Ball joint grease
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MR.WaynesWorld, Sep 28, 2022.
  1. Sep 28, 2022 at 5:41 PM
    MR.WaynesWorld
    MR.WaynesWorld [OP] Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
    What does everybody recommend to use to grease ball joints?
    I'm going to be changing my UCA’s and the ones I’m looking at have ball joints that can be greased.
  2. Sep 28, 2022 at 6:07 PM
    IrishRed
    IrishRed Appalachian Ridgerunner
    Central PA
    2017 TRDOR DCSB 4x4 MGM Prem&Tech Auto
    Eibach Suspension, JBA UCA’s, 16” SCS Ray 10s, BFG KO2s, ECGS Bushing, Pro Skid Plate, Fumoto Valve, Pro Grille, Opt7 Tailgate Light Bar, AVS Window In-Channel Vents, Roknlokz XL Mud Flaps, Husky Floor Mats, Bed Mat, Tailgate & Glovebox Letter Inserts, TRD Grille Badge, Exhaust Tip, Toyota Hitch Plug.
    I’ve been using Lucas Red N’ Tacky with my JBA upper control arms. Seems to be good stuff, but I’m no grease expert.
    CalcityRenegade and 3JOH22A like this.
  3. Sep 28, 2022 at 10:14 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I’m going to throw this novel idea out there: Use the grease that the manufacturer of the UCA recommends.
    That being said after I get enough experience with this vehicle I will settle on one grease only for the complete vehicle as I really don’t wish to have a grease gun ready with the proper grease for every application.
  4. Sep 28, 2022 at 10:27 PM
    Raijin822
    Raijin822 Well-Known Member
    Canada
    2021 TRD OR
    Red n tacky goes in all my grease points.
    1 grease gun to rule them all.
    I recommend lock'n'lube coupler, make an easy thing even easier
    whatstcp likes this.
  5. Sep 28, 2022 at 10:33 PM
    5efvz
    5efvz Well-Known Member
  6. Sep 28, 2022 at 10:42 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What UCAs? I know my SPCs call for NLGI #2, Grade LB with 3%-5% Molybdenum
    ZColorado and Toycoma2021 like this.
  7. Sep 29, 2022 at 4:44 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Here is a non expert question, do the standard taco’s come with grease fittings? Sorry I don’t really want to crawl under again and look.
  8. Sep 29, 2022 at 5:10 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes. On the drive shaft. They are disappearing on the newer models. YMMV
  9. Sep 29, 2022 at 5:19 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    SPCs do indeed call for a "high moly" grease. It should be dark grey in color.
    Red-n-Tacky is an NLGI grade 2, but there is no moly in it. so it's a different grease. NLGI2 greases like that are usually specced in u-joints though.
  10. Sep 29, 2022 at 5:37 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    I have used red n tacky on everything for a while. Recently switched to Valvoline moly based because my JBA arms recommend moly.
  11. Sep 29, 2022 at 6:10 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Ball joints, tie rods - Moly added
    Driveshaft - normal nlgi #2 (red/tacky, superlube)
  12. Sep 29, 2022 at 6:49 AM
    Technique
    Alex
    Utah
    Any reason NOT to use a moly-based grease on everything? Aside from maybe being more $.
  13. Sep 29, 2022 at 6:53 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    This is a good one, lithium complex, so it's compatible with existing grease in the joints.
  14. Sep 29, 2022 at 6:54 AM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    The moly enhanced Valvoline grease is the best around.
  15. Sep 29, 2022 at 6:55 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    It gives less corrosion protection than non-moly grease. Moly is molybdenum disulfide, which attracts water and turns into sulfuric acid.
    Moly should only be used on sliding metal-on-metal surfaces that takes a lot of power, e.g. driveshaft slip joint.
    Technique[QUOTED] likes this.
  16. Sep 29, 2022 at 7:55 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    https://dropbymyhouse.com/moly-grease-vs-red-grease/
    Molybdenum disulfide or “moly grease” is commonly used for high-pressure metal surfaces that are slow-moving. While red grease works better on rubber seals, rings, and/or bushings. Both have relevant, targeted uses that help lubricate the surfaces they’re on.
    Slow-moving ie: ball joints and tie rods, not driveshaft universal joints
  17. Sep 29, 2022 at 8:03 AM
    Toycoma2021
    Your 2016 probably had them on both the front and rear driveshafts. My 2021 has none. I’ve crawled and crawled and found none. Looks like you need to do some crawling.
  18. Sep 29, 2022 at 8:11 AM
    Toycoma2021
    Oh, so right.
  19. Sep 29, 2022 at 8:14 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
  20. Sep 29, 2022 at 8:15 AM
    adamceckhardt
    adamceckhardt Well-Known Member
    Schaeffer oil makes good quality grease, and have several with moly. I've been using their stuff on my excavator and tractor for years and it seems to work well. My heavy equipment mechanic swears by it, so there's that. The company also has really great customer service- the last time I ordered a really nice lady called me a few days later to offer a discount on future orders.
