Bed Rack for Retrax XR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Baleklocoon, Apr 13, 2021.
  1. Apr 13, 2021 at 12:50 PM
    Baleklocoon
    Baleklocoon [OP] Well-Known Member
    Texas (DFW)
    2019 Tacoma TRD Off-road MT
    I'm in the market for a bed rack that will mount to the T slot rails on my Retrax XR tonneau cover. I found a couple of decent options (links below). Primary use would be to mount a 23zero 62 RTT, and mount some recovery gear to the sides of the rack. I think the UpTop Truss Bed Rack is much more visually appealing. But I do like that the height of the Yakima Overhaul HD is adjustable in case I ever need to change the height (could raise height to be flush with potential future roof rack to carry longer objects like kayaks etc.). PS. The Yakima Overhaul HD does have a sidebar accessory that can be used to mount recovery gear to the sides. Any thoughts or advice? Any other Retrax XR compatible racks anyone else is aware of that I have missed? Thanks for the help.
    https://www.uptopoverland.com/products/truss-tacoma-retrax-bed-rack-2005-2021
    https://www.rackoutfitters.com/yaki...-retrax-xr-series-bed-cover-on-toyota-tundra/
    https://www.rackattack.com/us/truck...fzmQXV4sAFnVYFqYOSBbsxrjbq0DUyucaAjuqEALw_wcB
  2. Apr 13, 2021 at 4:29 PM
    TRD__Chris
    TRD__Chris Well-Known Member
    STL
    2016 Sport
    Sub’d
    I have the Retrax OneMX and I’m debating if I want to swap out the rails for the slotted versions or just go the KB Voodoo adapter route.
  3. Apr 13, 2021 at 4:33 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Baleklocoon[OP] and TRD__Chris like this.
  4. Apr 14, 2021 at 8:38 AM
    Baleklocoon
    Texas (DFW)
    Thanks for the info! I will look into this! When I google searched "tacoma bed rack retrax" this option did not show up. I've only heard good things about Voodoo racks. I'll just have to take some measurements and see if there will be enough clearance for me to still use my tailgate pad for my 29er with dropper post.
  5. Apr 14, 2021 at 8:40 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Go for at least an 18" high rack for that.
  6. Apr 14, 2021 at 8:44 AM
    Baleklocoon
    Texas (DFW)
    Does the use of the modular attachment brackets with the retrax rails reduce the load carrying capacity of the max modular? Or does the 300 pounds dynamic 600 pounds static still apply?
    Seth2197 likes this.
  7. Apr 14, 2021 at 9:36 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    No reduction in load rating, and the cover is still fully functional.
  8. Apr 30, 2021 at 9:07 AM
    WenboLTaco
    WenboLTaco Active Member
    Midwest
    2019 TRD Offroad Calvary Blue
    Diamondback Cover, Custom Roof Rack
    Thanks for the info! What is that water tank you have mounted on the rack?
    [/QUOTE]
  9. Apr 30, 2021 at 9:14 AM
    tomgru
    tomgru Well-Known Member
    Thomas
    PNW
    2021 TRD Pro
    [/QUOTE]
    it's a Waterport.
    They are online... also sometimes available at costco.
