Basic brake/rotor replacement
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZachUA, Feb 2, 2024.
  1. Feb 2, 2024 at 10:50 AM
    ZachUA
    ZachUA [OP] Well-Known Member
    Hi, looking to replace the brakes and rotors on my stock 2017 tacoma. I searched around but was finding threads for brake upgrades for trucks with larger/heavier wheels/tires. I just need a good set of replacements for a stock sized wheel/tire non-lifted truck, something that won't break the bank but will be good quality. Any recommendations?
  2. Feb 2, 2024 at 10:53 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I got a complete set of Callahan front rotors and pads for $150. They've actually lasted longer than the OEM did.
    ZachUA[OP] likes this.
  3. Feb 2, 2024 at 10:58 AM
    ZachUA
    nice thanks! I see this one on Amazon: https://www.amazon.com/FRONT-Premium-Brake-Rotors-Ceramic/dp/B01N9MZEI5
    amazon has a note at top that says it will fit a 2017 taco, but the title by the seller doesn't mention tacoma's, and it's my undertanding that 4runners use larger rotors?
  4. Feb 2, 2024 at 11:01 AM
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
  5. Feb 2, 2024 at 11:02 AM
    golfindia
    Yes.
    pickup truck
    I clicked on that link, and it says that's what I purchased in 2021. I have a 2017 tacoma.
    ZachUA[QUOTED][OP] likes this.
  6. Feb 4, 2024 at 7:26 PM
    Waynebarkr
    Waynebarkr Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    If you havent' already--check out this thread. Has links to AMAZING (and short too!) videos he did about maintaining your third gen (including brake replacement--both front and rear).
    https://www.tacomaworld.com/threads/3rd-gen-maintenance-maps-get-300k-miles.789809/
    TomYotaNH and ZachUA[QUOTED][OP] like this.
  7. Feb 4, 2024 at 7:38 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I went with PowerStop because I had a braking vibration with my OEM brakes. Very happy with PowerStop.
    https://www.amazon.com/gp/product/B005FKS28C?ie=UTF8
  8. Feb 5, 2024 at 7:55 AM
    ZachUA
  9. Feb 5, 2024 at 8:21 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    the best bang for the buck is the Tacoma Big brake upgrade using GX470/ T4R caliper rotor pads
  10. Feb 5, 2024 at 8:24 AM
    TA2016
    Oregon
    My pulsating vibration was when braking from about 50mph to 35mph. I normally like to stay with OEM, but went aftermarket because of the vibration that appeared at 40K miles on my factory brakes.
    I have 15K miles on my PowerStop brakes and still happy with them.
    IronratPR likes this.
  11. Feb 5, 2024 at 9:02 AM
    IronratPR
    IronratPR Active Member
    Ace
    Caguas,PR (USA)
    White Tacoma TRD Off Road 4WD 2022 aka The Cloud
    KDmax 9.0
    as previously said, Powerstop.
    I have their rotors and pads on a Infiniti QX30 and a Fiesta ST and an very pleased with them.
    TA2016 likes this.
  12. Feb 5, 2024 at 9:08 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This is the way. Would recommend the Z36 Extreme's to anyone looking for a serious upgrade. Fantastic bite, long lasting and almost no dust whatsoever.
    payrow[QUOTED] likes this.
  13. Feb 5, 2024 at 9:20 AM
    BlackCat81
    BlackCat81 Well-Known Member
    2023 Ice Cap TRD OR
    I wonder if you can then do what us GX470 guys do for an upgrade and go to the 460 brakes.
  14. Feb 5, 2024 at 9:31 AM
    Koolbreeze7
    Jon
    Jersey
    Id be willing to try. I was going to do this on my 3rd Gen, but found a brand new set of rotors for my old Lexus sedan buried in my warehouse. Took them to autozone and swapped them for a cheap brake job. the new Calipers will have to wait
  15. Feb 5, 2024 at 10:11 AM
    BlackCat81
    2023 Ice Cap TRD OR
    Im pretty sure you’d need at least 17” wheels.
  16. Feb 5, 2024 at 10:21 AM
    Koolbreeze7
    Jon
    Jersey
    I have SEMA 17's
    BlackCat81[QUOTED] likes this.
  17. Feb 5, 2024 at 10:30 AM
    eurowner
    eurowner Duke Sky
    Scoty
  18. Feb 5, 2024 at 11:18 AM
    payrow
    Los Santos
    '18 DCSB Sport
    My OEM rotors went into the trash at 43K miles. Thats when I couldn't take the shaking/vibration when braking at highway speeds anymore. Seems to be a common issue with this gen - I see a lot of us with the same problem at approx the same mileage. o_O
  19. Feb 6, 2024 at 7:17 AM
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    I recently ordered oem pads and rotors. They aren't gone yet, but at 100k miles they are getting low. I haven't experienced pulsing or vibrations which is interesting since I've chased those issues on previous vehicles.
    Looking back over 30+ years of driving and numerous brake jobs maybe I'm driving this truck slower and easier than all my previous cars.
  20. Mar 26, 2024 at 12:05 PM
    Hank_Mille
    Hank_Mille Well-Known Member
    PNW
    2016 Tacoma Limited
    Great timing as I need new rotors as well... This kit looks good - I assume that the pads work directly with the stock OEM calipers?
    Thanks!
    payrow likes this.
