Bed Bulkhead Cap Screw Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jnc1991, Sep 13, 2019.
  1. Sep 13, 2019 at 12:09 AM
    jnc1991
    jnc1991 [OP] Member
    2017 Tacoma TRD Sport LB
    I am installing a BakFlip bed cover. The directions have you remove the bulkhead cap and placing seals on the ends, then reinstalling the cap. One of the nuts for the bulkhead cap seems to be crossthreaded. Any advice for repairing or replacing that nut if that is even possible? Ive been searching diagrams to see if those are available and only find the nuts that fit on the rails for accessories.
  2. Sep 13, 2019 at 12:12 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    The front of the bed/rail? If yes I thought those nuts where welded on. If that’s the case then rethread the nut maybe
    Big tall dave likes this.
  3. Sep 13, 2019 at 12:14 AM
    jnc1991
    jnc1991 [OP] Member
    Yes on the front of the bed. That may be the case, will have to look closer.
  4. Sep 13, 2019 at 2:12 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I would....
    1. Try and run a tap/thread chaser through it first, if not.....
    2. Drill it out and use a Heli-Coil or a NutSert
    Good luck.
  5. Sep 13, 2019 at 2:18 AM
    jnc1991
    jnc1991 [OP] Member
    Awesome. Thanks for that info. Ill try it.
