Bed liner on plywood?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Dec 10, 2018.
  1. Dec 10, 2018 at 10:30 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Has anyone painted plywood with bed liner? I made some drawers for my bed, and am considering what coating to use. I may just go with a few coats of poly, but it would be nice to have it blend in with bed liner, but worried it might peel and that it may not do as good a job keeping moisture / water out...
    I have an enclosed bed rack with side doors and an rtt, but no rear door. It is pretty well protected but some water does get into the bed area.
    Truck norris likes this.
  2. Dec 10, 2018 at 10:50 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Are you thinking Line-X, Rhino? If so, I'd just go in and ask them. If you are thinking Walmart stuff, I've had that stuff chip off of itself.
  3. Dec 11, 2018 at 1:19 AM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    i have used the rustoleum bed liner on plywood and it works really well. Make sure to prep your surface really well, sand paper to ruoghen and clean, and make sure to use thick coats.
    Rujack[OP] likes this.
  4. Dec 11, 2018 at 2:33 AM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    It will work fine. We spray things at work on wooden pallets all the time and they hold up forever as long as we don’t destroy them in other ways.
  5. Dec 11, 2018 at 4:23 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Just use sheathing grade plywood. I use a 4x8 sheet trimmed as my bed pad, in florida no topper, no paint
  6. Dec 11, 2018 at 6:43 AM
    Rujack
    What brand are you using?
  7. Dec 11, 2018 at 6:45 AM
    Clearwater Bill
    Billy
    Largo Florida
  8. Dec 11, 2018 at 6:55 AM
    Rujack
    Looks good (the website, on the other hand). Too bad I need it by tomorrow.
  9. Dec 11, 2018 at 6:57 AM
    Rujack
    Does it form a membrane? I need it to seal the boxes to keep them watertight - especially at the joints...
  10. Dec 11, 2018 at 7:01 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    It will seal small cracks fine, but I would still use liquid nails on the seams before I screwed anything together.
  11. Dec 11, 2018 at 7:03 AM
    Rujack
    Too late. I should’ve used something like that. I used titebond.
  12. Dec 11, 2018 at 7:15 AM
    jimbro
    jimbro Well-Known Member
    Jim
    Manoa, Hawaii
    2016 Magnetic Grey DCLB TRD sport
    6” Fabtech lift, Fox reservoir coilovers and shocks, Detroit locker, 5.29 front and rear, 35x12.50x17 Falken AT3W on SCS Ray 10, rock lights, ditch lights, CB
    Line-X is the way to go. Have you seen the videos where they line-x an egg and it never breaks?
  13. Dec 11, 2018 at 7:16 AM
    Rujack
    Nope. Ok I’ll see if I can find some today...
    Edit: just realized you can’t buy line-x
    GreyBaldTaco likes this.
  14. Dec 11, 2018 at 7:17 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I used rustoleum bedliner for my sub box a while ago and it worked great
  15. Dec 11, 2018 at 7:22 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    red blue or green? blue is okay for minor water contact after the glue cures, but red titebond isnt very good with moisture, in my experience. green is similar to blue but longer setup time, if gluing big projects up.
    Silentshredr likes this.
  16. Dec 11, 2018 at 7:24 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    also build your box with big enough tolerances so that you can still operate when they absorb a little bit of water.
  17. Dec 11, 2018 at 7:27 AM
    Rujack
    Red :annoyed:
    Well. We’ll see how it goes I guess. At least this is only a quasi-temporary setup. Just needed something to improve organization for an upcoming trip.
    96BlueTacos likes this.
  18. Dec 11, 2018 at 7:35 AM
    Rujack
    Nothing too fancy. Bashed them out in a day. Need to throw on another drawer face to the wider drawer on the right. No sliders but seems to work good enough - hopefully I can keep the water out so they don’t bind up, among other obvious reasons. I’ll add a drip edge over the drawers and add weather stripping between the faces and end of the boxes.
  19. Dec 11, 2018 at 7:39 AM
    Rujack
    1/4” all around the drawers
  20. Dec 11, 2018 at 7:44 AM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    haha ya it will still work great. Just won't hold up to moisture over time very well. Red is best for interior work. blue is better for something that may see some moisture like cutting boards and wooden bowls and utensils, and wooden boxes in the back of your truck!
    My carpentry advice, (which is admittedly much better and more informed than my mechanic advice) if you are looking to have a protected exterior wood product, you should get some Sikkens CETOL DEK. (https://srdstain.com/sikkens-cetol-dek-finish/) I use this on exterior decks, hand rails, furniture, and other exterior wood products in Grand County CO and all over CO. about 8,000ft elevation on average, intense sun and weather, holds up like a champ.
    Sand down your box well with 80 grit then 120, no need for anything more and apply 2 coats initially. EDIT:(save yourself some time and just do 80grit then wipe down the box with a wet rag, this will "pop the grain" and hide a lot of the 80 grit marks. let it dry and coat)
    Then next year lightly sand it again with 120 and apply one more coat.
    The next year do the same thing, and now you've got years of protection.
    Just make sure too keep up on a re-coat about every 5 years after the first 2 years and you'll have a bullet proof shiny looking box.
    You could stain the box prior to coating. or leave it natural
    Rujack[QUOTED][OP] likes this.
