Bed Stiffeners - What do they do? Do I need them?
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Jun 26, 2018.
  1. Jun 26, 2018 at 8:19 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    * Patent # D820,180 *
    This is a very common question we get at TOTAL CHAOS. If you're running a camper shell, bed rack w/ RTT, or just putting your truck through serious off-road abuse then you should consider Bed Stiffeners.
    On 2005 and newer Tacoma's the composite bed is very weak. Over time they can fracture or crack causing issues with tailgate alignment and possibly lights. We reinforce the rear bed channels at the tailgate which is ideal for preventing bed flex and avoiding issues that come along with it.
    The TOTAL CHAOS Bed Stiffeners also feature additional tie-down points. Adding a set will give you 6 tie down points and 2 light or whip mounts. *no load ratings are implied
    Constructed of 3/16" steel these are built to last. We finish them in a durable black powder coat and include grade 8 hardware for the install. Are you running TOTAL CHAOS Bed Stiffeners or have questions about them? Post up :thumbsup:
    2005-2015 Tacoma - HERE - $170.83
    #48675
    2016-2018 Tacoma - HERE - $170.83
    #48676
    INSTALL INSTRUCTIONS
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    [​IMG] [​IMG]
    Parker315 and Sk8virt like this.
  2. Jul 10, 2018 at 6:01 PM
    TOTAL CHAOS
    Corona, CA
  3. Jul 11, 2018 at 8:13 AM
    TOTAL CHAOS
    Corona, CA
    We have exciting news regarding the TOTAL CHAOS Bed Stiffeners! These are no longer patent pending ... the patent has been issued :)
    Patent # D820,180
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    HBMurphy and remgu2000 like this.
  4. Aug 6, 2018 at 8:46 AM
    TOTAL CHAOS
    Corona, CA
    NOTES from @82abnmedic
    Installed Total Chaos bed stiffereners just now. Took less than an hour. I installed pass side first because it had less gap with tailgate closed. Pretty straight forward, good directions. Then the drivers side. I noticed 1/4" larger gap on this side. After tightening down the 2 lower bolts, I worked my way up from bottom on new drill holes and bolts. I could see the bed get sucked in as I did this. Huge difference in new gaps. Im confident about installing my new topper next week now. Not to mention, the extra strap points are sweet. Does not interfere with stock bedmat. Easy job, thanks TC. [/QUOTE]
    TacoTim85, Gunshot-6A and Quadabaum like this.
  5. Sep 18, 2018 at 8:55 AM
    TOTAL CHAOS
    Corona, CA
  6. Sep 20, 2018 at 8:49 PM
    dawgspit
    dawgspit Member
    Ben
    Monte Vista, CO
    2010 Timberland Mica 4x4 DCLB
    OME 887 coils, Dakar leafs w/ Bili's 275/75/17 BFG KO2, Level 8 MK6 wheels "Infamous" eBay bumpers
    I am curious what is patented about yours versus the others that are available. I need to get a set but want to know what is different or better about yours. Thanks!
  7. Sep 21, 2018 at 8:22 AM
    PeterMN
    PeterMN Well-Known Member
    Fort Bragg, NC
    2018 ORD DCSB Cement
    @dawgspit Total Chaos Bed Stiffeners extend further vertically and maintain contour with the bed which allows for more contact than other brands such as cali raised. They also have a thinner vertical profile in respect to the bed of the truck which allows for ease of loading with large materials.
    Go with TC, you will be very happy!
  8. Sep 21, 2018 at 8:55 AM
    dawgspit
    dawgspit Member
    Ben
    Monte Vista, CO
    Sounds good! Do they work with the Decked system? Are there any specials going on right now?
  9. Sep 21, 2018 at 11:07 AM
    TOTAL CHAOS
    Corona, CA
    Here is the patent # (D820,180) if you'd like to see exact details on the patent. As stated above, customers choose TOTAL CHAOS Bed Stiffeners over the competition since we offer maximum strength and coverage with minimal bed intrusion. Constructed of 3/16" steel these are built to last
    We also offer additional tie down points and antenna/whip mounts. Adding a set will give you 6 tie down points and 2 light or whip mounts. *no load ratings are implied.
    We have NOT installed a set with the Decked system. I looked at one the other day and the Tundra system appears to have enough clearances. On the Tacoma it will be similar. You might have to shave down a tiny bit of material on the corner of the decked system. We don't offer any discounts or specials, but one of our Authorized Dealers might be doing something.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  10. Sep 26, 2018 at 10:45 AM
    caribe makaira
    Caribbean, Puerto Rico
    Are they Left Side - Right Side specific? Can they be installed with added tie down points towards the rear?(side location flipped)
  11. Sep 26, 2018 at 11:20 AM
    TOTAL CHAOS
    Corona, CA
    These are designed to be installed with the tie downs facing towards the front of the vehicle. They can't be flipped without additional vehicle modifications.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  12. Oct 11, 2018 at 8:44 PM
    Col4bin
    Col4bin Well-Known Member
    Maine
    2018 TRD OR Double Cab
    Wanted to say Ive only ready great things and wanted to give you my money tonight! BUT...tried to "shop" on your site but couldnt find em. so I went to Wheeler's Off Road.....but they wanted 45 dollars to ship it ground. Thats insane! What are my options?
  13. Oct 12, 2018 at 7:29 AM
    TOTAL CHAOS
    Corona, CA
    We are closed today, but please email info@chaosfab.com and we'll get you a shipping quote!
    Or call 951.737.9682 on Monday
    Hours: M-Th 7am to 5:30pm
    CLOSED Fri, Sat, Sun
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Col4bin[QUOTED] likes this.
  14. Oct 12, 2018 at 7:32 AM
    Col4bin
    Maine
  15. Oct 26, 2018 at 1:07 PM
    T.jarvis321
    T.jarvis321 Member
    2017 Cement Tacoma TRD Pro
    DiamondBack SE VooDoo ALUMAX 10” Bed Rack
    Total Chaos -
    Do you all fabricate these per order?
    Can you customize?
    I am only asking because I would like to use your bed stiffeners yet still be able to place my AMP Bed Extender. Can they be made without the Eyelet tabs or keep the top one but without the Middle and Bottom eyelets and perpendicular flange?
    I am just thinking but if you (or any user in TW) have any examples of your product working with a bed extender that would be greatly appreciated.
  16. Oct 26, 2018 at 1:51 PM
    TOTAL CHAOS
    Corona, CA
    These are not built-to-order. Typically, we try to have a few sets in stock and build more when necessary. We can't offer any custom options.
    On the Tundra forum, we had a similar question come up. If you attach these brackets to our Bed Stiffener you should be able to run the bed extender without issues. We haven't confirmed this works 100%, although it looks like a possible solution.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  17. Oct 26, 2018 at 2:15 PM
    T.jarvis321
    T.jarvis321 Member
    Total Chaos, Thank you for your quick response and the suggested part. I will test it out. I will post a picture on this thread of before and after if you would like for examples if any others have same questions.
  18. Oct 26, 2018 at 2:31 PM
    TOTAL CHAOS
    Corona, CA
    For mockup, try attaching them with VHB tape. If it works you can always drill for a more permanent install. It's easier than drilling and finding out they won't work. Pics would be greatly appreciated.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  19. Nov 2, 2018 at 7:20 PM
    TOTAL CHAOS
    Corona, CA
  20. Dec 2, 2018 at 7:51 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm not able to order them from the TC website?
    Just ordered them from lowrangeoffroad.com
