Bed Carpet Kit!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jnizzle, Apr 26, 2012.
  1. Apr 26, 2012 at 10:52 PM
    Jnizzle
    Jnizzle [OP] Well-Known Member
    Jack
    Reno, NV
    04' 4x4 5spd X-cab
    Shell
    Check it out I just finished it. If enough people ask, ill do a write-up.
    In Progress, Showing the hinge design so you can fit it in and out easily. It folds to about 30 degrees with the carpet pad & carpet
  2. Apr 26, 2012 at 11:01 PM
    jesus
    jesus Well-Known Member
    jesus
    bakersfield
    K&N ram intake & doug exs.
    +im game how hard was it...
  3. Apr 26, 2012 at 11:13 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I once had something similar in a truck. It was moldy in real short order. I highly recommend you silicone the bed drain holes closed to prevent water from getting under your new carpet. Also check and see if you have any leaks around the tailgate.
    Looks good! Just don't want to see it get soggy, and it does not take a lot of water to mess things up.
  4. Apr 26, 2012 at 11:16 PM
    Jnizzle
    Jack
    Reno, NV
    04' 4x4 5spd X-cab
    Shell
    There were some hard spots, but overall it was fairly easy. You could knock it out in one day. It also only costs about $20, for the wood & hinges. Carpet you can find in your local carpeteria's dumpster :spy:
  5. Apr 26, 2012 at 11:18 PM
    Jnizzle
    Jack
    Reno, NV
    04' 4x4 5spd X-cab
    Shell
    I see your from the coast, things get super soggy there for sure! Im in Reno, NV so things are very dry mostly. My dad has had the same basic carpet kit in his tundra for years and its golden.
  6. Apr 27, 2012 at 7:07 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Sure beats spending hundreds on the carpet kits. I like it. I've always had carpet in my bed but never used a backer so it curled up and crap. Will consider this when I get some shag carpet.
  7. Apr 27, 2012 at 8:53 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    I manage a flooring store and have carpet rems all the time. I cut a piece and just threw it down ontop of the bed liner, lays nice and flat and helps with managing cargo. I find it really helpfull when I'm goin to the beach alot b/c it makes the sand easy to clean out. When it gets gunked up from fish slime, I'l replace it.
  8. Apr 27, 2012 at 9:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Looks awesome.
    The one that I had in my '94 was a full kit, basically 3-pieces.
    The sides fit over the wheelwells and had storage doors on top, plus 4 cup holders at the rear.
    The sides also had 2x2 strips near the top.
    The center floor could be pulled out and rested on these 2x2s so the bed could be used for camping, with gear still secured under the "floor".
    I put a Bedrug in my 2nd Gen.
  9. Apr 27, 2012 at 11:26 PM
    Jnizzle
    Jack
    Reno, NV
    04' 4x4 5spd X-cab
    Shell
    Sounds sweet, have any pics of it?
  10. Apr 27, 2012 at 11:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Nahh... haven't had that truck since I traded it on my Tundra at the end of '02, and I never did get any interior pictures of it.
