Bed Rail Cleat Alternatives
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kasnerd, May 16, 2014.
  1. May 16, 2014 at 2:17 PM
    kasnerd
    kasnerd [OP] candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    So with the new Leer cap (stupid snugtop: they were jerks when I called and asked why they don't make a midrise for the short beds), it mounts into the bed rails...ok...wait a min...damn lip hangs over and now the cleats can't tighten down. :sigh:
    Are there aftermarket cleats available?? Did a quick search and all I found were a bazillion links to ebay (and tw.com lol) selling the stock ones.
  2. May 16, 2014 at 2:19 PM
    davem311
    davem311 Active Member
    Dave
    Richmond, TX
    2010 4x4. El Taco Blanco.
    3" Pro Comp Lift. Toyo At2 285/70r18. Pro Comp Alloy Rims. TRD Intake. Fogs Anytime Mod. Oil Catch Can. SnugTop Rebel Shell. Weather TEC floor mats. Mirror Mod. Garmin Etrex Hardwire.
    you could pay 80 bucks for four of those, or just go to home depot and spend 8 bucks and make your own. I went and made 8 of them. Just search for home made bed tie downs.
    unless your loaded and are cool with wasting 80 bucks for plastic, then go ahead.
  3. May 16, 2014 at 2:20 PM
    davem311
    Dave
    Richmond, TX
  4. May 16, 2014 at 2:42 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    you can't modify the existing ones to fit? looks like you could.......
  5. May 16, 2014 at 2:51 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
  6. May 16, 2014 at 2:57 PM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
  7. May 16, 2014 at 6:56 PM
    J4m3z420
    J4m3z420 Active Member
    James
    Keystone, CO
    09 DCBS TRD Off-Road V6 4x4
    Front: OME 884x | 90021 | Light Racing UCA’s Rear: CS047R (minus top overload) | 60091 FN Six Shooter 17x8 6-139.7 (20lbs) BFG KO2: LT265 /70 R17 112S C1 RWL (45lbs) ECGS bushing front diff
  8. May 16, 2014 at 6:58 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Mine work on my Leer
  9. May 16, 2014 at 6:59 PM
    OZ-T
    Peter North
    British Columbia
    Is this where I find your posts about both of your Snugtops leaking like a sieve ?
  10. May 16, 2014 at 9:58 PM
    davem311
    Dave
    Richmond, TX
    hey, like i said before just go make your own, and skip every issue....less money, and zero clearance issues. it should be a no brainer, but i guess for some its not....
  11. May 16, 2014 at 10:41 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    Yup, done. Love the fact I can just tighten it down by hand or with a screwdriver through the "eye" instead of rubbing my fingers raw messing around with the stock ones, which are plastic and have a less than optimal design, to put it tw.com friendly language requirements.
