Bed Rail Accessory Mount Tab Question
Discussion in 'Relentless Fabrication' started by Mr.Pink Taco, May 12, 2020.
  1. May 12, 2020 at 4:30 PM
    Mr.Pink Taco
    Mr.Pink Taco [OP] Well-Known Member
    Tim
    Jersey
    2020 TRD Pro Black
    Minor stuff.
    Hey guys, was wondering if your bed rail accessory mount tabs can hold a 102" whip CB antenna with a spring base? I know those antennas move around a lot.
  2. May 12, 2020 at 4:45 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I think our accessory brackets on their own are capable of it, however the tie down rail would likely flex/twist with the antenna movement and that I would be more concerned about over time. Our bed corner tie down bracket would be a much more solid option but it would also require you to purchase and install an OEM front tie down track like the 05-15 Tacomas came with. The tie down essentially reinforces the bed corner and links the front and side rails together for more strength and rigidity.
    Edit: link to corner tie downs (same between tacoma/tundra) https://www.relentlessfabrication.c...oducts/07-tundra-bed-corner-tie-down-brackets
  3. May 12, 2020 at 6:28 PM
    Mr.Pink Taco
    Tim
    Jersey
    2020 TRD Pro Black
    Minor stuff.
    Thanks for the quick response. Might just got with a Firestick antenna to use with these brackets. Looking forward to getting them!!
    Thanks again.
    RelentlessFab[QUOTED] likes this.
  4. Oct 12, 2022 at 5:50 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
    Can I buy bed rail caps ???
  5. Oct 12, 2022 at 5:55 PM
    RelentlessFab
    Eric
    Sparks, NV
    Sorry, we're not producing the 2nd gen aluminum rail caps at the moment
  6. Oct 12, 2022 at 6:18 PM
    killerkeener
    2011 trd 4x4 manual
    None yet
    Pppfffttt....no x-mas card for you this year ...
