Bed lights for access cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by specTACOluar, Jan 26, 2021.
  1. Jan 26, 2021 at 5:21 PM
    specTACOluar
    specTACOluar [OP] Well-Known Member
    Eastern Oregon
    As you know, the access cab does not come with bed lights, and does not even have the switch inside. I guess toyota thought that people who wanted the longer bed wouldn't use it at night? Luckily though, you can have oem bed lights for just over $100.
    All the wiring is in place. The switch harness in the cabin is there, and in my 2021, the bed lighting plugs are behind the tail lights.
    I ordered the switch for $66.86 from Village Toyota. Part #84267-0C020
    I ordered the bed lights that fill the blanks near the tail gate for $51.75 from Village Toyota. Part #PT857-35200
    I just installed it. Very easy, all you need is a flat head, 10m, and 20 minutes.
    Inside the cabin, you use the flat head to pop off the switch panel nearest the drivers door. Pop out the horizontal blank and pop in the new switch. I found it easiest to put the flat head between the panel and blank and push the blank out. The harness plug is found just below the switch panel. Make sure that the switch lights up before reinstalling the panel.
    The bed light videos are all over youtube.
    Don't load an access cab in the dark if you don't have to!
  2. Jan 26, 2021 at 5:59 PM
    Tarl_Cabot
    Tarl_Cabot Well-Known Member
    SC
    Gen 1 2000 2x4 2.7 A/C SR5 Gen 3 2021 4x4 3.5 A/C SR
    awsome, thank you for the info and part #s
  3. Jan 26, 2021 at 6:10 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I ordered my '21 TRD OR AC with bed lights.
    Don't like that they're tied in with the rear cab dome light though...
  4. Jan 27, 2021 at 1:42 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    I don't believe that's correct. I have a 2021 TRD Sport AC with the added OEM bed lights. The bed light switch on the dash has no effect on the rear dome light. The only thing the bed light switch controls is .....the bed lights. However, the front dome light switch (on the overhead console) does control the rear dome light. (The rear dome light also has a switch of its own.) Just checked this this morning.
  5. Jan 27, 2021 at 1:50 PM
    trdxtacoma
    trdxtacoma Well-Known Member
    18 Tacoma SR AC
    I know my 18 isn’t pre wired for bed lights. I believe Toyota included the wiring sometime later or possibly on specific trim levels.
    Anyone have more info on this? Specific years, trims, configurations? I don’t need it but I’m sure someone lurking here later will find it helpful.
    NorrinRadd and specter208 like this.
  6. Jan 27, 2021 at 2:26 PM
    CT Yankee
    CT
    Trust me, that IS correct for my truck. The switch on the lower left of the steering controls BOTH the bed lights and the rear cab dome light. I can set it for ON (all the time), DOOR (lights on when unlocked or when the door is opened), or OFF. The rear cab dome light is NOT correlated with the front map lights. There IS a switch on the rear cab dome light, but it's only for ON or OFF. I'd much rather that the rear cab dome light could be synched with the door opening independent of the bed lights.
  7. Jan 27, 2021 at 2:50 PM
    Jkline101
    Jkline101 Well-Known Member
    Josh
    Houston, TX
    2020 Black Tacoma TRD Sport 4x4 DC
    SEMA TRD Pro wheels, Falken Wildpeak AT3 tires, Bakflip MX4 Tonneau, 3D Maxpider Kagu floor mats, TRD Pro skid plate
    I installed the OEM kit on mine. Was debating that and the @mattgecko kit. Talked my dealership down to a decent price and they ordered it overnight for me. With a bed cover, it is still kinda dark towards the front... Shoulda bought Matt's...
  8. Jan 27, 2021 at 3:03 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    Well, that's the way mine is.
    Since both of our trucks are 2021 TRD AC's (yours an OR and mine a Sport, shouldn't matter), the wiring should be the same. The only difference that I can see is that your bed lights were installed at the Port (or at the dealer), while I did the installation myself. Conclusion: whoever did your installation made a mistake. It's possible this could be corrected. Take it back to the dealer.
    BTW, my truck was made in Mexico. Where was yours made?
  9. Jan 27, 2021 at 3:07 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    The '20 and '21 OEM bed lights are LED's, and they are bright. Blindingly so, if you look directly at them.
  10. Jan 27, 2021 at 3:24 PM
    Jkline101
    Josh
    Houston, TX
    I have a 2020. The problem is they are flat and pointing in to each other. I think some years they had angled LEDs. It isn't a huge issue, but I'd like more light up front, and the Mattgecko kits have the strip up there. Huge advantage of the OEM was the ridiculously easy install.
  11. Jan 27, 2021 at 3:31 PM
    sled dog
    sled dog Well-Known Member
    Mine did.
  12. Jan 27, 2021 at 5:02 PM
    CT Yankee
    CT
    Mine was assembled in Guanajuato Mexico.
    Judging from all that I've read on TW about messing with anything electrical on a Taco, I'm fearful of what may happen if the dealer attempts to correct/modify the way it currently works.
  13. Jan 27, 2021 at 5:15 PM
    CT Yankee
    CT
    Or vice versa.
    Does your overhead rear dome light have a 3-position switch (i.e. OFF-DOOR-ON)?
  14. Jan 27, 2021 at 6:14 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    No, it's a 2-position switch -- Door and On. (Someone sitting in the back could turn on the rear dome light independently.) If set to Door, then it's controlled by the front overhead map light switch, which is 3-position. None of this has anything to do with the bed lights.
    BTW, this is covered on page 348 of the owner's manual. This shows the 3-position switch on the front overhead console and the 2-position switch on the rear dome light. However, the manual doesn't mention the interplay between the front and rear switches. You have to find this out by trial and error.
  15. Jan 28, 2021 at 6:49 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    I assume this was a dealer installed option?
  16. Jan 28, 2021 at 7:16 AM
    CT Yankee
    CT
    Mine was either factory or port installed - I suspect factory. It was NOT installed by the dealer.
    zoo truck likes this.
  17. Jan 28, 2021 at 8:00 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    My 2020 sr5 access cab came with bed lights....dealer told me at the time when i place the order a year ago it would have them.
  18. Jan 28, 2021 at 8:33 AM
    CT Yankee
    CT
    Bed lights (in the bed's side panels) or Cargo lights (in the 3rd brake light)?
  19. Jan 28, 2021 at 10:38 AM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    The Access Cab doesn't come with the cargo lights in the 3rd brake light. (Those are found only in the Double Cab.) That's why Access Cabs normally don't have the dash switch. It's added along with the optional bed lights.
    Getting back to the dome light switches, I checked mine again this morning. It turns out that the front overhead console light switch acts as the master switch for both lights. That is, when the front switch is "On," both lights are on, regardless of the rear switch position. Likewise, if the front switch is "Off," both lights are off. Only when the front switch is set to "Door" can the rear light be turned on independently. Again, this has nothing to do with the bed lights.
  20. Jan 28, 2021 at 11:39 AM
    zoo truck
    None
    Its got what appears led lights in the rear bed side panels. Dealer informed me that the sr5 trim package i requested would automatically come with them.
