Bed Mat Stays
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Texaslaw, May 11, 2018.
  1. May 11, 2018 at 12:33 PM
    Texaslaw
    Texaslaw [OP] Well-Known Member
    2018 Quicksand TRD OffRoad (OVTuned)
    Does anybody have issues with the OEM bed mat flying out? Have any fixes? I just went through a car wash and the drying fans blew it out of the bed. I don't want that to happen when passing a truck.20180511_143117.jpg
  2. May 11, 2018 at 12:37 PM
    batong_23
    batong_23 vincedprince
    SoCal
    2017 white toyota tacoma trd sport
    really?? i would assume those would stay flat on the bed..
  3. May 11, 2018 at 12:40 PM
    white_taco_
    white_taco_ Active Member
    A keg of beer right in the middle should do the trick.
  4. May 11, 2018 at 12:41 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Get a tonneau cover.
  5. May 11, 2018 at 12:41 PM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    I've had that mat in my 07 for 11 years and not once has it ever flown out. That's 106k miles and two hurricanes.
  6. May 11, 2018 at 12:44 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Non-issue. It never moves under normal driving situations.
  7. May 11, 2018 at 12:44 PM
    Texaslaw
    Problem solved! :bananadance:
  8. May 11, 2018 at 12:44 PM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I know there are drain holes in the bed. You could get cotter pin bolts that are thinner so they don't block the hole completely and go from the top of the mat down under the bed and slip the pin in to keep them in place.
    mtip and Norsemanvike like this.
  9. May 11, 2018 at 12:45 PM
    cafereef
    cafereef Well-Known Member
    2017 MGM Tacoma TRD Sport
    TRD Sport Exahust, OEM roof Rack, Predator Pro side steps.
    I had this same issue, wind on the highway caught under the corner and blew it out of the bed. I sold it and picked up a $30 horse trailer mat and cut to fit. that thing weighs probably 50lbs now and doesn't budge.
    RacoonBandit likes this.
  10. May 11, 2018 at 12:46 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    I don't know what kind of OEM mat you have, but mine is super think and weighs quite a bit...
    Perhaps the carwash needs to turn down their dryers.
    specter208, drewhaus and Heepspo like this.
  11. May 11, 2018 at 12:47 PM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    Oh I see you have a short bed. Mine's a long bed. Must be something to do with things that are too complicated for me.
  12. May 11, 2018 at 12:47 PM
    batong_23
    SoCal
    where did you get a horse trailer matt for $30?
  13. May 11, 2018 at 12:52 PM
    tacosurftruck
    tacosurftruck Well-Known Member
    SoCal
    2016 TRD Sport Access Cab 4x4 MT
    No issues with the long bed mat, even going 80 mph plus at the highway.
    specter208 and Heepspo like this.
  14. May 11, 2018 at 12:54 PM
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    2nd recommendation for bolting it down. There’s a write up on here somewhere for it. Should take you about 5-10 minutes and a quick trip to your local hardware store for a bolt, nut & washers
  15. May 11, 2018 at 12:55 PM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Some people put bolts in the drain holes and cut holes in the bed mat, also help prevent theft.
  16. May 11, 2018 at 12:58 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Mine is heavy as hell. I think shipping weight was 60 lbs?
    I drive 80mi of mostly interstate every day passing numerous trucks, never any problems.
  17. May 11, 2018 at 1:05 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  18. May 11, 2018 at 1:10 PM
    white_taco_
    It's only an issue when the car wash dryer blows directly into the bed. Long or short bed, the air pushes underneath the mat because of the raised bumps and the mat goes flying. Good news is, the mat is heavy enough it doesn't fly out of the bed you just have to readjust it once you're out of the car wash.
    specter208 likes this.
  19. May 11, 2018 at 1:12 PM
    necrodiety
    Orlando
    I've only ever done the car wash like 6 times but it's never flown out or even moved. That's the self drive and pull through ones.
  20. May 11, 2018 at 1:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Make sure the sides of the bed mat are tucked under these screw heads on both sides, never had my factory bed mat lift up before.
    airborndad, specter208, mtip and 3 others like this.
