Bed rack for roof tent?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by All Beef Taco, May 13, 2010.
  1. May 13, 2010 at 4:26 PM
    All Beef Taco
    All Beef Taco [OP] Well-Known Member
    Joe
    Thornton, CO
    2010 TRD Off-Road DC 4x4
    Rattle canned wheels, Weathertech Floormats, Undercover Tonneau, DIY Hi-Lift jack bed mount, Demello Sliders, ARB Bumper w/ ARB Fogs + anytime fogs mod, IPF 968's, Warn M8000 w/ Amsteel Blue & Billet 4x4 Hawse Fairlead, Rear Leaf TSB, Toytec Adjustable Coilovers and AALs, Rear Bilstein 5100's, BFG MT KM2's, Safari Snorkel, Rear Diff Breather Mod
    I'm looking to get an ARB (or similar) roof top tent and I'd like to mount it over my bed at the same height as the cab. Can anyone recommend any options for this? I've seen it done before but I don't see how such a rack would mount in the bed or where to get one, for that matter.... I know I could go with something totally custom but something off the shelf (if available) would probably be easier on my wallet. Anyone have any ideas?
  2. May 13, 2010 at 4:31 PM
    All Beef Taco
    Joe
    Thornton, CO
    Ah! Thanks!
  3. May 13, 2010 at 4:35 PM
    All Beef Taco
    Joe
    Thornton, CO
  4. Oct 27, 2010 at 9:40 AM
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    Front Runner makes a bed rack called a Bakkie tent mount frame. :D
  5. Oct 27, 2010 at 3:29 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    I would also like to mount a RTT in the bed of my truck but I want to mount it lower in the bed.
  6. Oct 27, 2010 at 3:44 PM
    JonB
    JonB Well-Known Member
    Jon
    Corvallis, MT
    2012 Tacoma
    All-Pro Off Road built "APex1"
    All-Pro sells them for $399, same style as the one on the Baja Taco but made to fit 2nd gens.
  7. Oct 27, 2010 at 3:59 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    I used Thule racks and mounted them to the bed. The tent is slightly lower than the roof line. It keeps the center of gravity down and helps with the fuel mileage.
  8. Oct 27, 2010 at 5:30 PM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    That's what I'm looking for thanks!
  9. Oct 27, 2010 at 6:20 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    That looks like a baja rack
    Link
  10. Oct 28, 2010 at 11:14 AM
    bridaw
    Brian
    I like your setup. Nice and low. Which RTT is that? Do you flip the tent open to the side or rear?
    I could always go with a Thule rack mounted to my cover as a short term solution. I'll just use my broom stick with a hook on the end to grab the action packers from the front of the bed. :)
    I have a Diamond Back SE cover on my truck and it supports 400 pounds. Sort of wish I bought the HD cover that supports 1600 pounds. It seemed overkill at the time and I would have laughed at the idea of mounting a tent on my truck.... I might need to beef up the underside of my panels to handle the weight of a tent + 2-3 adults. If I keep the mounts directly above the sides of the bed I should be OK.
    I've been researching tents and mount options for a few weeks now. I hope to find something off the shelf but I might need something fabricated. I'll mount so it flips open to the rear. I want 4 permanent mount points on the Diamond Back panels. I'll need a permanent mount on the bottom of the tent (roof rack or basket parts maybe) that will mate and lock into the base mounts on my bed cover. The two supports on the rear deck or under the tent will need to allow the RTT to slide backwards a bit so I can open my forward panel -even when the tent is deployed. I was wondering how I could still make use of the front panel of my cover with a tent mounted on top when I saw this AT video showing one of their trailers being opened while the tent is deployed.
  11. Oct 28, 2010 at 7:46 PM
    all.on.black
    Auburn, WA
    It's an Eezi Awn 1400. It opens to the passengers side. I like to use the tail gate as a table and getting stuff in and out of the bed is easier not having the tent there. I can move the tent to open any way I want but I always set it to open to the passengers side. The cover is a retractable aluminum cover. I'm not sure how you will make your cover work with a tent on there but my rack mounts to the bed and the cover mounts to it's own rails so I can have the cover open and the tent up.
    I had the tent mounted on an ARE cover and got tired of lifting it up and down to get stuff out of the bed.
  12. Oct 28, 2010 at 8:06 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    Damn I like this :cool:
  13. Aug 26, 2012 at 3:00 PM
    Rustbucket
    Rustbucket God Bless America
    Garrett
    Bay Area
    06 V6 Access Cab SR5 Manual in Speedway Blue
    Which product from front runner is this exactly, and how much weight can this support?
  14. Aug 26, 2012 at 3:16 PM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    Front Runner Bakkie pickup bedrail load bar system. I'm not sure how much weight it can support. I looked at getting this setup before but they were unavailable at the time. I went with the Thule Xsporter rack instead.
  15. Aug 27, 2012 at 6:12 PM
    Rustbucket
    Garrett
    Bay Area
    Thanks for the quick response I really appreciate it. I'm trying to get a list of future parts together and was tripping out on this a little bit haha
  16. Aug 28, 2012 at 9:52 AM
    allpro
    allpro Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    Just to throw our rack into the mix:
    2005+ Tacomas:
    95-04 Tacoma:
    The APEX Pack Rack mounts onto CNC laser-cut bed rails that are gradually tapered for the exact fit of your truck's bed rails and disperse the weight without collapsing the factory plastic trim. On the 2005+ Tacoma, the Pack Rack simply bolts to the beds existing cargo tie-down system to provide for an easy, no-drill installation.
    The upper tubular structure is made from heavy-duty 1.5 x .120 wall DOM steel tubing. Our modular design allows you to break it down for easy storage when not in use. We also offer the added cargo rack as shown. Long & short bed versions available.
    ddiaz84 likes this.
  17. Aug 28, 2012 at 10:02 AM
    pbcolt
    pbcolt Well-Known Member
    Colton
    San Diego
    2024 F250 Tremor
    FWC Hawk
  18. Aug 28, 2012 at 10:30 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I made mine. Cost about 200 bucks in materials, plus a few days.
    YOTA 209 and zach nm like this.
  19. Aug 28, 2012 at 12:41 PM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    IIRC the Bakkie rack has to be bolted to the bed. The All-Pro racks look good but can't be adjusted.
  20. Aug 28, 2012 at 2:35 PM
    Dmora874
    Dmora874 Well-Known Member
    Derek
    Albuquerque NM
    TRD Off Road
    I have the all pro bed rack and I like it. I am still working on and how to mount the tent to it, (bought the tent used and have no hardware). I am thinking of getting this baja rack, [​IMG], (http://www.bajarack.com/4runner-exp) and then put the tent on top of it.
    Here is the truck for reference:
