Bass Blockers on JBl stock tweeters and mid range speakers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kaiyahzzz, Mar 8, 2019.
  1. Mar 8, 2019 at 8:53 PM
    Kaiyahzzz
    Kaiyahzzz [OP] Member
    2015 Black limited edition Tacoma
    3" procomp lift 33x12.5 discover cooper 18x10 fuel maverick
    Hey guys, So 2nd gen double cab Tacoma with jbl package and I took out the stock 8" sub and added a lineout converter from the jbl amp to my new aftermarket amp with skar IX8 sub. I keep everything else stock. head unit, tweeters, and mids are all the factory jbl's. The problem is that my tweeters and highs are playing the same low frequencies so how could I fix that?
    I heard bass blockers, but unsure on what kind to get and how to install? any help?
  2. Mar 9, 2019 at 3:35 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    If the tweeters are being fed the low frequencies, they're probably junk now.
    To install one, pull the positive wire off the tweeter, attach one end of the bass blocker (capacitor,) to the wire and put this wire back on the NEGATIVE terminal of the tweeter. Move the negative wire to the positive terminal. Done.
    Capacitors, invert sine waves 180°, hence the need to swap positive and negative wires on the tweeter.
    Give it a shot.
    Kaiyahzzz[OP] likes this.
  3. Mar 9, 2019 at 1:46 PM
    Kaiyahzzz
    thanks man Ill try it out, maybe post some pics for whoever wants to try it too. Also would it be the same for the mid speakers?
  4. Mar 9, 2019 at 1:52 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    You could just get a crossover to split out the frequencies you want to each speaker.
  5. Mar 9, 2019 at 1:54 PM
    Kaiyahzzz
    would the crossover be easier to wire than the bass blockers
  6. Mar 9, 2019 at 4:45 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 Super White S/C DCLB TRD SPORT
    Tweeters already have a bass blocker/crossovers, on mine there was when I removed them.
  7. Mar 9, 2019 at 5:22 PM
    Kaiyahzzz
    Ohh okay thats good so that means I probably need to get a bass blocker for the mids cuz that's where the unwanted lows are coming from?
  8. Mar 9, 2019 at 7:27 PM
    Larzzzz
    Larry
    MA
    I don't have the jbl system. Isn't the crossover in the amp?
    OP, have you even looked at the drivers in the door to see what you need?
  9. Mar 10, 2019 at 6:26 PM
    Kaiyahzzz
    Im not to sure on that so maybe ill go poke around and check it out
