Bed liner spray chipping
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TA 4, Nov 12, 2016.
  1. Nov 12, 2016 at 6:53 PM
    TA 4
    TA 4 [OP] Well-Known Member
    Ontario, Canada
    2015 SSM Taco access 4x4 2.7
    Cruisin offroad bumper, RCI front skid, Bakflip Tonneau Cover, Westin Running Boards, door molding, Blazer Led lights, Bed Lights, DIY Bed/rear cab mats, 3M Clear Bra (Hood and Fenders), Husky front floor mats, re diff relocated, Coverking seat covers
    Hey Everyone,
    Just got my fresh RCI skid back from a local shop from getting painted. They said they prepped it and than sprayed it with bed liner. However the bed liner didnt cure proper and the paint is chipping/flaking off in corners and edges down to the steel.
    Any thoughts or expierence with this? The Bed liner they used was Dupli color. Now looking online looks like they are known to have bad batches and wrecking the bond with the primer. Im going to sand down the weak areas and try something else. On the flat portion of the skid the bed liner doesnt look like bedliner but at least seems stable.
    Will throw some photos up tomorrow
  2. Nov 12, 2016 at 7:23 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Why use bedliner on a skid?
  3. Nov 12, 2016 at 8:35 PM
    TA 4
    Ontario, Canada
    Thought it be a more durable finish than just paint. Was going to go with powder coat but I heard you can really touch it up as good as touching paint up
    In the first photo ive grinded and sanded the paint away. Seems the etching primer did its job mostly except for the corners its as if nothing was ever there. The second is on the backside showing what it was like before.
    What would ya reccommend for putting on the skid?
  4. Nov 12, 2016 at 8:45 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    If you just got it back from the paint shop, why don't you make them fix it?
    t4daddy likes this.
  5. Nov 12, 2016 at 9:06 PM
    TA 4
    Ontario, Canada
    They did try to fix it, they painted it once and the paint ran off as it was water. The second time, they grinded it a bit more and got to the current result. So just going to tackle it myself
    The shop in the summer recoated my steel loght bar with the same product and it came through with flying colors and is durable as heck. This time around with the skid, the rubber and everything else that makes up the bed spray litterally just brushed off.
    Also feeling like just trem clading it, a shop wants 100$ for powdercoat which is a little rich for just coating a skid
  6. Nov 12, 2016 at 9:13 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    The spray can DIY liners like this require good prep and then a lot of curing time for the product to harden. I've seen it soft for 3-4 days when the temperatures are low like this time of the year, and a good week before it's fully cured. In the summer with higher temps it still seems to need 24-48hrs to cure enough to be remotely durable, and another couple days to reach max durability. It's also tricky to lay down, 4-5 light coats are necessary with a bit of dry time between. Go too heavy on a coat or too soon and it will run or bubble. Or if you coat it and come back a few hours later and decide to try another coat.... bad idea also, it then likes to wrinkle up and not lay right.
    The way the finish looks on yours there was too much time between coats, and then not let enough time to cure completely.
  7. Nov 12, 2016 at 9:15 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Was it sandblasted first to clean the surface and give the coating something to bite onto?
  8. Nov 12, 2016 at 9:18 PM
    hoarder23
    Shay
    NJ
    Scratches
    I coat mine with 3M Professional Grade Rubberized Undercoating 03584, lasts longer than other coatings, easy to reapply, found it on sale.
  9. Nov 12, 2016 at 9:37 PM
    TA 4
    Ontario, Canada
    Thanks Rentless Fab for the great info! That might just explain what happened here
    No, it wasn't sand blasted. They said they did sand it before working on it, but no sand blasting. The ecthing primer is great on the flat metal, just not the corners. So after reading around a lot, Im just going to get some more etching primer and use Rostolluem or similiar. Easy touch ups and should hold up to the up and coming salty roads
    Wish I didn't live in the salt capital of Canada, spraying the skid wouldn't be as much of a concern hahaha
