Battery voltage 14.5V & 15.6V - too high??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ashakespeare, Apr 13, 2019.
  1. Apr 13, 2019 at 2:44 PM
    ashakespeare
    ashakespeare [OP] Well-Known Member
    2018 DC TRD OR
    Hey TW, happy Saturday!!
    My 2018 Tacoma was having some trouble starting (engine wouldn't turn over), so I checked the batteries. The starter battery (OEM) was at 14.5V and my aux battery was at 15.6V (which charges from the alternator through a BlueSea ML-ACR). I don't check my batteries often, but I can't remember ever seeing the voltages this high. Is it too high?
    Oddly when I tried to start the car again, it turned over no problem.
    Thanks
    Andrew
  2. Apr 13, 2019 at 2:53 PM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    That does sound a little odd. Usually, the charge of a resting 12V battery is around 12VDC. It might read more when the alternator is going.... you got anything else providing power like a solar panel?
    JoeCOVA likes this.
  3. Apr 13, 2019 at 3:00 PM
    ashakespeare
    2018 DC TRD OR
    No other power sources; just the alternator. I'll check in a couple hours and see if it has settled down at all. Seems really high to me.
    Should I put a load on the battery to truck 'suck' some of the over-charge out?
  4. Apr 13, 2019 at 3:04 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Try putting a load on it and testing it. Maybe turn on the headlights with the engine off and test.
  5. Apr 13, 2019 at 3:21 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Seems it's getting overcharged which could lead to premature battery failure. I would definitely inspect the battery and have a shop test the your voltage regulator isn't faulty.
    Markcal and Thatbassguy like this.
  6. Apr 13, 2019 at 3:22 PM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    A fully charged battery at rest should read 12.8 volts. A properly working charging system should top out at 14.4 to 14.6 volts. Charging to 15 is murder on a battery. Heat destroys batteries not cold. Cranking in the cold takes more juice. Your battery will be trash after the summer. First cold day... Click click click
    cwdog, OriginalMan and Thatbassguy like this.
  7. Apr 13, 2019 at 4:20 PM
    Woodrow F Call
    Colorful Colorado
    I'd check the charging system and see what you are getting. I'm not completely familiar with Toyotas, but your regulator might be bad.
  8. Apr 13, 2019 at 4:20 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    14.5 would be proper charge voltage from your alternator.. when its not actively running/charging it should be around 12.4-12.8 if the voltage drops below 11.8 when engine is off your battery is getting weak.. you should have it load tested.. the 15.6 is beacuse your charge controller is not reading battery voltage correctly.. it should stop around 14.8 MAX.. dissconnect the bluesea controller and test the battery.. if it checks out to around 12v-13v.. it should be fine.. the charge controller should switch off, or dump to a dummy load (typically a coil, or incandecent bulb arrangement)
    OriginalMan likes this.
  9. Apr 13, 2019 at 4:21 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The assumption is that your voltmeter is accurate. Have you tested it on another vehicle? In my experience, 14.3V would be top charge voltage. Certainly anything more than 15V would be defective.
  10. Apr 13, 2019 at 4:22 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I can't see how using an ML-ACR you can get this. It's only connecting batteries together so if the main is 14.5V then the aux has to be that or lower. Or perhaps you have a perpetual motion machine charging the aux?
  11. Apr 14, 2019 at 9:32 AM
    ashakespeare
    2018 DC TRD OR
    I checked this morning, with the engine off and ML-ACR in the off position: starter = 12.93V and aux = 16.20V (still way too high).
    I'll leave the charging relay off for now, and have put a small load on the aux battery to try bring it down to 12-13V.
  12. Apr 14, 2019 at 9:47 AM
    DaveB.inVa
    DaveB.inVa Well-Known Member
    SWVa
    2015 AC SR5 4x4 V6 AT MGM
    Oil Catch Can, OIl Pressure and Temp Gauges, Falken Wildpeak A/T3W 265/70R16
    Check your meter. I've got a Dodge Cummins and had an issue causing the truck to stop. Mine was a loose connection from the ECM to the battery ground at a battery terminal. At the same time I decided to check voltage on my batteries and got high readings of around 16V.
    I changed the 9V battery on my meter and brought everything back to normal.
  13. Apr 14, 2019 at 9:49 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Just a thought before you start changing anything. Try a different meter to make sure yours us reading correctly. If you dont have another meter, try yours on another vehicle to see if it also reads high? Just a thought.
  14. Apr 14, 2019 at 9:57 AM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    How long have you had this dual battery setup? They are setup in parallel, not series right?
  15. Apr 14, 2019 at 10:14 AM
    ashakespeare
    2018 DC TRD OR
    You guys were spot on. Replaced the 9V battery in my voltmeter and started getting much more realistic readings! Thanks for your help :)
    Aux = 12.9V and Starter = 10V ... looks like I need a new starter battery (which explains the engine not starting in the first post). One of the benefits of having an aux battery you can easily connect to the starter when you're in trouble.
  16. Apr 14, 2019 at 10:23 AM
    20tacoma17
    2017 DCLB Sport AT
    Well just glad that's all it was and an easy fix. :hattip:
