Bed Molle Comparisons? Pros & cons.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JVL1985, Jan 23, 2020.
  1. Jan 23, 2020 at 10:38 AM
    JVL1985
    JVL1985 [OP] Well-Known Member
    2019 Tacoma Double Cab, short bed,4x4, v6, TRD Off-road
    I searched around a bit on here to find a conversation about the different molle systems but didn't see anything. Wondering what you guys have and if you would recommend one product vs another?
    I've been looking at the CALI RAISED system VS the VICTORY 4X4. I'm open to any other suggestions.
  2. Jan 23, 2020 at 11:46 AM
    ramrod84
    ramrod84 Well-Known Member
    Little Rock, AR
    2020 Tacoma TRD Pro
    I've also been doing a bit of research and there's not a lot of comparison between the two. That being said, both are solid brands and both seem like your typical molle panel system. Maybe it's just how i've been searching, but it seems that more people have the CALI Raised than the Victory.
    I don't think you could go wrong with either one, but i'd also love to hear from others who have similar setups.
  3. Jan 23, 2020 at 11:48 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I've been eying these as well. Me personally, I would stay away from Victory. There's a thread around here about their roof racks and they seem to have a lot of QC issues even after they were "corrected".
  4. Jan 23, 2020 at 12:50 PM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    fonzi42, P8trit, mrbetelman and 6 others like this.
  5. Jan 23, 2020 at 2:10 PM
    xerogs1
    xerogs1 Well-Known Member
    New Mexico
    2019 TRD OR DCSB AT Silver Sky Metallic
    Bartact Seat Covers, Cali Raised LED molle bed system, radio knobs and Subaru Tweeters, OCD interior parts, OEM Exhaust tip, dash cam, hood protector, various theft deterrent items. Still a WIP
    I have the CaliRaised Molle system and use it quite a bit. The only thing I needed to add was some caps over the exposed threaded screws on the forward panels and I used some 3M fastener to attach the left side to the bed since I don't have a cubby on that side (2019 TRD OR). I will probably hard mount the left side but I wanted to leave my options open for a cubby install or my own custom bed mods on that side. I am not an expert installing molle bags and straps so I might be doing it wrong but I end up using my fingers to fish the straps through the holes. Their molle holes are properly de-burred so I don't cut up my fingers. Also you can purchase the front and rear panels separately as well as the front bed panel so there is some level of customization based on your needs. Victory looks like you have to purchase the whole left or right panel but I could be mistaken.
    I can't really speak to the Victory molle panels but I know there was some de-burring issues with their roof rack. I would give their panels a really good inspection before installation just so you don't snag a strap or a finger. I haven't heard of de-burring problems with their molle panels and the roof racks were vendor specific from what I gather from their posts in regards to the issue. It's just something I would check.
    I would watch the installation videos for both systems since they differ. Also the front Victory panel offers some different options for high lift mounting. To me both look like solid options but I do have bias since I have the CaliRaised system. Definitely pull up both websites and do a side by side comparison. I ultimately went with CaliRaised because of quality, cost, and discounts at the time.
  6. Jan 23, 2020 at 2:26 PM
    JVL1985
    Thanks for the pictures and info. Does it work under the BAK BAKFlip MX4 tonneau Cover. I think that cover moves the rails down a bit.
    Edit: Nevermind. I saw on your site that you offer a set that fits the BAK covers.
    SatlyPartiot408 and 6MTPro like this.
  7. Jan 24, 2020 at 12:13 PM
    mrchin
    mrchin Well-Known Member
    2017 Tacoma TRD Pro
    So I bought the Victory 4x4 side panels. Their install video is super nice and explained a lot. The product is 100% perfect and showed up fast and well protected. I personally don't see any QC issues BUT...I am 1 person.
    I jumped on their black friday deal before looking into some of the "how" in regards to the molle panels. I have the rails shifted down an inch due to my XTang Tonneau (just like the pictures on the CalleRaised Bakflip version). That said, I bought some longer torx bolts and am making some shims just to align it nicely. Not a big deal at all just a little bit of puzzle solving for my own specific application.
    I like the Victory version because it goes behind the cleat rail...which arguably you don't need if you have the panels BUT I think it just adds another layer of functionality and aesthetic. The front panels (by the cab) have some cool Hi-Lift mounting holes setup and it seems very modular. I don't think there is that big of a difference between the two ultimately.
    Oh another note, and it may not matter to anyone, but both setups block the pocket (above the side cubbies) that you can use to hold a cross brace for hauling plywood/sheetrock. I really like them so I have also notched my panels out to retain access to those holes. I should have it finally re-assembled in the next week or two and I can snap a few pics if people care.
  8. Jan 24, 2020 at 12:15 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Either look good! I have a a victory bedrack and roof rack. Both have been very solid. I do like Caliraised rear panel better because it covers the whole back portion of the bed.
  9. Jan 24, 2020 at 3:10 PM
    JVL1985
    I'de like to see those pics. Thanks.
    mrbetelman likes this.
  10. Jan 24, 2020 at 4:14 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I don’t really need Molle but I like the idea of lots of tie down points that can be positioned to keep small heavy items secure. Factory locations are either too high or too low )short bed). Are these strong enough for propane tanks, 2-5 gallon fuel or water jugs, loaded cooler etc? Thanks.
  11. Jan 24, 2020 at 4:17 PM
    dpippel
    dpippel Well-Known Member
    Phoenix, AZ
    Super White 2020 TRD Off Road 4WD DCSB A/T
  12. Jan 26, 2020 at 12:39 PM
    dpippel
    Phoenix, AZ
    @CaliRaisedLed, if you get a chance to answer my question I'd really appreciate it.
    CaliRaisedLed likes this.
  13. Jan 27, 2020 at 10:29 AM
    CaliRaisedLed
    Jake
    Texas (DFW)
    Hello,
    With our molle panels, RotoPax sells brackets that you can attach to our panels.
    Thanks,
  14. Jan 27, 2020 at 10:32 AM
    dpippel
    Phoenix, AZ
    Thanks! Appreciate the info.
  15. Jan 27, 2020 at 12:37 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    Did a decent amount of research on this, and the Caliraised ones were the only ones that work with my Bakflip Mx4 cover that I have been able to find.
    shinbo and Yann like this.
  16. Jan 27, 2020 at 3:25 PM
    mrchin
    2017 Tacoma TRD Pro
    The Victory ones go behind the rail. I am looking at the Bakflip Tacoma instructions and it should work as far as i can tell....that said I am not a Victory rep and I am still monkeying around with mine in the garage to make it work with my Extang cover.
  17. Jan 28, 2020 at 8:27 PM
    Nardogg
    Nardogg Well-Known Member
    19 Cement TRD Sport M/T
    Wheels/Tires, Some Meso Stuff, TURD grille. Hoodscoop Light Bar, Can-o-PY
    ive been considering this aslo rago fab molle panels
  18. Jan 30, 2020 at 9:12 AM
    monkeyevil
    monkeyevil Victory 4x4
    Daryl
    Kalamazoo, MI
    As long as the Bakflip can handle .120 of thickness added behind the bed mounting rails, it should be good to go. I haven't installed a Bakflip in the shop, but I assume that is well within the vehicle variances they allow.
    We have had a brand new half a million-dollar laser cutter and new QC procedures and roles in place since late last year and things have been going great. Even before then our tracked product issue rate was in the low single digits, but now it's even lower. The only problem now is getting orders out the door fast enough a record Black Friday rolled into a record December. Grateful for the problem though! :thumbsup:
    As far as the general question. We both make good stuff, and attack the mounting slightly differently. I think you would be happy with either once you figure out your needs. If you have any questions about our product, please dont' hesitate to ask.
    RTweet, DogStar84, JFanaselle and 3 others like this.
  19. Jan 30, 2020 at 9:12 AM
    GreyBaldTaco
    2019 F150 5.0
    You've said that before, and then people were still posting QC issues....
  20. Jan 30, 2020 at 9:18 AM
    monkeyevil
    Daryl
    Kalamazoo, MI
    I didn't say there were no issues, there always will be. All we can do is strive to limit them to the best of our abilities and handle them fairly and professionally when they arise. That thread is a tiny window into what happens here daily in customer service and tech support is all I'm saying.
