Bed cover hinges melting?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by axisofoil, Dec 20, 2019.
  1. Dec 20, 2019 at 9:17 PM
    axisofoil
    axisofoil [OP] Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    The ends of the hinge-seals or whatever these are called on my factory tonneau are degrading/melting.
    Any idea what it takes to repair or replace these?
    2016 doublecab shortbed.
  2. Dec 20, 2019 at 9:44 PM
    Beerpayzdabillz
    Beerpayzdabillz Pastryatarian
    Nor Cal
    2016 DCSB 4x4 sport
    full disclosure - I don't. But, maybe looking at them from the bottom side will shed some light.
    I have the same tonneau. Aerospace 303 has kept mine in good shape. Also a 2016.
    axisofoil[OP] likes this.
  3. Dec 20, 2019 at 9:46 PM
    tcjacado
    tcjacado Well-Known Member
    I'd say that hot arizona summers and that seam gets used a lot. But mainly the heat and direct sunlight will do that kind of damage.
    shakerhood and axisofoil[OP] like this.
  4. Dec 21, 2019 at 3:01 AM
    axisofoil
    Gilbert, AZ
    These get doused in 303 monthly.
    AZ Sunlight is a monster.
    For what it's worth, I was more hoping to find a part number than a guide - the things got a bajillion screws and if I remove enough of them it should become clear - but that doesn't do me much good if I can't get reppacement parts.
    treyfive and AkRoaneo like this.
  5. Dec 21, 2019 at 3:04 AM
    axisofoil
    Gilbert, AZ
    Heat and direct sunlight, yes.
    I've probably opened the 2nd seam 50 times in the last 3 years, so 'a lot' is definitely not the case.
    tcjacado[QUOTED] likes this.
  6. Dec 21, 2019 at 5:35 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Maybe gas vapours from a gas can that you store in the bed near the damage??
  7. Dec 21, 2019 at 5:46 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    Go to the stealership. I was looking at a piece for mine 2 weeks ago.
    Beerpayzdabillz likes this.
  8. Dec 21, 2019 at 8:50 AM
    Beerpayzdabillz
    Nor Cal
    2016 DCSB 4x4 sport
    please keep us posted, we're all gonna have that problem at some point.
  9. Dec 21, 2019 at 11:05 AM
    axisofoil
    Gilbert, AZ
    Nope. This happened to ALL of them at about the same time.
    Big tall dave[QUOTED] likes this.
  10. Dec 21, 2019 at 11:14 AM
    Itchyfeet
    Itchyfeet Well-Known Member
  11. Dec 21, 2019 at 12:11 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  12. Sep 10, 2020 at 3:46 PM
    Gdreeves
    Gdreeves New Member
    Arizona
    2024 Limited
    I have experienced the same issue except that mine have further degraded to the point of cracking the entire length of the seal. Mine is also in Arizona and also received regular 303 treatments. The dealership just quoted $1700 to fix. The cover was a $650 option at time of purchase (2016). I am interested in learning if anyone has found a fix other than replacing with an aftermarket cover.
  13. Sep 30, 2020 at 8:12 AM
    axisofoil
    Gilbert, AZ
    The dealer said the seals are available as separate parts...I didn't order them yet. Life got in the way.
  14. Sep 30, 2020 at 10:11 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Please post the part number(s) if you get them.
  15. Sep 30, 2020 at 10:28 AM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    Try some inner tube repair patch and the flex seal!
    GOLIVER0131 likes this.
  16. Nov 13, 2020 at 11:42 AM
    talkie123
    talkie123 Member
    DES2009 and Boghog1 like this.
  17. Nov 13, 2020 at 1:37 PM
    trac
    trac Well-Known Member
    Eek! That looks gnarly!
  18. Nov 13, 2020 at 1:45 PM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    WTF????????????? Something had to be spilled on that. Nasty.
  19. Nov 13, 2020 at 1:50 PM
    Skidog1
    Chicagoland
    That's sun and heat damage in Arizona.
    DES2009 likes this.
  20. Nov 13, 2020 at 1:52 PM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    One of mine is heading in that direction, although currently no where near as bad as the one in the picture. Southeast Louisiana sun, heat, rain, humidity does a number on most anything..
