"Band-aid" fix for leaking CV boot?
Discussion in 'Suspension' started by BassMaster06, Nov 20, 2014.
  1. Nov 20, 2014 at 12:12 PM
    BassMaster06
    BassMaster06 [OP] Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    3" lift, my passenger side outer cv boot has rubbed a small hole and is now leaking grease. I'm short on cash/time at the moment and was thinking about trying to seal up the hole and make it last a little while longer until i have the time to install a new axle.
    I was gonna do the cv boot slide mod while I'm at it, and then attempt to repack the boot with grease and then use some heavy duty sealant to seal the hole. Any issues i might run into by doing this? Most importantly, is there a special kind of grease that goes into the boot for these axles?
  2. Nov 20, 2014 at 12:14 PM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  3. Nov 20, 2014 at 1:05 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Washington
    BSP 4x4 TRD DCSB
    Not enough
  4. Nov 20, 2014 at 1:56 PM
    BassMaster06
    Dan
    South Carolina
  5. Nov 20, 2014 at 2:21 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Interesting....Well, if you give it a try with that product, let me know how it works out. I'll report back with how well the Shoe Goo fix lasts.
  6. Nov 21, 2014 at 9:08 AM
    BassMaster06
    Dan
    South Carolina
    Did the work last night, drove to work this morning (~20miles). So far so good
  7. Nov 21, 2014 at 10:43 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Right on...keep me posted.
  8. Nov 21, 2014 at 10:46 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    i did this but the leak came back. Another method is to buy a bicycle inner tube and cut it flat to wrap around the boot, then use zip ties to keep it in place between the fins. definitely go and get re booted when you have the chance. I now keep extra inner tube rubber and zip ties in my truck for an on-the-trail quick temporary fix. you should be able to get 2-3 patches out of one inner tube.
  9. Nov 21, 2014 at 11:04 AM
    little red
    little red Well-Known Member
    Central GA
    PreRunner SR5
    In a pinch, I have used electrical tape. A whole roll, round and round from end to end.
  10. Nov 21, 2014 at 1:27 PM
    BassMaster06
    Dan
    South Carolina
    Good info
  11. Nov 21, 2014 at 1:33 PM
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    You can just buy a whole new cv axle for $40-$60 and do it yourself. (Cheaper and easier then dealing with grease) I did mine last week. Never did it before and was pretty easy. I have some pics on my build. (Last few pages)
  12. Nov 21, 2014 at 1:51 PM
    BassMaster06
    Dan
    South Carolina
    I know, I've done it before, twice actually. Im strapped for cash and have other things to pay for at the moment (in the middle of moving/relocating/starting new job). Dust should settle in a few wks. Just needed a quick fix to get me thru the next month or so
  13. Nov 21, 2014 at 2:29 PM
    adriancast
    Adrian
    Ontario, Ca
    Oh ok. I didn't see the part that you'll be installing a new axle when you have the money.
  14. Nov 21, 2014 at 2:43 PM
    BassMaster06
    Dan
    South Carolina
    No worries, it's friday :cheers:
  15. Dec 9, 2014 at 12:14 PM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    The Shoe Goo fix didn't last more than a few days.
