Battery for 2001 V6?
Discussion in '1st Gen. Tacomas (1995-2004)' started by N81292, Sep 14, 2016.
  1. Sep 14, 2016 at 2:47 PM
    N81292
    N81292 [OP] Well-Known Member
    Looked in the owners manual and I'm trying to figure out what battery would fit. I'm overseas and the exchange only offers a few different types and I'm assuming at least one of them is compatible.
    Brie likes this.
  2. Sep 14, 2016 at 2:55 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    generally it calls for a group 35
    to replace the original
    But IMO that is too small and somewhat underpowered.
    So I would look for a group 34 instead.
    Tho' the battery's terminal placement can be the deciding factor.
    1st Gen. Toyotas have a reverse terminal hook up position
    then say a GM or Ford.
    Do not use side terminals for heavy loads.
    If by chance the battery has those.
    They tend to be a weaker link then the primary post would.
    Brie likes this.
  3. Sep 14, 2016 at 3:07 PM
    N81292
    So an Interstate Battery V346 would be considered a group 34? Sorry I'm clueless about batteries.
  4. Sep 14, 2016 at 3:26 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Group 34r, the terminals are reversed, thats what the r is for.
    Brie likes this.
  5. Sep 14, 2016 at 3:29 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    I went with a Optima, maybe you can order through autozone. they have free shipping to APO
  6. Sep 14, 2016 at 3:45 PM
    N81292
    Ordering online is probably the easiest thing to do because I know for sure It'll be compatible. I do see the Optima a lot, but it seems to be the priciest one. And frankly, I am going to be selling my Tacoma before I PCS so I'm not sure if I want to go that route.
    I'm just hesitant to order online because I want to get this replaced ASAP.
  7. Sep 14, 2016 at 3:50 PM
    carofchoice
    Jeff
    Newton, IL
    If you plan on selling it, just get one with enough CCA and fits. You should be able to just take some measurements of yours and measure the one in the BX and be good.
  8. Sep 14, 2016 at 4:00 PM
    N81292
  9. Sep 14, 2016 at 5:46 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    majority of lead acid type batteries designed to fit the Tacoma's
    terminal hook up will be listed here...
    http://www.interstatebatteries.com/...4rZ1z0tvv6Z1z0tvzmZzihwsq?dsNav=A~Part+Number
    call Interstate for further verification of their offerings.
    I would likely go with the least expensive battery if ya don't plan on keeping it.
    Probably Walmart or Autozone or similar.
    I run dual Yellow Top 34's
    the terminals are opposite then was the original battery...
    But I easily extended the terminals to reach across
    the primary (house) battery.
    The house battery's ground wire was also extended.
    The original house battery hold down/stay was also altered
    so that I needed not use the included Optima plastic spacer.
    Measure the external dimensions of your current battery
    and be sure the new one is near to that...
    Important... if you intend to purchase one that fits as the original did.
    In other words... the external size matters too.
    homemade extension using copper bar stock...
    Note: it was painted after assembly... but not during it's intial hook up
    as it requires a clean contact/ground.
    2002Tacoma4x4 and Brie like this.
  10. Feb 24, 2021 at 7:35 PM
    Brie
    Brie Well-Known Member
    Brieanna
    CA
    2001 Tacoma TRD, Prerunner
    Thank God for old posts!
