Battery ground disconnected
Discussion in 'Technical Chat' started by Sam091990, Oct 15, 2020.
  1. Oct 15, 2020 at 4:53 PM
    Sam091990
    Sam091990 [OP] Well-Known Member
    Sam
    BLK '12 DCLB PreRunner TRD Sport V6
    Marsauto LEDs in license tag lights Marsauto LEDs in map lights Yorkim Red LEDs in High mount brake light Zevo LED in dome light (may change that, it is not too bright)
    So, I was showing a friend my battery and noticed a possible issue. I looked over where the ground cable shoulda been and saw this
    Ground cable cut?
    So my question is, is it safe to drive it? Truck starts no issue and all electrical systems work. Only thing I can think of is the guy at autozone cut it when he installed my battery. Kinda ashamed I never noticed it.
    Thanks
    Sam
  2. Oct 16, 2020 at 2:51 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It would help to get it attached not a major problem I see strange electrical things all the time.
    It was not cut it just pulled out of the crimp .
  3. Oct 16, 2020 at 5:10 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yeah swing by any local car stereo shop and ask them to make you a 10-12” piece of 4awg with ring terminals on both ends. They might charge you $5. Then just remove and replace the factory wire
    As for being safe to drive, yeah it’s fine for short term. The battery is also grounded to the engine or the frame (which are sometimes grounded together as well) so just get it fixed soon and you’ll be fine
    HisDad likes this.
  4. Oct 16, 2020 at 11:18 AM
    Sam091990
    Sam
    Thank you, it is beyond me why a car store employee would disconnect the secondary ground wire.
    Sam
  5. Oct 16, 2020 at 11:24 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Thats the body ground. Technically not needed but does make the path of current more efficient for things grounded to the body. That other ground cable goes to the engine. Which is technically connected to the frame and the frame is connected to the body. That extra cable just makes the path shorter for electronics not connected to the engine itself.
    whatstcp likes this.
  6. Oct 16, 2020 at 11:29 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Your 100% positive that was still attached when the truck was being worked on.
    Anymore who knows if it would be brought to your attention if the ground was disconnected when you had the truck worked on.
    Quite possible removing the terminal was enough to loosen things it popped off later.
  7. Oct 21, 2020 at 6:30 PM
    Sam091990
    Sam
    Would this affect it if I connected a lightbar or emegency vehicle grille lights? I will be installing 2 flashing LED grille lights on my truck. Possibly 6 more as well (2 on back 2 intersection lights on each side), so a total of 8 lights around the truck. Also a white led light in the bumper.
    Thanks
    Sam
  8. Oct 22, 2020 at 12:25 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Depending just where your grounding your lights it could effect if you get a good ground or not.
    No way to tell till you do.
  9. Oct 22, 2020 at 1:33 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    That's a very common problem on Toyota pickups, now Tacoma's.
    It's a body ground and it is needed. When you fix it, either make a loop with the new wire or make the wire longer than needed so you have some flex in the cable.
    HisDad likes this.
