Battery problems - 2nd gen 2006 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Grant4X4, Sep 12, 2017.
  1. Sep 12, 2017 at 10:13 AM
    Grant4X4
    Grant4X4 [OP] Member
    So my battery recently went dead, decided to buy a new one. I should've spent the extra penny but I ended up going to Walmart to buy a new battery. (broke college student) the cold cranking amps on the battery say 585 and in the group of 24F. My last battery was at 680 cc and in the group of 27F I believe. My battery is currently not turning my truck on, it's been 4 days since I bought the new battery. I was wondering if I bought the wrong one or if there's a different problem with in my truck that might be draining my battery. I looked on a couple other forums saying that the new battery I bought would've been perfectly fine for my truck but I'm just not sure and thought to come to the best forum online to ask a question. Thanks for taking the time out of your day to read this. I hope I can be helped. Got class all week.
    BassAckwards likes this.
  2. Sep 12, 2017 at 10:19 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    You more than likely bought the wrong battery.
    Replace the battery with what it calls for (type/amperage, etc.) in your Owners Manual. I would take that one back and exchange it for one with the proper amperage and group called for.
    What year and engine size is your Tacoma?
    Also, don't go cheap on a battery, it will only let you down a few months (if your lucky or weeks, days maybe) from when you installed it. College kid or not, spend the extra $ (call mom or dad and ask for $) and get a real good battery, just go to the dealer and purchase one from there.
    Just my $0.02
    Always Remember you get exactly what you pay for....you pay cheap....you get cheap.
    boogie3478 and Grant4X4[OP] like this.
  3. Sep 12, 2017 at 10:29 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Wrong battery, the one you bought it too small and not enough crank.
    That being said, nothing wrong with walmart batteries. Only snobs will say differently, especially considering there are 2 major battery manufacturers that produce the same product under different names.
    Go back to walmart and exchange it.
    JoefromPTC, Grant4X4[OP] and ChemDawg like this.
  4. Sep 12, 2017 at 11:09 AM
    Grant4X4
    Do you think it might be my alternator?
    Because it was running fine for 3 days. I'm just trying to touch all the areas here and figure out the solution. My truck is a 2006 V6 4X4 TRD. Thanks for the response
  5. Sep 12, 2017 at 11:15 AM
    Tex-Tac
    TEXAS
    I would first install the correct battery that your Tacoma requires. Start from there, if it works fine without any other problems then your good to go. If not then you can start looking into the starter, alternator, wiring to and from the battery to the starter alternator, etc.
    Take it one step at a time.
    (get a battery that is the correct Group that has an equal or greater amperage value than what your old battery had 680cc amps. You never want to go below the cc amperage that is recommended for your specific engine, starter and alternator capabilities. If you don't, as you found out, it will only cause problems)
    Check and make sure that the wiring to your battery connecting cables and to the starter and alternator are all clean and free of any dirt or acid build up, etc. Clean everything, all connections with a wire brush and a can of battery cleaner.
  6. Sep 12, 2017 at 1:05 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    I guess I'm a snob....I purchased a battery from WalMart for another vehicle and it ended up failing in less than 2 months. They replaced it under warranty and that battery lasted just over a year before it died. I replaced that with an Interstate battery that was still functioning over 3 years later when I sold the vehicle.
    Tex-Tac likes this.
  7. Sep 12, 2017 at 1:09 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I did exactly this whenever the stock battery went bad in my '13 this year. It came with a 27F (it has the tow package) and I replaced it with a 24F. The v6 tacomas that came without the tow package but still had the 4.0L motor came with the 24F. We have an FJ that has the 4.0 and it also has the 24F. I would attribute this to a bad battery. Take it back to walmart and have them exchange it (it should still be under free replacement warranty). The 24F shouldn't have any problem starting your truck unless its a dud. I ran a 24F in mine for a few months until I could find a 27F since walmart doesn't carry that size.
    I also believe theres nothing wrong with walmart batteries, after all many of the Everstart Maxx's come with a 3 yr free replacement and an additional 2 yr prorated warranty
  8. Sep 12, 2017 at 1:26 PM
    TacomaMike37
    13' DCLB MGM
    Everstart branded batteries sold at Wal-Mart are manufactured by Johnson controls. So there's that.
  9. Sep 12, 2017 at 3:22 PM
    JoefromPTC
    JoefromPTC Well-Known Member
    Joe
    Atlanta Georgia metro
    2005 Tacoma TRD Sport 4X4 6MT
    I've had great service from every Everstart battery I've purchased from Wal-Mart... I will say last time I was there I checked the in-stock batteries, and they didn't have group 27F batteries.
  10. Sep 12, 2017 at 8:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    If it worked for three days and now it doesn't your alternator charging system would be suspect. Get the battery charged and take it to get the alternator charging circuit tested.
    Sandman614 likes this.
  11. Sep 12, 2017 at 8:54 PM
    Pigpen
    Northwest Montana
    24F is fine for most people. I would suspect the alternator.
  12. Sep 12, 2017 at 9:02 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    A 24f is standard for non-tow package. The tow package came with the group 27. Auto parts stores will generally check your charging system/battery for free.
  13. Sep 13, 2017 at 2:48 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Group size only matters so it fits in your battery tray and hold-down hardware. Otherwise, any battery with the minimum CCA rating for a 2006 Tacoma V6 (585 CCA) will do. Group size also contributes to reserve battery power; a larger size battery will hold more reserve power allowing you to run accessories longer with the engine off.
    As JimmyH points out, if your engine ran for 3 days with the new battery, and is battery is now dead - this points to a bad alternator or bad charging wiring connection.
    To test the charging system you need a fully charged battery and a voltmeter.
    When a battery first goes dead, you should run some routine tests to help determine the cause for its demise - a bad battery or bad alternator.
    You start by charging the dead battery. If it can't hold a charge; get a new and proceed to checking the alternator. With engine running, you test voltage at the battery terminals - voltage should read 13 - 14.5 volts. Then do a load test - test for voltage again after turning on some devices (headlights, fan speed on high, wipers on high) and raise RPM to 1500; the voltage drop drop should be about .5 from standing voltage, but no less than 13 volts.
    Here is a good guide: https://axleaddict.com/auto-repair/Alternator-Problems-and-Automotive-Charging-System-Tests
  14. Sep 13, 2017 at 6:45 AM
    Pigpen
    Northwest Montana
    It's good to have a larger battery (more actual capacity) when you run accessories or live in a cold climate. All cold climate Tacos, even without tow package, come with a 27F.
    Edit: they have the heavier duty alternator too.
  15. Sep 13, 2017 at 6:53 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    :canada: approved battery :blahblah:
    NORTHSTAR Pure Lead Automotive Group 27F Battery NSB-AGM27F https://www.amazon.com/dp/B00M4H48MS/ref=cm_sw_r_cp_apa_VGtUzbHAFPHSG
    *not broke college kid approved
  16. Sep 13, 2017 at 8:25 AM
    TacomaMike37
    13' DCLB MGM
    CAn one use a cheap multimeter say this one ( ) to check the condition of ones battery.
    My wife's pilot has original and am thinking of changing it.
  17. Sep 13, 2017 at 2:04 PM
    Pigpen
    Northwest Montana
  18. Oct 3, 2017 at 4:40 PM
    Grant4X4
    Thank all of you! this community is the best when it comes to tacoma problem. you guys rock. to solve the mystery, it was my alternator. Again thank everyone for the support.
  19. Oct 3, 2017 at 4:42 PM
    BassAckwards
    Thats why were here sir! Im also glad to be a part of such a knowledgable group of folks!:thumbsup:
    Glad you figured out the problem!
    Grant4X4[QUOTED][OP] likes this.
  20. Oct 3, 2017 at 8:59 PM
    Jimmyh
    SC
    2012 Prerunner SR5
