Bed Cleats
Discussion in '3rd Gen. Tacomas (2016-2023)' started by erwigg, Jul 11, 2022.
  1. Jul 11, 2022 at 1:27 PM
    erwigg
    erwigg [OP] Well-Known Member
    Eric
    Oregon Coast
    2022 Tacoma access cab SR
    question on the bed cleats: how well do they really hold up?
    it looks like a rubber/plastic part
    I am going to help someone move- can I really tie stuff down with it or is this more a delicate little flower?
    in the bed is two D-rings up near the cab that are small-ish how well are these mounted? just to the plastic bed liner or to the body?
    or should i go for the bolt in rings to the bed floor?
    Part Number: PT27835160
    Supersession(s): PT278-35160; PT27835050S1; PT27835100S1; PT27835111; PT27835112; PT78535050S1
    Secure your gear and head out with confidence, knowing that each bed cleat will hold up to 110 lb.
    • Fully adjustable, the bed cleat slides along the vehicle’s bed rail system using a spring-loaded, twist/locking clamp to hold it in place
    • Made of sturdy black-nylon material, each bed cleat measures approximately 6 x 1in.
    2022 Toyota Tacoma Bed Cleats - Black - PT27835160 - Genuine Toyota Accessory
  2. Jul 11, 2022 at 1:39 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    If you want to secure more weight than the cleats will hold (110lbs, per), then strap it to the bed floor with a very strong strap.
  3. Jul 11, 2022 at 1:43 PM
    Tacospike
    Two Trucks
  4. Jul 11, 2022 at 1:46 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I don't trust them for heavier loads. I added rings to the front bed mount bolts like we have in the back. Much stronger and work great for lower loads (like wood) that the bed side ones are too high for.
    Tacospike likes this.
  5. Jul 11, 2022 at 1:58 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    I consider them to be not much better than stabilizing a load. Exactly how much force that applies is anyone's guess.
    I have a cap, so I'm not really concerned about stuff flying out of the bed.
    Tacospike[QUOTED] likes this.
  6. Jul 11, 2022 at 1:59 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I use mine all the time. They were not made to strap down and haul the Liberty Bell, but I certainly would not classify their capabilities to be on par with a delicate little flower.
    JGO, CalcityRenegade and Tacospike like this.
