Baxter Performance TS-101-BK
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Xena1, Oct 18, 2017.
  1. Oct 18, 2017 at 2:04 PM
    Xena1
    Xena1 [OP] Well-Known Member
    Ron
    2017 Tacoma Access Cab
    Contacted Baxter Performance today and they have a oil filter adapter which eliminates the cartridge on the 3.5L and uses a spin-on filter (wix# 51348). A bit pricey at $200 but filters are less expensive and much easier to replace. Over the life of the truck it would not be a factor. Anybody done this?
  2. Nov 9, 2019 at 8:35 PM
    badmotofing3r
    badmotofing3r Member
    Zach
    Late reply but I wanna help you out. I put the Baxter Performance TS-301-BK on my 2014 Tundra. I love it. I as well made a custom (lolz) hole in my skid plate.
    My long-term girlfriend and I are looking in to getting a 2019 Tacoma and this will be my first mod to it once we get it. Installing a TS-101-BK
  3. Nov 9, 2019 at 8:37 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I'm not a fan
    1. The expense
    2. It adds another leak point
    3. The cost savings will be a wash
    The cartridge setup is tried and true.
    wahoobie, hrivera007, Chew and 3 others like this.
  4. Nov 9, 2019 at 8:50 PM
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I got mine close to 1 year and no problems. Soon I need to change the oil.
  5. Nov 9, 2019 at 9:02 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
    Unless you first puncture the spin on filter to drain some oil before removing it, I think you might end up with a bit of a mess from spillage due to the oil held in the passages at the top of the filter. It can sometimes be tricky to hold onto a large slippery spin-on filter.
    I suppose that if you have a large enough oil pan it’s not a big deal.
    The cartridge filter has the drain plug at the bottom, to which you can attach the plastic drain piece and drain hose to prevent it from making that mess from spillage.
    The adapters look cool. I’d like to know how clean, or messy it is to remove a filter with one installed.
    I’ve dropped vertically remote mounted filters while changing them.
    Mas Olas likes this.
  6. Nov 9, 2019 at 9:04 PM
    Dacon
    Danny
    Gilbert, Arizona.
    I will find out soon how it works. Not the first time I took a facefull of oil.
    OregontoBajaCA and shakerhood like this.
  7. Nov 9, 2019 at 9:30 PM
    Ziggyman
    Ziggyman Well-Known Member
    2018 TRD OR DBL 4x4
    I installed mine last weekend. I drive about 30k a year and I have hated the wife's cartridge filter in her 08 Highlander since...08...
    What do folks with this adapter do when taking car to dealer (assuming there is a reason)? Tell them to not tough the oil?
    I'm at 33k seems like the only real maintenance besides oil, lube shaft and check bolts on drive are spark plugs at 60k.
    Get the adapter. Most folks tell you to get a metal housing... Just use the cash toward the adapter.
    Saying it is another leak point tells me you may not know what a pos the cartridge is. The frickin drain usually never works, the plug part seizes, you get rained on with oil doing the whole thing. No real way to torque the bitch either. I'm always doing it hand tight... Seems to work but no way....
    OG_Tacoma likes this.
  8. Nov 10, 2019 at 5:56 AM
    Itchyfeet
    The cartridge system has been around for decades. It does add another leak point. It's not going to show up in the first year, but the constant R & I of oil filters is going to have a negative effect on the the adapter o-ring. The product kind of reminds me of the Jeep 4.0 oil cooler / filter mount. Sooner or later it's going to leak
    shakerhood likes this.
  9. Jun 7, 2020 at 3:20 PM
    badmotofing3r
    Zach
    I had a leak with my cartridge filter on my Tundra on the last oil before I was going to install my Baxter Performance TS-301-BK.
    Upon investigation when I took the cartridge filter apart the larger diameter o-ring was trashed. Could of been a freak deal with the o-ring supplied with the filter or it could have not.
    Going on 1.5 years and two oil changes with my Baxter TS-301-BK and zero leaks so far.
  10. Aug 19, 2020 at 10:13 PM
    swtlei4u
    swtlei4u Member
    ron
    2017 tacoma try sport
    try pro grill
    any suggestion on the oil filter that fit on the conversion? purchase the 101k.thx
  11. May 6, 2021 at 12:19 AM
    Nichoff270
    Nichoff270 Member
    Nick
    2017 TACOMA TRD OFFROAD 4x4 DBL CAB Short Bed Black
    BF Goodrich All Terrain TA KO2 K&N Black Hawk Cold Air Intake Magnaflow Cat Back Stainless Exhaust TRD Pro Front Grille Deer Creek Hunting Dog Box Husky Liners
    Toyota TS-501-BK Cartridge to Spin-on Adapter (Universal)
    Put it on my 2020 Toyota Tacoma, TRD Off-Road Double Cab, V6 3.5L about two months ago. What a well made, heavy duty oil filter adapter that replaces the cheap plastic cartridge style! Worth the price and convenience of using regular and better and less expensive tradition oil filters. As the company claims, it gives your engine better lubrication and protection at cold starts. Great customer service! I refer you to the great auto mechanic YouTube Channel “Scotty Kilmer” for a discussion of the Baxter Performance Oil Adapter versus the cheap plastic OEM cartridge style.
  12. May 6, 2021 at 12:41 AM
    waltuo
    waltuo Well-Known Member
    Toyotas
    $200?
    Nichoff270[QUOTED] likes this.
  13. May 6, 2021 at 4:36 AM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    Yup and it was worth it to me and my brother
  14. May 6, 2021 at 4:48 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    To me, they're less convenient. Not having an oil drain is going backwards. I hate oil, so anything that lessens a chance for spillage, I'm for.
    Also, Scotty :annoyed:
    Lt. Dangle and waltuo like this.
  15. May 6, 2021 at 9:22 AM
    waltuo
    Toyotas
    I was just confirming the price because he said he could buy the “less expensive traditional oil filters”
    I can do 35 oil changes for the price of this adapter. Not to mention the added leak point. Sorry, replacing the filter element isn’t that hard.
    Skydvrr likes this.
  16. May 6, 2021 at 9:23 AM
    waltuo
    Toyotas
    X2
    Skydvrr[QUOTED] likes this.
  17. May 6, 2021 at 9:25 AM
    mysubiewasalemon
    I like being able to use my filter magnet on the canister just for piece of mind
  18. May 6, 2021 at 9:45 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    350k miles, gawt dayum.
    waltuo[QUOTED] likes this.
  19. May 6, 2021 at 10:31 AM
    waltuo
    Toyotas
    Haha it'll be my kid’s problem in about 10 oil changes
  20. May 6, 2021 at 10:42 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
