Battery died, car is immobilized. How do I reset?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sierrakiwi, Jan 8, 2023.
  1. Jan 8, 2023 at 11:27 AM
    Sierrakiwi
    Sierrakiwi [OP] Member
    hey guys,
    turned up to my truck after work and tried to start it. Had rapid clicking so thought it was the battery. I then tried to jump it and nothing, no crank no click no nothing. I have checked fuses, I have checked the starter relay, I've checked for loose terminals. I'm pretty certain the anti-theft system has immobilized the truck. I've tried turning the key on and off 5 times (apparently it sometimes works), Tried starting and leaving the key in for 10 mins. I have tried unlocking and locking via the door with out the key fob.
    Does anyone have any ideas on how to override or reset the immobilizer? i believe its the factory anti-theft system.
    2012 tacoma, 4wd, v6
  2. Jan 8, 2023 at 11:29 AM
    Bishop84
    Bishop84 Well-Known Member
    Does the red security light flash when the key is in the ignition?
    The security system does not control cranking, it controls injectors. So even with the wrong key, it will crank.
    It sounds like a battery, possibly shorted.
    Raylo likes this.
  3. Jan 8, 2023 at 11:30 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    If the factory immobilizer on the Taco is similar to my 4Runner, the engine will fire up then immediately turn off.
    Superdave1.0 likes this.
  4. Jan 8, 2023 at 12:24 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    If you got the rapid clicking and then it would not turn over either you starter is dead or the jump did not have a good connection.
    Does the engine rotate when you jump it and turn the key?
  5. Jan 8, 2023 at 12:33 PM
    perterra
    perterra Well-Known Member
    Tejas
    Battery, battery connections corroded or starter shit the bed.
    GilbertOz likes this.
  6. Jan 8, 2023 at 12:49 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Chris(NJ) and TnShooter like this.
  7. Jan 8, 2023 at 1:19 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This 100%
    As Dm93 said, unless you have an aftermarket alarm.
    The factory immobilizer will let you crank the truck.
    It won’t start, but you can crank it all you want, or until the battery dies:eek:
  8. Jan 8, 2023 at 5:46 PM
    Sierrakiwi
    So looked around and I believe I have an aftermarket system, bought the truck with it a year or so ago. I'm going to try contact the owner and see if I can find out which alarm it is and go from there. Thank you guys.
  9. Jan 8, 2023 at 5:52 PM
    Bishop84
    One obscure thing I've seen is GPS lock outs hidden on high risk credit purchases, they disable the truck remotely, the only problem is they tend to fail over time, and they are super hidden.
    GilbertOz, TnShooter and Dm93 like this.
  10. Jan 8, 2023 at 5:55 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve heard of times someone buys a vehicle, doesn’t know it has an aftermarket alarm which is set to valet or passive mode. Meaning the alarm is turned off, like it has no alarm. Disconnecting the battery causes it to default alarm on. Without the remote, it won’t start until disarmed.
