Bed lined side steps / nerf bars?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frostbyte, Mar 24, 2012.
  1. Mar 24, 2012 at 2:47 AM
    Frostbyte
    Frostbyte [OP] Well-Known Member
    Northern Utah
    18 Super White TRD OR Manual
    SOLD - 03 Black SR5 4x4 TRD OR RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    How many of you guys line-x'd, rhino lined, or herculiner'd your side steps or nerfs? I am looking to get some nfabs, but dont want them to rust, debating for the cost to quality ratio, which is better? Which wont make me slip on them when wet, and fall an extra 6 inches (due to lift) to the ground, thus hurting myself, or making me look retarded and/or cussing in front of children that might be present at the time... :D any input would be great, thanks guys, and gals.
  2. Mar 24, 2012 at 3:18 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Rustoleum spray on bedliner is my favorite. It goes on evenly and dries hard and fast with a rough texture so u wont slip.
  3. Mar 24, 2012 at 7:32 PM
    Frostbyte
    Northern Utah
    have you used this before? is it durable?
  4. Mar 24, 2012 at 9:48 PM
    especk
    Erik
    Redding, CA
    Yes. And yes, it is the most durable DIY bedliner - I have used all of them multiple times
  5. Mar 25, 2012 at 9:40 AM
    Toddjt
    Toddjt Well-Known Member
    Todd
    Greenville, SC
    Red 05 Dblcab V6 Manual SR5
    bull bar and warn winch 2.5" spacer lift wheels and tires
    I was also wondering about this. I planned on using one of the big three (line-x, herculiner, rhino liner) on my nerf bars when I get them too, but I have no idea which I would pick or which would work best. I had the thought that once I did the nerf bars that I might spray/roll it on my fender flares too? idk just a thought..
  6. Mar 25, 2012 at 9:42 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I have been considering doing my factory step rails. Not sure about it sticking to the finish on these though. They are I guess a stainless finish? Can anyone tell me if it would work or not?
  7. Mar 25, 2012 at 10:43 AM
    Tacolover443
    Tacolover443 Well-Known Member
    Kyle
    Haverford, PA
    07 TRD OR DCSB BSP
    Satoshi, color match grill, 2 Hella 500ff's, rear TSB, yellow "Taco", OEM all-weather floor mats, OEM TRD seat covers, Ultra-Gauge, bed linered rear bumper, Plasti-dipped rims, DuraTrac's,
    I did my rear bumper with duplicolor spray on bed liner and couldn't be happier. The stuff is tough and looks good. Easy to spray on and I didn't use primer either. all I did was sand down, wipe down the bumper and spray away. I think I did three costs and it looks like it will last me a while.
  8. Mar 28, 2012 at 8:27 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Thanks to the OP for starting this thread.
    I have Raptor black powder coated nerf bars on my tundra that I put on Oct 2011. This winter, even though it was mild, there are spots of rust starting around the pad and end plugs.
    There is a 10 yr warranty on the bars but to ship them back is a pain plus
    They are used in the Northeast ie salt country so it will just happen again.
    Soooo...how do I do this rustoleum prep thing?
    Do you use an acetone after scuffing them up?
    Do I take the pads off or tape it off seal with like a silicone?
    I have read online that some guys spray the inside with like that foam insulation stuff? That seems extreme, that crap expands :eek:
    How about spraying it inside? (the rustoleum stuff not the goop insulation)
    It also makes them less slippery correct?
    My black powder coated bars are slippery
    Thanks in advance!
  9. Mar 28, 2012 at 8:32 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    Recently got my avid steps line-x'ed :) (Cost me $175) [​IMG]
  10. Mar 28, 2012 at 8:45 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you lightly scuff the finish, the bedliner will adhere. You might want to read the can to see if they recommend a primer or adhesion promotor when applying to bare metal. Bedliner can be used to cover stainless steel though.
    Remove the end caps and step pads, then remove all surface rust by sanding, it will be quite a bit of sanding. Inside the pipe will be difficult for obvious reasons but a wire brush will allow you to rough up the first 8 - 10 inches anyways. Once your surface rust is removed, scuff up the entire surface for good adhesion. I used regular old rubbing alcohol on a lint-free rag as a final prep stage. You probably could use acetone but I'm not sure what it would do to the powdercoat. You don't want to soften the powdercoat since it will be remaining as a substrate. I used bent up coat hangers and hung my light bar from the ceiling rafters in my basement to paint. Use light, even coats, the paint comes out very fast initially and it can be easy to get runs if you apply too thick.
    I covered my light bar with 4 - 5 light coats and sprayed inside the pipe as much as I could. I also used the same prep steps mentioned above as the light bar can powder coated from the factory. 1 winter down so far and the bedliner looks great! I don't use them for stepping but there is a nice texture to the paint, which I'd imagine would be more grippy than powdercoat.
  11. Mar 28, 2012 at 9:07 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Those look awesome!
    Unfortunately my only local spray place won't spray mine not that I could spend that money. My bars were only $150 because everything rusts here.
    Your Avids certainly are very, very nice!!!
    Going to look great on your truck!
    Mike, thanks for outlining the process. I like the rubbing alcohol suggestion & hanging them from the rafters. If the warm weather comes back this is what I will do. Appreciate all the help. :)
  12. Mar 28, 2012 at 9:12 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Same here they've held up great over the winter so far, although this winter was hardly a winter around here...
    OP - save your money and don't bother with Herculiner.
  13. Mar 28, 2012 at 7:23 PM
    kulcat
    kulcat Well-Known Member
    Thomas
    Plano, TX
  14. Mar 28, 2012 at 7:32 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Let's see those installed...
  15. Mar 28, 2012 at 7:54 PM
    neonlazer
    Lafayette, LA
    '23 DCSB 4x4 SR5
  16. Mar 28, 2012 at 8:36 PM
    a89aries
    a89aries Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
    I Line-X'ed mine, never looked back!
  17. Mar 28, 2012 at 10:54 PM
    Frostbyte
    Northern Utah
    :thumbsup:
    I would love to get mine line-x'd, or rhino line'd, but it turns out that working for the local government, keeping people safe, and restoring order when there is chaos doesnt pay for shit ;)
    Im leaning more towards the rustoleum spray liner. After doing some research, reading reviews and spending some time on their website, it looks like rustoleum stands behind most of their products, and seems to be a well rounded company. I think this is the route im going to go, considering its a spray liner, the cost to quality ratio will be really good.
    Thanks for the link, and feedback. Have you put the sand paper stuff on your steps since you coated them? Will it even stick to the coating, or is it not that textured?
    looks good man, i love the way the 12's look, and with steps that have been line-x'd, im jelly.....
  18. Mar 29, 2012 at 4:40 AM
    kulcat
    Thomas
    Plano, TX
    You know, I did not even try. It's not THAT textured like the Line X stuff appears to be. The back of the step pads they come with are really tacky so I would imagine it would hold up well. I honestly don't think you really need them as I get pretty good grip w/o. I will say if I had to put them on , what I would do is measure out where they would go, and then sand down the liner and apply them. That way you get a smooth surface for them.
  19. Mar 31, 2012 at 7:30 AM
    WEZZA83
    WEZZA83 TX Pro
    Wes
    Baltimore
    TX Pro
    Toytec with 5100's 5% Tint
    How much was the light bar to Line-X? Mine arrives Monday and I need to make a decision?
  20. May 22, 2012 at 7:01 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    Stock for now
    Finally got around to spraying my Tundra's Raptor series oval nerf bars w/ bed coating / bedliner material.
    They were flat black powdercoated & after one mild winter scratched, dull & rusty in spots.
    I also broke one of the plastic darts that keeps the step pad in place.
    The end caps would not come off either so everything got sanded/roughed up.
    After prepping the bars by cleaning & sanding & siliconed the plastic edges.
    Used 3M heavy duty double sided tape along with glob of silicone to reattach the end of the step pad.
    I sprayed a light coat of Rustoleum's Rust Inhibitor let dry per instructions.
    Then used 3 light coats of Rustoleum's Bed Coating Spray.
    The light coats ensured no dripping & kept a uniform sandy grippy texture to the bars surface.
    I was real happy with how they turned out & like them better than when new.
    Before:
    Passenger side scratches -
    Driver's side starting to sand, broken pad dart & lots of rust :eek:
    After:
    Texture close ups:
