Baldwin oil filter VS Toyota
Discussion in '1st Gen. Tacomas (1995-2004)' started by p.fist, Dec 19, 2015.
  1. Dec 19, 2015 at 5:58 PM
    p.fist
    p.fist [OP] Active Member
    04 regular cab 4x4
    So I'm sort of a stickler on what parts I put on my truck, and I try to put mostly original parts when I can. I've been running Toyota filters on it since I bought it and I was wondering if switching over to baldwin would be worth my while. Any input or experience with the baldwin brand would be great.
  2. Dec 19, 2015 at 6:38 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I just remember I always used Baldwin filters be it fuel or oil on my 1994 Dodge 3/4 ton truck w/ the straight six Cummins Diesel engine. It was recommended over any other filter from my diesel mechanic buddy who said they were top of the line. I have never used one on my Tacoma though.
  3. Dec 19, 2015 at 6:46 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    68dave likes this.
  4. Dec 19, 2015 at 9:56 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    When it comes to oil filters (just like motor oil) go with whatever makes you feel better and avoid the really cheapy cheapy ones like the Fram orange cans of death. There's only about 4 companies that make oil filters now and the same goes for motor oil. The days of separate mom and pop shops in that industry are long gone. Toyota oil filters are rebadged Denso filters, Toyota doesn't make their own oil, filters, antifreeze, ATF or any of their gear lubes at all so you don't really know what you're getting with their stuff. I'm sure most of it's just fine but I personally go with brands I know best that have a long standing reputation and good track record. I've gone back and forth between Wix and Purolator filters on my vehicles and never had a oil or filter related problem at all with any of them, just keep up on maintenance and you'll be fine with whatever you use.
    p.fist[OP], vern650 and Sicyota04 like this.
  5. Dec 19, 2015 at 11:35 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Baldwin are perfectly good filters
    TacoDan723 likes this.
  6. Dec 20, 2015 at 2:29 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Baldwin were the go to filters years ago I have no clue about now.
    Have they followed the others to have filters built as cheap as possible.
    I use Toyota or Wix
  7. Dec 20, 2015 at 6:50 AM
    p.fist
    04 regular cab 4x4
    I've never used fram... not even on my first beater I owned it was always purolator or Napa. I have noticed on these filters I get from the dealer is that they say made in the USA?... I wonder if denso has a subcontract with someone because all the others I see are made in Taiwan
  8. Dec 20, 2015 at 8:19 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I've used all brands of filters on my vehicles and never had problems. since I bought about a dozen Toyota filters a few years ago for a good price I haven't used different. there will always be possibilities of failure in any brand. just less in the top quality, but always possible. as stated keep up on the maintenance, don't abuse it and it should be fine and last awhile.
  9. Dec 20, 2015 at 9:21 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Send one to @chris4x4 and have him tear it open for you. That'll answer your questions. Search "oil filter comparison" and look at his thread. Even the "oversize" filters don't have as much filter media as OEM.
  10. Dec 20, 2015 at 9:22 AM
    DrFunker
    DrFunker Well-Known Member
    Would like to hear @chris4x4 's opinion. :rolleyes:
  11. Dec 20, 2015 at 9:33 AM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    baldwin and wix make filters with 98+% filtering efficiency. those are the premium filters youll find at places like NAPA or Carquest/Advance Auto Parts. not autozone, oreillys, or pep boys.
    ac delco, motorcraft, fram and those other "oe" filters only have about 94% filtering efficiency. wouldn't recommend them. this is true with most filters bought from domestic dealers.
    purolator makes filters that do 94, 98, and 99+% efficiency. you have to make sure your getting their premiums if you want good filtration.
    K&N and mobil 1 filters are always 99+% filtering efficiency.
    denso filters im not sure about their filtering efficiency. i would hope it's 98+. either way it's a good quality filter.
  12. Dec 20, 2015 at 9:40 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I'm not sure if Chris is still tearing filters apart, but previous comparisons are located here.
  13. Dec 20, 2015 at 9:43 AM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    im sure they are fine But why the switch?
  14. Dec 20, 2015 at 11:13 AM
    2004TacomaSR5
    Jon
    Montana
    Not exactly sure, but it's definitely not uncommon for them to be subcontracted in different areas. Last time I heard they were made in Thailand, but that was a couple years back.
  15. Dec 20, 2015 at 11:16 AM
    Caligula
    Los Angeles, CA
    I usually reuse my oil filters 2 or 3 times after running them through the dishwasher. Thats ok right?
    keakar, ThunderOne and p.fist[OP] like this.
  16. Dec 20, 2015 at 11:22 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^IDK, how is your dishwasher?
  17. Dec 20, 2015 at 11:30 AM
    KenLyns
    Belly of the Beast
    Agree with most of what you are saying, however the filters Denso makes for Toyota are constructed differently than those Denso makes for the aftermarket. Could be a matter of patents or the need to cater to multiple car makes and models.
    From left to right, Denso filter fitted to Tacos at the factory, Denso filter at Toyota dealer, Denso aftermarket filter, Fram filter:
    2004TacomaSR5[QUOTED] likes this.
  18. Dec 20, 2015 at 11:37 AM
    2004TacomaSR5
    Jon
    Montana
    I've never actually seen a factory filter cut open, that's definitely different and unique looking to say the least! Never seen a media quite like that before.
  19. Dec 20, 2015 at 12:11 PM
    p.fist
    04 regular cab 4x4
    Dealership is just to out of the way and the truck shop down the road stocks them.
  20. Dec 20, 2015 at 1:41 PM
    CodeSeven
    Serge.
    Coachella Valley
    Depends. Did you use one of those dryer freshening towels?
