Battery Replacement...AGM or Lead
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WVTacoma08, Jul 22, 2020.
  1. Jul 22, 2020 at 6:33 PM
    #61
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I’ve heard that optimal aren’t what they used to be since company was sold and batteries now produced out of the country. I have optima yellow tops in my dodge and they’re just now starting to go bad- they’re from 4/2006. I’m really torn on what to get now but thinking about diehard or northstar. Unfortunately there’s no sears anywhere around me these days. I’ll be sticking with agm irregardless. I’ve put 2 acid batteries in my wife’s car in the last 4 years. The last one that failed wasn’t covered under warranty even though it was just Under 14 months old since it was a battery that replaced another failed battery under warranty.
    DAS Taco likes this.
  2. Jul 22, 2020 at 6:47 PM
    #62
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I edited my previous reply with a few links, worth checking out
  3. Jul 22, 2020 at 7:32 PM
    #63
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    You can find some info about my findings and config values in my post history. My alternator constantly outputs 14.6-14.7v.
    Bastek likes this.
  4. Jul 22, 2020 at 7:47 PM
    #64
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Another data point. I have vF Tuner and am waiting for the AT transmission tunes to drop. I will alter my charging voltage once the tunes are available. I have a X2 24F AGM currently. Had it since March 2020.
    Even at the stock charging voltage, when I go to top it off every 3-4 weeks, I never see it below 90%. Usually it’s around 95% in the ~4 times I’ve topped it off since I got it. Today I put it on the charger to top it off and it was at 90%. It’s been consistently in the high 90’s temp wise here, so maybe the heat is drawing it down more. Maybe it’s because I top it off every 3-4 weeks, but I’m not seeing anything drop off too crazy, voltage is always around 12.9 and it’s always around 90-95% charged. Only takes about an hour to get it to 100%.
    This is my first AGM, and it’s new so long term could be a turd, but so far I like it and the fact it’s sealed and not leaking/outgassing like the stock battery before I replaced it.
    EagleUSMCRet and b3itz like this.
  5. Jul 23, 2020 at 3:00 AM
    #65
    cubie
    cubie Aznrednek
    Jonny
    Sweet home Alabama
    '06 and '18 TRD OR 4x4 Access Cab
    they looked it up on their computer and I believe I got a 24.
    dubktrd[QUOTED] likes this.
  6. Jul 23, 2020 at 4:45 AM
    #66
    Outdoorsy_Yota
    Outdoorsy_Yota Hella-Known Member
    duhbondo JIW Local 378
    Bay Area
    17 DCLB TRD OR LOL
    13.5 - 13.8 on a chilly morning, but yeah.... I have a solar on my aux, that tops it off properly.... but my starting battery with the witch hooked up to it will be 80% cap till I get a charger
  7. Jul 23, 2020 at 4:45 AM
    #67
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Optima used to be a top choice, in fact I got Optima batteries in all 5 vehicles including a Blue Top in our fishing boat that's 9 years old and it's still strong. But the quality has gone south...maybe it's a coincidence but ever since Optima moved to Mexico they aren't made the same. The Red Top Optima in the picture is my second one in 1 year, the first one just quit taking a charge from the Noco (Genius G3500) charger...(i rotate my vehicles so when they are parked they're on their Noco) so they gave me another one...will see if it a good or dud purchase...a Red Top Optima in Alberta can be between $260-$280 CAD
    maxtherat likes this.
  8. Jul 23, 2020 at 4:59 AM
    #68
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I used an advanced auto AGM in my 2nd gen for years with no issue, and it never saw a charger or a change from the stock alternator output. I just got an advanced auto AGM (made by Johnson Controls-3yr warranty) for my 3rd gen, but it sits on an AGM maintainer all the time since I barely drive it. Came in under $200 I think. No way would I pay the $300+ for one of the instalanding brands.
  9. Jul 23, 2020 at 6:08 AM
    #69
    EchoDeltaSierra
    EchoDeltaSierra Well-Known Member
    Georgetown, TX
    2020 TRD Off-Road
    Nitro 4.88 gears OME suspension ST/Maxx 255/85R16s
    I'm a bit of a battery-geek and had to pile on...
    If all you're doing is starting the vehicle and driving on pavement, any decent battery will suffice. If the truck is going to experience more vibration and be expected to power accessories (winch, compressor, lights, radios, etc) then AGM might offer benefits worth the cost. AGM is a very good lead-acid battery construction, durable as all getup, and in the same size +50% more capacity. Yes, they have a higher voltage for float charging to realize their full potential. About every month or so, I just hook up a NOCO charger and float the charge up to levels AGMs prefer (14.4v). The only real weakness of AGMs (and really any other lead acid battery) is over-discharge... a few deep discharges (like below 11.6v) and it will permanently affect the internal chemistry shortening the capacity and life of the battery.
    Batteries, like tires, are expendable. There are advantages and disadvantages to each type of battery. Understand your use case and get the right tool for the job.
    Lots of great info on all sorts of battery tech at Battery University. - https://batteryuniversity.com/index.php/learn/article/absorbent_glass_mat_agm
  10. Jul 23, 2020 at 6:18 AM
    #70
    DAS Taco
    DAS
    2017 TRD Offroad
    Also I believe that AGM batteries have a lower resistance than led acid geometry...so that can help with longer alternator life.
  11. Jul 23, 2020 at 6:44 AM
    #71
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    7.8 volts, no problem.
  12. Jul 23, 2020 at 6:55 AM
    #72
    EchoDeltaSierra
    Georgetown, TX
    2020 TRD Off-Road
    "If you discharge the battery up to only 30%, the battery will live for about 1,200 to 1,400 cycles, depending on rate of discharge. On the other hand, if you discharge the battery all the way to 100%, it will only provide you with about 300 to 350 cycles." (ref. https://www.quora.com/Should-I-not-let-my-AGM-battery-discharge-below-70-or-50)
    It may crank the engine; but at voltages that low, the batteries functional life is permanently shortened. It's how chemistry works.
  13. Jul 23, 2020 at 6:57 AM
    #73
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    Once you have 1 lead acid battery leak, you never get one again. Replaced mine with an Odyssey in the first 2000 miles. Factory battery is also junk by all accounts.
    DAS Taco and Shellshock like this.
  14. Jul 23, 2020 at 6:58 AM
    #74
    Outdoorsy_Yota
    Bay Area
    17 DCLB TRD OR LOL
    That's what the battery see's? If, so, this is great!
  15. Jul 23, 2020 at 7:05 AM
    #75
    dubktrd
    dubktrd Well-Known Member
    Wichita Kansas
    Which Noco model charger do you have ?
  16. Jul 23, 2020 at 7:21 AM
    #76
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    most o the time a ' New ' batt is NOT fully charged when needed as a replacement
    they have been sitting on a self losing a % each/ every day simply sitting
    then attached to the waiting vehicle................essentially will ONLY charge to the level
    of that particular vehicle ............. No Less to that specific charging system
    results likely the BATT is NOT at an Optimum level
    then its usually driven back to residence
    truth be known its never nor will it reach optimum level
    not everyone analytical retentive
    i place same batt on charger ( NEVER use a trickle Charger !!!!) overbite
    to get a FULL CHARGE
    place in vehicle usually take an extended run/trip
    the BATT will then be charged to the system of same vehicle ( typically IS below Full Charge )
    i do quite a bit of ' road ' driving as i rarely do suburban/ commuter / or in town bump/ grind traffic
    so my Batts are rrarely in ' Deficit ' a direct result from the Cranking
    + the resulting ' Load '.........actually running ( nite / headlights altho LEDZ have lightened the Load)
    essentially the Batt rarely rebound to the optimum charge
    the main reason they go bad
    today at 90%
    & down hill Each successive daily cycle
    each short trip to follow
    down hill each cycle ...............
    while many think all is well they could actually be down to 60-70%
    & trending down
    in real world environs the New tech Battz rarely last longer
    altho they are Very Convenient
    koditten likes this.
  17. Jul 23, 2020 at 7:32 AM
    #77
    scotkw
    A free State
    '17 DCSB V6 2wd Sr5
    Guess I should have been more clear. I have a capacitor, not a battery. Millions of cycles to 0%, no degradation.
  18. Jul 23, 2020 at 7:33 AM
    #78
    EchoDeltaSierra
    Georgetown, TX
    2020 TRD Off-Road
    The NOCO G3500. I got it a bit ago on a w00t deal. It's served me well for all sorts of 6v and 12v charging applications.
  19. Jul 23, 2020 at 7:44 AM
    #79
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The reason I run a AGM is to get around sudden cell failure and the corresponding no start on a lead acid. Over the years that has left me stranded more than once. An AGM tends to die slowly. Big advantage for me. I could care less about the capacity and charge issues. Works fine.
    shakerhood and maxtherat like this.
  20. Jul 23, 2020 at 8:02 AM
    #80
    STrooper
    STrooper For HIS glory!
    Jack
    NC
    2018 TRD Sport QuickSand / 2020 TRD Sport Cement!
    Question - I do not do any off road activity, but I would like to transition to an AMG battery for its longevity. What would you recommend, 27F? I hate changing my battery every 2 to 3years, I’ve always go with the Toyota brand.
