battery light flickers, but new alternator a week ago
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wrxRome, Nov 21, 2011.
  1. Nov 21, 2011 at 12:13 PM
    wrxRome
    wrxRome [OP] Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    so i was driving home from new orleans today when almost the whole way back my battery light was flickering randomly, it wouldnt stay lit or flash but completely random flicker, then sometimes go off and come back, i just had the alternator and battery replaced last week and no problems since then (here is the story for that one, http://www.tacomaworld.com/forum/2nd-gen-tacomas/187526-electrial-problems-need-help.html )
    i read all the battery light threads i could and still am confused as what it could be,
  2. Nov 21, 2011 at 12:18 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    the history suggests a short somewhere.
  3. Nov 21, 2011 at 12:21 PM
    wrxRome
    Brandon
    thats what i was thinking but everything is back to stock wiring from the fog light ordeal. so im stuck.
  4. Nov 21, 2011 at 12:55 PM
    2010Tacoma4x4
    2010Tacoma4x4 "Man Ho"
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    Tinted windows, Bug deflector, Rain guards, Bed mat, Rear leaf TSB, Bilsteins front & rear (front set @ 1.75), 16x8 chrome Helo wheels, Toyo open country AT P265/75/R16 tires. CBI bolt on sliders. BSP color matched M1 Satoshi grill. BHLM. UWS low profile black powder coat crosover truckbox. Pioneer DVD/CD head unit - 4 channel amp - front mids & highs - 8" sub box.
    I would check for a loose (or corroded) ground somewhere. Starting from the battery making sure the terminals are clean and work your way throughout the vehicle.
  5. Nov 21, 2011 at 1:25 PM
    wrxRome
    Brandon
    will do. i already looked everywhere in the engine compartment though.
  6. Nov 21, 2011 at 2:15 PM
    Leggo
    Newton,Ma.
    disconnect the neg. side of the Batt. and put a test light between the cable and the - battery terminal. If it lights up, you have something drawing voltage. ( something left on OR a short circuit somewhere.) I never seen a bad ground cause a voltage draw or cause a Battery to run down sitting around..
  7. Nov 21, 2011 at 4:22 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    I thought the voltage draw problem has been corrected and now it was only the battery light flickering.
    Yes if your still having problems with the battery going dead then it would more than likely be something else other than a loose ground.
  8. Nov 21, 2011 at 4:38 PM
    2010Tacoma4x4
    Dave
    Jacksonville, Fl
    2010 4x4 SR5
    To elaborate on what Steve recommends to determine if you have a parasidic battery drain...make sure you have the ignition turned off and the doors closed when using the test light method ;)
  9. Nov 21, 2011 at 5:06 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Where did you get the alternator from? I worked in auto parts for a few years. Just because it's new doesn't mean it's any good.
  10. Nov 21, 2011 at 6:46 PM
    wrxRome
    Brandon
    Autozone
  11. Nov 21, 2011 at 7:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Don't know much about them currently, but used to be crap. There are usually two lines of remanufactured electrical in the aftermarket. You get what you pay for. If they gave you two options and you went cheap, it's probably a bad alternator they sold you.
    I would pull it back out and tell them the warning light keeps coming on. As long as it starts okay, the battery is probably fine.
  12. Nov 21, 2011 at 7:28 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Is the Alt. new or refurbed? Just changed one in a car friday put in a refurb, car showed up at garage this afternoon deader than a doornail. Has a brand new battery too, not a high quality one though
  13. Nov 21, 2011 at 9:15 PM
    Leggo
    Newton,Ma.
    (Nice tip. I had a minor electrical problem with bulbs recently, this would have come in handy. Just so I know for the future,does the key need to be on or anything to do this? If i had a short in a wire and pulled and replugged in the fuse there would be a spark?)
    I saw this in your last thread, what was the problem here?
  14. Nov 21, 2011 at 9:29 PM
    wrxRome
    Brandon
    It said remanufactured on the box. I just told them my truck and they gave me that. They never told me any other options. I'll put my old one back on because it's still good and just return the "new" one.
  15. Nov 21, 2011 at 9:31 PM
    wrxRome
    Brandon
    That was just for future reference if I need to pinpoint a short. But I knew what te prob was there.
    I'm sure it's the new alt now. But today when I went to work after letting my truck cool. The light never even flicked
    So now I'm still confused lol
  16. Nov 22, 2011 at 4:47 AM
    NC15TRD
    Nick
    PA
    Return it and get another one. A refurbished part like that will carry a warranty
  17. Nov 22, 2011 at 12:20 PM
    wrxRome
    Brandon
    yeah thats what i plan on doing, because my stock still is good
