Be QUIET! or... how to sound-proof your Taco cab
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jinzo Ningen, Oct 1, 2020.
  1. Oct 1, 2021 at 10:28 AM
    #61
    itsZiz
    itsZiz Active Member
    2021 VooDoo Blue SR5
    KMC KM535 GRENADE OR Falken Wildpeak AT2W 265/75r16 Black Decals Overlay & Tailgate Inserts Aeroskin II Hood Protector Tacoma OEM Bed Mat Window Tint TRD Grill
    Did you do MLV in the doors too? I'm trying to figure out how much room there is between the inner door and the panel.
    MLV is 1/8 thick, then a layer of ccf on at least one side, maybe both (between the metal door and mlv, and the mlv to the door panel) so its up to 3/8 of an inch. Some of it squishes down from the ccf, but that still seems really thick.
    Hate to waste money on stuff I have to rip out.
    CygnusX191 likes this.
  2. Oct 1, 2021 at 11:17 AM
    #62
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Yes on the doors, Its a tight fit but it fits.
    I used sound deadening inside the door shell and around the speakers another layer of sound deadening foam stick on material and then hung the MLV over it.
    https://www.amazon.com/gp/product/B08562G98X?ie=UTF8
  3. Oct 1, 2021 at 11:37 AM
    #63
    itsZiz
    Thanks!
    So you used the foam on the inside of the door shell, what about between the MLV and the meta door itself? So essentially did you have 3 layers... ccf/mlv/ccf ~ 3/8"
    I've read ccf between the mlv and the metal door panel is the most important, but assumed id need it between the mlv and the door shell as well. basically we dont want MLV touching anything that isnt soft ccf right?
  4. Oct 1, 2021 at 11:42 AM
    #64
    auskip07
    Skip
    Atlanta, Ga
    Inner part of door (where window recesses) and exterior shell
    Layer 1 -BXT II RAAMmat
    Cabin side of metal door in-between the door and plastic door card.
    Layer 2 - Ensolite IUO
    Layer 3 - Mass loaded Vinyl
    i got the door card plastic snaps in place and used pressure from my knee to get alll the screws in. So its tight.
    CygnusX191 and itsZiz[QUOTED] like this.
  5. Jan 17, 2023 at 12:15 AM
    #65
    Danieldee
    Danieldee Well-Known Member
    Daniel
    2015 Tacoma TRD
    Im about to install goose gear as well. Did you have any trouble with fitment after putting the materials?
  6. Jan 17, 2023 at 1:27 AM
    #66
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    If you stick to 80 mill and 150, you should be fine. I used 150 on top and 300 in lower portions, and my floor and some areas did not like the extra. For some reason, I had in my head to use the 300 and its FAT. With 80 mill and 150 it should fit back nice and clean.
    doublethebass and CygnusX191 like this.
  7. Jan 17, 2023 at 5:53 AM
    #67
    Shellshock
    Iowa
    Nope. Definitely recommend doing if you are putting goose gear in
  8. Jun 17, 2023 at 11:23 PM
    #68
    MajinMight
    MajinMight Member
    Derek
    2011 Black Tacoma SR5 Access Cab
    Kenwood Excelon Head Unit with wireless Android Auto and Apple Car Play
    Hey guys, I have a 2011 SR5 access cab and started the project today. I have 80 mil killmat I'm putting everywhere. I can't figure out how to get the back panel off the back wall in the access cab. Haven't seen a video for this specific trim. I've removed the seats, and storage bucket. It seems tight, but I don't see and bolts or screws holding it in place. Anybody know?
    Also to remove the headliner, I have everything off except for the airbag badges. Any special way to take those off? I disconnected my battery just in case.
    Thanks!
  9. Jun 18, 2023 at 7:11 AM
    #69
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    everything pry's off. just gotta find which way to pry it. one way it won't go, the other way it will
    MajinMight and CygnusX191 like this.
  10. Jun 18, 2023 at 2:51 PM
    #70
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Yup, stuff just pops off lol.
    Airbag badges?
    MajinMight likes this.
  11. Jun 18, 2023 at 3:47 PM
    #71
    soundman98
    NW Indiana
    the one's at the top of the A pillar? i believe they pry towards the windshield. it's really just a bolt cover
  12. Jun 22, 2023 at 5:33 AM
    #72
    MajinMight
    MajinMight Member
    Derek
    Yes, so the SRS airbag emblems or badges... Are just fancy screw covers. You need a sharp tool to get in there and open the cover. It splits in half folding down to expose a 10mm screw. Best to use a socket instead of Phillips head on these.
    The back panel does pry off as others mentioned here. It was on so tight that I felt like it had screws but it didn't, just about 15 of those plastic clip things. Nearly all of them broke so you may want to have new ones on hand for reassembly.
