Banjo bolt (M12x1.25) pressure gauge adapter
Discussion in '1st Gen. Tacomas (1995-2004)' started by jimbobaja, Mar 30, 2017.
  1. Mar 30, 2017 at 9:40 AM
    jimbobaja
    jimbobaja [OP] Member
    jim
    Walnut Creek, Ca.
    98 SR5 Xtracab 133k ret. land survey work tru
    OME frt. & rr springs & shocks
    Trying to find a fuel Banjo bolt adapter, M12x1.25 w/ a 90 degree 7/16in. x 20 Schrader gauge coupling to permanently mount to replace stock bolt for checking fuel pressures w/o the hassle. Anyone done this and if so where did you source the adapter? I understand these fittings came/come stock on some models, so I can't be the first one to want to retro fit a permanent mount. Old Taco's needing more attention and want to alleviate as much hassle as possible.
    Also want to do the same to '05 Lexus GX470 w/ 4.7 V8 that has same banjo bolt set-up, except w/o the 90 elbow, just straight up.
    Thanks for help. Done some searching, but no go, not my forte.
  2. Mar 30, 2017 at 10:12 AM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Here's a shot, will have to search out the details later...
  3. Mar 30, 2017 at 11:55 AM
    kgw
    kgw
    SoCal
    99 PreRunner
  4. Jul 2, 2020 at 5:59 AM
    Clucky
    Clucky Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    Anyone know if this setup works on a 3.4L? I tried the Autozone loaner kit, which isn't bad, but there isn't enough clearance to get their bolt in and attach the gauge or the 90 to it. I think the bolt for the 3.4L is a M12 x 1.5.
  5. Jul 2, 2020 at 8:11 AM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    It works but I had to remove the 4 bolts holding the timing cover on and pull it away to get the bolt in. Once bolt is in you can screw in the adapters. It’s a pain but it works once you do it
    Clucky likes this.
  6. Jul 19, 2020 at 7:28 AM
    Clucky
    W
    WC to EC back to WC
    Want to follow up here. The banjo bolt and 90 above are useful however the Schrader valve in the Amazon link isn't quite the same as the one shown in the pic. The link is for a smaller, tire size Schrader for air applications. The one in the photo is a larger one appropriate for fuel connections. I ordered that one from Riffraff Diesel and it worked well to connect the Actron gauge from the AutoZone loaner kit. I will point out that the banjo bolt while having the correct thread size is slightly larger than the stock bolt, so you have to coerce the crossover piece a bit to get everything to fit.
    treyus30 likes this.
  7. May 2, 2023 at 12:16 AM
    csrf
    csrf Active Member
    @Clucky
    I'm trying to do the same thing for the 3.4. Can you clarify your comments about the banjo bolt? You said that the bolt is bigger yet that the thread is the same, which is kinda confusing. Bigger how? Is the fuel rail banjo bolt on the 3.4 M12x1.25 or M12x1.5? Also, can you post a link for the valve you got? Also, did you use teflon on the threads?
    WagonHo! likes this.
