow.
    That’s a good question. Honestly, it really depends on the bracket. I have seen some that are flat and some that are v shaped for additional strength. Rule of thumb is if there is a flat area that is 2.25” in diameter around the bed bolt, OneTrax bed anchors should not have an issue being used. Also, keep in mind this will raise the anchor a little higher depending upon the thickness of the bracket.
    corgimas[QUOTED] likes this.
  11. Mar 2, 2024 at 1:20 AM
    Glaese
    Glaese Unknown Member
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    What happened to your d ring system? What you are selling now seems sub par
  12. Mar 2, 2024 at 1:58 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    We have discontinued the d-rings because OneTrax anchors are better in every way. To begin, both anchors share the same load limit of 1000 lb. However, OneTrax is only a fraction of the height of the swivel d-rings when not in use because the tie down point itself (single stud l-series fittings) easily can be removed/installed in less than a second. This gives your the ability to slide objects in your bed and not have them get snagged on the anchor.
    DSRamsey13 likes this.
  13. Mar 2, 2024 at 5:37 AM
    Glaese
    Cris
    Country of Texas
    17 Sandy Taco Ltd
    Makes sense the height of the item is what initially put me off. It appears v2 still barley protrudes above the raised portions of the bed. Any plans to make the product even lower profile?
    corgimas likes this.
  14. Mar 2, 2024 at 5:44 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    For a single stud L-series anchor, OneTrax is as small as it can get. We may look into a swivel d-ring in the future that will match the height of the bed ridges if this is something that is desired. Being that only the round (dome) portion of OneTrax anchors protrude past the highest portion of the bed ridges, it’s not so much of a snagging issue as some may believe.
  15. Mar 5, 2024 at 5:52 AM
    corgimas
    rob
    uhhhh....dog fur?
    I got mine yesterday, thank you! ?These look slicker than I expected, the profile should be pretty level with the bed mat (cut holes in my bed mat for d rings I had put on the bed bolts that these are replacing). looking forward to some nicer weather so I can install
  16. Mar 5, 2024 at 6:37 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Awesome! I’m glad you love the product. I recommend just using a hole saw in the bed mat to make those holes. And you are correct, with the bed mat installed they will essentially be flush.
  17. Mar 5, 2024 at 8:26 AM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Do you plan on making the rail for the 3rd generation Tacoma? Im only seeing a preorder at the moment for the 22+ Tundra
  18. Mar 5, 2024 at 8:34 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    No plans at the moment. Unfortunately, the bed bolts don’t line up in a straight bed ridge slot which makes it difficult to incorporate a rail.
  19. Mar 10, 2024 at 6:39 AM
    McFlysRide
    McFlysRide Well-Known Member
    Maryland
    2017 TRD Sport DC
    6" lift, Fox 2.5 DSC with adjusters(Rear 2.5s on the Rona’ back order) FF headache racks/Modifier&RC Cubes,DBCustoms Matte PC Grill w dual RC Cubes and amber backlit script, Westin Rails,Dropstar 20" 645B with 35.12.50.20 Nitto Trail Grapplers. MESO'd out. Rago bed mounts. Dynamat,JL650s components in all corners with dual JL 10” shallow mounts/custom box. Taco tunes amp for the doors and Monoblock for the subs.
    @VersaTrax Just received mine, in what seems like 24 hours lol. Proper packaging and protective sleeves etc, for shipping. Either way quick review.
    This is one of the best designed and robust system I’ve installed on the taco. Time, weather and heat/vibration cycles will be the true test. But from my initial unboxing and install, the hard coat anchor and finish quality is top notch. I’m surprised there is no pic of the of the bed stud, because that alone would have sold me. Solid grade, not pot metal. The tie down ring assembly snaps into place with zero slop. This whole system screams great R&D and QA.
    I’m simple and appreciate when a company takes the time to put in the legwork before releasing a product. I would’ve gladly paid double for the set of 4 that I purchased. Looking forward to other potential offerings for this platform.
  20. Mar 10, 2024 at 6:46 AM
    VersaTrax
    Nicholas
    2019 Toyota Tacoma
    Thanks for your candid review! We did take our time on this product to ensure it meets our high standards in innovation and quality. Enjoy your new anchors!
