Battery Replacement Recommendation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Snake, May 21, 2012.
  1. May 21, 2012 at 7:12 AM
    Snake
    Snake [OP] Member
    Alabama
    PreRunner DBLCB LB TRD Sport 2WD
    None
    I had an issue this morning with my original battery in my 2007 not wanting to turn over this morning. Noticed it was turning over slower than normal and am curous as to what would be a good replacement.
    It's still the original battery and I have the heavy duty one that comes with the towing package and have the power outlet in the bed.
    Also, I feel like I've read somewhere that the O2 sensor or some other sensor may need to be reset after replacng that battery? May be crazy but if anyone could shed any light on this it would be appreciated!
  2. May 21, 2012 at 7:33 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Make sure it's the same cold cranking amps basically match the numbers on top of the battery I like the odyssey brand or just ask thE guy Wat the auto parts store he can help you find one in the computer
  3. May 21, 2012 at 7:39 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    you can either get 24F or a 27 and optional optima red top..optima i would recommend only if youre running a sound system,winch or off road often,other than that,its a waste of money. 24 is the standard size which is most common. 27 is the longer,a little more power (towing battery). The o2 sensor does not have to be reset
    hresendiz25 likes this.
  4. May 21, 2012 at 7:44 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Like mentioned get the same battery spec and group size, with the best full replacement warranty available, combined with the pro rate warranty. I lot of good batteries out there made by the same people with different packages or names on them.
  5. May 21, 2012 at 7:50 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  6. May 21, 2012 at 10:26 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Same thing happened to me a month ago, I went to walmart, had the best price and same warr. as others
    got OTD for less than 90 bucks and picked up an extra 40 CCA
    Ranger Dave likes this.
  7. May 21, 2012 at 3:56 PM
    11Speedway
    11Speedway Well-Known Member
    Held Hostage in Tennessee
    Stock 11 TRD OffRoad Access Cab
    I am a fan of the Interstate brand. Replaced several OEMs over the years with Interstates.
    Barzini and JSU like this.
  8. May 21, 2012 at 7:38 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    be cafefull with the battery clamp, as it's cracked 2 of my batteries. I would say odyssey.
  9. May 21, 2012 at 10:10 PM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    Sears diehard platinum 31m
    dbennett48 likes this.
  10. May 22, 2012 at 6:44 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I replaced my battery this past fall.... Not because it was 'bad' but because it was 5 years old and the 'winter' was approaching. It was time to change it before it left me sit. I shopped around and ended up buying a battery from my local dealer - they were having a sale on them. I can't remember the details... but it compared in price to all the others of the same size and had a really long warranty.
    Plus, I figured.....the factory battery lasted 5 years without any problems, you can't go wrong with another factory variety.
  11. Feb 28, 2016 at 8:20 PM
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
  12. Feb 28, 2016 at 8:22 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Northstar
    Interstate
    AutoZone Gold
    There are only a handful of battery manufactures so chances are they just have a different label
  13. Feb 28, 2016 at 8:42 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Northstar makes Northstar
    Benzdriver81 likes this.
  14. Feb 28, 2016 at 8:47 PM
    mahaloTaco
    Max
    Los Angeles
  15. Feb 28, 2016 at 8:49 PM
    OZ-T
    Peter North
    British Columbia
    If by cool you mean is that the same battery I have in my truck , the answer is yes , Northstar AGM 27F
    patbegley and mahaloTaco like this.
  16. Feb 29, 2016 at 4:14 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    I buy TrueStart batteries. Some last a long time, some don't... same as the others. I'm out on remote jobsites every day, no cell service most of the time, can't worry about dead batteries, so I take along my AntiGravity jump start pack. Also have a BatteryMole analyzer plugged in, keeps track of the battery, charging system. I'll know before hand when to pick up a new battery.
    asuchemist and UBYBC like this.
  17. Sep 17, 2018 at 7:55 AM
    Smokyray
    Smokyray Member
    Rob
    TX
    Tacoma Gen 2
    PR, SR5, Tow Pkg, Tri-Fold Tonneau Cover, Bed Rails, K&N Intake filter system
    My original Toyota battery (2013) lasted five years before it wouldn't hold a charge. As mentioned above, make sure to have a load tester verify your battery is bad or it isn't dirty connections, bad ground or faulty alternator, or that you inadvertently left an interior light on overnight. Most lead acid batteries are the same basic materials underneath the label, the number of plates and capacity being the difference and CCA capability. Life span of the lead plates in acid is about three-five years before they won't hold a charge, hence the standard warranty time. A deep cycle AGM battery is another animal altogether and price range. They also need to be charged differently than a LA battery. Unless you have excessive engine off battery drain, a standard LA battery is a much better value. If you live where it gets really cold, a battery blanket and solar trickle charger are good investments, trust me. I like to be able to replace the battery easily so I purchase from National supply stores (auto parts chains, Sam's Club, WalMart etc) Here is a good article on batteries and their characteristics. https://www.wholesalesolar.com/solar-information/deep-cycle-battery-info
    For my Tacoma I bought a Sam's Club Duracell 27 with the 5 yr warranty.
    https://www.samsclub.com/sams/durac...el_people-who-viewed-this-item-also-viewed_16
  18. Sep 17, 2018 at 9:09 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    The 27F is a dollar cheaper :thumbsup: if you can find it. Usually out of stock at local Sam's.
  19. Sep 17, 2018 at 9:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    This thread started about the time your original battery was produced.............. :D
    doublethebass and knottyrope like this.
  20. Sep 22, 2018 at 12:39 PM
    Smokyray
    Smokyray Member
    Rob
    TX
    Tacoma Gen 2
    Yeah, I guess you can't keep a good thread down...:)
    MolonLabeTaco likes this.
