Bed Storage Box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhyNotFab, Oct 18, 2012.
  1. Oct 18, 2012 at 6:10 PM
    WhyNotFab
    WhyNotFab [OP] Well-Known Member
    Ricky
    Florida
    '08 TRD Off Road
    I just installed a soft bed cover, so now I wouldn't mind keeping some sort of waterproof storage box in the front of the bed for all of my larger items that are under the rear seat now.. stuff that would eventually be dirty anyway, straps/rope/tow hitch/etc..
    Looking for ideas on decent boxes that wouldn't take up the entire width of the bed, since I'll have my air tank and compressor in the passenger side corner..
    Any suggestions on boxes that I could bolt down or mod to hook into the rail system, that I could lock up even?
  2. Nov 14, 2012 at 5:46 AM
    JWinTN
    JWinTN Well-Known Member
    E TN
    2012 TRD Off Road
    Ran across this thread trying to research the same thing.
    So . . . anyone?
  3. Nov 14, 2012 at 6:00 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Ammo can mod.
  4. Nov 14, 2012 at 6:01 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
  5. Nov 14, 2012 at 6:07 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I went to Lowes and picked up a Black poly box that fits under my cover. It serves a purpose but when I went to put the long shank locks on the poly snapped. It hasn't been an issue just be careful.
  6. Nov 14, 2012 at 6:08 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
  7. Nov 14, 2012 at 6:21 AM
    JWinTN
    E TN
    2012 TRD Off Road
    I personally am looking for something a little bigger than the Tuffy, although if they weren't quite as pricey, I'd grab one of those too.
    I used to have an extended cab SR5, and the area behind the front seats held all my dog beds—extra coats, blankets, clothes, and whatnot depending on the season. Now I have a double cab for family haulin', and I can't keep all that stuff piled on the back seat. I basically need some type of RubberMaid storage that can be secured to the front of the bed but doesn't take up the whole bed. Almost like half a tool box, just not metal.
    I'll probably go to Lowe's or somewhere and look for one of those chest-type boxes and figure out a way to secure it to the bed rails. I just figured that with all the ingenious folks on TW, someone has likely already come up with a solution.
    What I'd really like to have is a box the width of the bed and about half as deep, that had wheels that ran in the bed rails similar to drawer tracks, that I could roll to the back of the bed to get it out of the way, and then pull it forward when I need to access it.
    Uh-oh, I think wheels are turning in my brain, and now I have a headache.
  8. Nov 14, 2012 at 6:31 AM
    BostonBilly
    Easton
    Mine sits against the cab and is held in place with ratchet strap. I put a lock on it cause in the winter I move it to the gate so if I need to get anything to pull Nissans out of the snow it is close
    DeathLurkZ likes this.
  9. Nov 14, 2012 at 6:33 AM
    JWinTN
    E TN
    2012 TRD Off Road
    Sounds simple enough, and an easy route to go. Thanks for the info.
  10. Nov 14, 2012 at 11:20 AM
    Colefoz
    Colefoz New Member
    Portland area
    Stock 09 SR5 TRD sport
    You can use 120mm ammo cans. A little mod and you can add pad locks to them and bolt them to the bed.
  11. Nov 14, 2012 at 11:24 AM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
  12. Nov 14, 2012 at 3:47 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
  13. Nov 15, 2012 at 10:57 AM
    szetor
    szetor Member
    Randy
    Edmonton, AB
    06 TRD Sport DCLB
  14. Nov 15, 2012 at 11:07 AM
    rondog
    rondog Well-Known Member
    Ronnie
    Escondido/San Diego
    here is what I did for my storage..high quality, water proof, shipped to my door for 250
  15. Nov 15, 2012 at 12:02 PM
    JWinTN
    E TN
    2012 TRD Off Road
    I was at Lowe's today and was looking at the Action Packers. Also looks like you could rig it to the bed rails with some kind of reinforcement for the plastic.
    Do you have a link or a model name for that? I can't seem to find that particular one. Looks like a solid solution.
  16. Nov 15, 2012 at 12:37 PM
    JWinTN
    E TN
    2012 TRD Off Road
    I saw only the 8 gallons ones.
    I just went from a '96 to a '12, and I really wanna attach somethin' to those bed rails. They demand it. :D
  17. Nov 15, 2012 at 3:11 PM
    BrainThump
    BrainThump IT Crowd
    CHS
    2016 TRD Sport
  18. Nov 15, 2012 at 3:16 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
  19. Nov 16, 2012 at 3:43 PM
    rondog
    Ronnie
    Escondido/San Diego
    Here you go: http://www.amazon.com/gp/product/B001V92QC4/ref=oh_details_o00_s00_i00
    Looks like it may have gone up a bit since I got mine. Looks like they have a used one from Amazon for $209. Not sure what the shipping situation would be. Also, when I ordered mine, it took like 3 weeks or something. I guess they build them when you order them.
  20. Nov 16, 2012 at 3:52 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
