Battery Tender Install? - 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mattm55, Jan 4, 2022.
  1. Jan 4, 2022 at 5:05 AM
    mattm55
    mattm55 [OP] Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    I did a search and found very little on installing a battery tender on a 3rd gen. I was wondering if anyone has one hard mounted under the hood that would share how they mounted for ideas?
    My problem (OK, probably others too) is that I work from home and hardly ever use my Tacoma. I do remote start and drive around the block but that's not keeping the battery up to snuff. The truck is parked outside under a cover.
    I grabbed a NOCO Battery Tender and trying to decide where to mount. I see there is a place on the drivers side fender with 2 open threaded 10mm bolt holes. I'm looking at creating a "mount" for that location but I always seem to overthink things. The mount wouId be aluminum and rubber isolated as well.
    I don't like the self-tapping screws in the fender nor a couple of tye-wraps on the battery method. I thought of mounting on the fuse cover however don't want to drill thru and cause water issues.
    Looking for any ideas. I'll post my setup once done for anyone else.
    Thanks
  2. Jan 4, 2022 at 5:58 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  3. Jan 4, 2022 at 11:37 AM
    mattm55
    Thanks. I tend to way overcomplicate...
  4. Jan 4, 2022 at 1:17 PM
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    I'd wire it like a motorcycle tender is setup. Easy. They have a pigtail that stays on the battery and a matching one on the tender. Just google search it. Easy to find.
    toku58 and Tacospike like this.
  5. Jan 4, 2022 at 1:41 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Trigger sells a lightweight aluminum tray that mounts to the threaded fender holes. You'll probably need to drill two holes on the tray to match the bolt pattern of the tender. https://triggercontroller.com/product/trigger-toyota-tacoma-bracket/
    The other option is to mount the tender on the garage or carport wall and just run the 12V wires to the vehicle. I mounted mine in a nondescript plastic stationery case to avoid drawing attention and to contain the wires when it isn't plugged in.
    IMG_5524_ctek_wall.jpg S_xSxCMevz-ar1UPavJgKw3WBje0etsIAjWjYDU2_a0adac847e687406d120316aaa373ddfa9e459cd.jpg
    Tacospike likes this.
  6. Jan 4, 2022 at 1:43 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I installed a port inside the drivers side wheel well. Allows me to plug in my tender or a solar panel without even having to pop the hood. These pictures were my temporary mount, I have since made a HDPE plate that connects to the top clip for the splash gaurd.
    DingleTower and Tacospike like this.
  7. Jan 4, 2022 at 2:30 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    This is how I have mine mounted. Only the wire sticks out of the grill.
