Bed battery relocation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Emtmeyer, Feb 27, 2013.
  1. Feb 27, 2013 at 3:18 PM
    Emtmeyer
    Emtmeyer [OP] Angrytaco
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    4" maxtrac spindles, extended brake lines, custom fab bumper, sound system, 33x12 federal couragias, cibie driving lights, otrattw dash switches
    Has any one relocated their battery to their bed? Trying to get some ideas on how I want to do it and nothing coming up after searching
  2. Feb 27, 2013 at 3:22 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    why? reason?
  3. Feb 27, 2013 at 3:24 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Weight distribution
    Cracked or broken core support
    Reduced taco lean
    Easier to run duals
    Not restricted to the stupid reverse pole batteries Toyota uses
    Is that good?
  4. Feb 27, 2013 at 3:26 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    All the above! Plus less front weight for jumps and such, risk of breaking and doing serious engine damage
  5. Feb 27, 2013 at 4:00 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    I did not see you were that modded. Forget some people on here use their trucks more than others.
    Not sure what anyone is running in terms of duals???? Getting around the reversed batter terminal situation is easier than a relocate.
    I have relocated them on a three of my previous vehicles.
    I would just pick a battery box that you like and attach it by means of a bed bolt. You are gonna have to get handy since there are no kits for our specific truck.
    If you pick a box that has a bolt on lid setup I would place a disconnect switch under the hood inline or at the battery box.
    I am guessing your truck is not going back to stock so purchase some welding lead cable in bulk from a electrical supply house and run it along the frame with proper grommets and fasteners. Just take off the factory leads and puts your own ends on the cables.
    If you do plan to go back to stock you can couple onto the stock battery leads to make a quick change for future sale.
    You can ground to the frame using the bed bolt but check your resistance values to verify it is a good ground.
    I like odessey batteries if you want one to take abuse and are light, optimas turned to crap.
  6. Feb 27, 2013 at 4:05 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    Yes and a sounds system
  7. Feb 27, 2013 at 4:07 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Ill def put a disconnect at the box and will mount it with insulated clamps, I'm just trying to see how others looked, I'm debating cuttin a hole in the side of the bed by the cab and mount the box in there so it's kind of hidden but readily accessible. Odessey is what I'll run, used to love optima till they moved to Mexico. My sig pic is pretty old lol I have done a lot since
  8. Feb 27, 2013 at 4:08 PM
    eric3187
    eric3187 Well-Known Member
    in my bagged truck i had, i just used a generic plastic battery box and ran the 2ga welding cables up front. held the battery box down with some 1/4" bolts.
    while it works for relocating, since its not solid mounted i would not jump or heavily off road with that type of setup
  9. Feb 27, 2013 at 4:10 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Lt is being made as we speak, prepping the truck for it, i have a 10" secured in the cab which hardly counts as a sound system, love the criticism tho any one have something constructive to add?
  10. Feb 27, 2013 at 4:12 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    That's where I'm having issues, only plastic boxes seem to be truly sealed and weather proof, might just have to go silicone crazy with a metal box.
  11. Feb 27, 2013 at 4:14 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    There is a decent amount of room in the rear bed quarters but you would really need to fab up a mount.
    I typically over fabricate everything and make it built twice what is needed and would come off the frame.
    I try to not cut up vehicles and work around what is there. Probably put it on drivers side since the cubby is larger.
    The odessey are typically half the weight so I would not worry about putting it on the drivers side.
  12. Feb 27, 2013 at 4:16 PM
    eric3187
  13. Feb 27, 2013 at 4:17 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    I don't want the box to fill with water in bad weather and corrode the crap out of terminals
  14. Feb 27, 2013 at 4:19 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    Factory location is not sealed in any way. As long as you put up a shield and have it in a good box that is not taking in water all the time it is a non issue.
    http://www.summitracing.com/parts/cee-4029/media/images
    Use grommets to seal the box where the cable enters and seal the corners with silicone. Use weather strip on top lid for ease of access. Nice and strong to mount as well.
  15. Feb 27, 2013 at 4:19 PM
    eric3187
    no box = no where for water to collect ;)
  16. Feb 27, 2013 at 4:20 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    Good point, but visible battery=fun item for hoodlums to steal
  17. Feb 27, 2013 at 4:25 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  18. Feb 27, 2013 at 4:33 PM
    Emtmeyer
    Brad
    Bakersfield,ca
    07 prerunner 5spd
    I debated the mount inside a plastic box and its not a bad idea, I can just drill a hole in the tab that the halves connect to to put a lock through.
  19. Feb 27, 2013 at 4:37 PM
    Tacoma Mike
    Southern Maine
    I did do this on my plow truck.
    I built a dual battery frame and used 2 battery boxes to keep them dry. Drilled 4 drain holes in each box in case of an issue. With stuff being thrown in the back covers were necessary. No issues but if your going to do this make sure it's built to take the abuse if you are gong to "jump it". One guy around here installed them in his tool box in the bed.
  20. Feb 27, 2013 at 4:38 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
