Bed Power outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tviteritto, Dec 30, 2020.
  1. Dec 30, 2020 at 6:46 PM
    tviteritto
    tviteritto [OP] Member
    Tom
    2021 Tacoma
    none
    How can Toyota give you a power outlet that can't run a pancake air compressor. Come on.
    This would be one of the primary uses if needed at a job site. Has anyone found a way to get it to work?
    carverboy and Junkhead like this.
  2. Dec 30, 2020 at 6:50 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
  3. Dec 30, 2020 at 6:51 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I think its rated at around 110v.
    Junkhead likes this.
  4. Dec 30, 2020 at 6:52 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    You’ll need to replace the inverter with a higher power unit (inverter is under center console), and increase the wire gauge from the inverter to the bed plug. (As that’s not up to the task either). Ultimately it’s worthless, you’ll be better off using a decent 12v compressor and running appropriate wire.
  5. Dec 30, 2020 at 6:55 PM
    mutely
  6. Dec 30, 2020 at 6:57 PM
    snickers
    Ford F150 hybrid has a 2K inverter. Didn't know the requirements of a pancake compressor till just looked up a few minutes ago. Don't know what the OP was expecting as the output of the Taco's is clearly specified and on the button activating it.
    High resell value for the Taco goes long way to the aforementioned Ford.
    Jaragon and BSFord like this.
  7. Dec 30, 2020 at 7:02 PM
    tviteritto
    Tom
    2021 Tacoma
    none
    I was just thinking if for example I needed to use my nail gun it would've been nice to be able to run the small compressor. I have a dewalt compressor that runs on the 20v battery but I couldn't use it for my nail gun.
  8. Dec 30, 2020 at 7:06 PM
    tviteritto
    Tom
    2021 Tacoma
    none
  9. Dec 30, 2020 at 7:07 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    So it's more like "Hey you can charge your cellphone/tablet in your pickup bed."
  10. Dec 30, 2020 at 7:07 PM
    tviteritto
    Tom
    2021 Tacoma
    none
    Ugg. Nice idea from toyota if i want to run a toaster :)
  11. Dec 30, 2020 at 7:07 PM
    PinStripes
    PinStripes Well-Known Member
    Oregon
    2018 Cement OR DCLB
    Has enough power for a string of led Christmas lights. That's about the most use I've seen it get. I was wondering about a tiny slow cooker to keep nacho cheese warm... Everyone wants to wheel with the guy who brings warm queso.
  12. Dec 30, 2020 at 7:09 PM
    mutely
    The bed inverter is really only designed to for chargers and such. So you can power a laptop / charge batteries etc, but not much else, Couldn’t even plug a coffee maker into it. But if you could use your battery powered compressor, you could use the Tacoma to charge the battery’s.....;). You can however get 12v compressors that will easily run a nail gun.
    https://www.amazon.com/Puma-Industr...puma+12v+air+compressor&qid=1609384080&sr=8-1
  13. Dec 30, 2020 at 7:14 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Just get a Honda generator.
    hrivera007, Chew, StuckinOhio and 2 others like this.
  14. Dec 30, 2020 at 7:15 PM
    tviteritto
    Tom
    2021 Tacoma
    none
    Thanks for the info. Good to know. Was just hoping to use what i have and avoid buying or start modding LOL. Once you start modding its a endless road. :)
  15. Dec 30, 2020 at 7:16 PM
    mutely
    Honda Ridgeline is a bit big for the bed I believe.:rofl:
  16. Dec 30, 2020 at 7:22 PM
    crbr
    crbr Well-Known Member
    east TN
    18 Sport / 93 Mastercraft Prostar 190
    hrivera007 likes this.
  17. Dec 30, 2020 at 7:45 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Did you mean the 60V batteries? I am not familiar with a 20V version unless you are talking about the inflator? The 60V compressor will do 135PSI 1.2 SCFM at 90PSI. Not sure what the PUMA one will do as far as SCFM, but for the money I would buy the DeWalt personally.
  18. Dec 30, 2020 at 7:46 PM
    Puppypunter
    Johnny
    2019 Black SR
    Also, be aware that alot of things like compressors pull alot more amps at start up than running, so be sure you are reading the specs right.
  19. Dec 30, 2020 at 7:57 PM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Gearheadesw likes this.
  20. Dec 30, 2020 at 8:08 PM
    crbr
    east TN
    Good generators aren't cheap...cheap generators aren't good. Honda is a household brand loyal product in my camp.
    I get your point. :pccoffee:
    Anything that costs over $10 at HF is a hard pass for me. But I do buy one-and-done tools there sometimes to preserve my tool set. And I have (reluctantly) bought the $12 pack of sand paper there.
    :oldglory:
